3-Point Hitch raises very slow
/ raises very slow #1
WhiteFox
Washington State
1953 Ford Golden Jubliee NAA
I recently purchased a small farm, and got an older international 424 gas powered tractor. It has a 3 point setup, but works very slowly. THe previous owner had a hydrolic pump mounted at the front of the engine, and that raises and lowers the front bucket quite well, and with authority. :) But the 3 point is really slow. I also own a 1953 Ford Golden Jubalee (NAA) and the 3 point hitch works flawlessly and is very responsive.
I do not yet have any manuals tfor the 424, but have any of you come across this on your tractors? Is there a filter in the system and if so, where?
And yes I am researching getting the necessary manuals, but decidded to turn to the internet to see what I could learn. I also drive motorcycles, 2003 Kawasaki Vn900, and belong to a forum and hve gotten a wealth of information from that, so I thouhgt I would try here.
/ raises very slow #2
There is a knob under the front of the seat. Make sure that is open!!! It is a shut off for the three point or to just regulate the flow for more controled uses.
/ raises very slow #3
clean the hyd filter it is in side the lift top on the front right side all u need to do is remove the hyd line and one bolt and the filter will come out the front
/ raises very slow #4
If you raise the front of the tractor you won't lose most of your hyd fluid.
That said on a tactor as old as a 424 the hyd like needs replacing and raise the front will help it drain out too.
