Massey 6180
/ Massey 6180 #1
massey6180
massey ferguson 6180
We purchased a 6180 a few years back and recently we have had bother starting it....Turn the key and nothing happens and only way to get her going is to connect the two points on the starter motor with something metal...Any ideas
/ Massey 6180 #2
Bad ground?:confused:
/ Massey 6180 #3
G'day could be a bad ground but it could also be one of the safety switches check the pto is not on, the fwd/rev shuttle lever ( if fitted ) is locking into nuetral, and also check the clutch switch they are about the only interlocks i can think of at the moment. Don't be too hard on yourself if the pto is in i recently drove 450km round trip to a combine harvester with a set of new batteries and starter as the new owner and cutomer of ours rang up complaining that he could not start ( threatening to charge us for downtime), as the machine was new to him i asked if he had everything turned off and in nuetral he swore it was. I get there at about 930 pm and get in it to check what is happening the first thing i do is put the hydrostat into nuetral and turn the key........ what do you know it fired right up, he very :mad::ashamed: but he going to feel worse when he gets my bill:laughing:.
Jon
/ Massey 6180 #4
Very common this not having everything in Neutral or off position bug is.
You're generally no good when the call comes in, machines junk, of course the operator checked everything. Nothing like that feeling of satisfaction when it fires right up, much to the operators's surprise.
Yup, that's why we get the big bucks.
/ Massey 6180
Cheers for help and wouldnt fancy the round trip
/ Massey 6180 #6
This recently happened to me for my 4253. It turned out to be a wire that plugged into the tranny area, that had somehow disconnected. I'm assuming it was the clutch safety wire.
/ Massey 6180 #7
when you cycle the clutch pedal does it wake the transmission controller up?
/ Massey 6180
Yea she lights up on the dash but when you turn the key theres nothing just a clicking noise when the key is turned
/ Massey 6180 #9
G'day when you say you short the two metal parts on the starter are you talking about the two large terminals or one large one small? If you short from the top large lug to the push on terminal and it starts then your starter is ok if not pull the starter and have o/hauled. If it starts then check at the firewall above the starter and you should have a couple of big elec junctions there, pull them apart and clean the terminals and inspect the wiring at the back of the plug, I have had some corrode there and give some hassles
Jon
/ Massey 6180
starter has been recently o/hauled along with solenoid..if a battery terminal had a small crack would that be the cause..avent checked that yet
/ Massey 6180 #11
G'day yes a cracked or dirty battery terminal can do that, pull both term and give a good clean with emery to the term and the post also check the back of the term for corrosion where the wire goes in
Jon
2011 International DuraStar 4400 18ft. Cab and Chassis Truck (A64194)
2011 International...
2012 Kenworth T300 17ft. Cab and Chassis Truck (A64194)
2012 Kenworth T300...
2011 Takeuchi TL250 Compact Track Loader Skid Steer (A64553)
2011 Takeuchi...
2023 JCB S3246E ELECTIC SCISSOR LIFT (A63276)
2023 JCB S3246E...
Kivel 42in Forks and Frame Mini Skid Steer Attachment (A64553)
Kivel 42in Forks...
LAND PRIDE 10' HYD 6 WAY BLADE (A64278)
LAND PRIDE 10' HYD...
