2210 Rear or front snowblower?
/ 2210 Rear or front snowblower? #1
megotatractor
New Richland, Minnesota
JD 2210
Is anyone using a rear 3 point snowblower on a 2210? Wondering about the snowthrowing performance of a rear blower vs front? I have been trying to decide to buy a front 2 stage which would require a hassle to change to front loader, or a rear 3 point blower; I have seen Buhler units that are 50 inches but weigh in excess of 400 lbs and wonder if the 3 point can lift that much in addition to the 100lb? quick hitch?? Plus some units that require a MINIMUM of 16 pto hp, is it a struggle for the 2210 ? if I recall correctly has 16 pto hp??
/ 2210 Rear or front snowblower? #2
Do you enjoy driving your car backwards? if the answer is NO, then your decision is much easier.
I just will never understand this thought.
/ 2210 Rear or front snowblower? #3
I had to change from my front blower to my FEL on my 4110 last week. It took me almost 10 minutes ( some ice on the hydraulic connectors). Normally it doesn't take that long.
/ 2210 Rear or front snowblower? #4
Although I have a 4210 and the rear blower was cheaper, but like said before, if you like driving in reverse they are fine. But if you live in a place that gets lots of snow, it will get old quick.
/ 2210 Rear or front snowblower? #5
You will be fine with a 3PH blower as long as you keep the loader on or have front weights. Your 2210 is closer to 20 HP at the PTO.
/ 2210 Rear or front snowblower? #6
I agree ,short or little usage rear blower..Maybe...Doing more than one driveway ,long driveways,, I wouldn't and didn't even think of a rear blower..
I use a rear blade for a total of maybe 10 min in a evening of using front blower for 3 hrs.. Just can't turn around for any length of time.
The reason I even consider a rear blower is this; since 2004 we have gotten by fine with the FEL and rear blade and the tractor often sat for several weeks at a time. Suddenly last March 2010 we had a 22 inch snow dump! Took me several hours seat time to clear. And then RECORD snowfall in December, several 12" dumps in a row, ran out of places to push and stack it. I figure rear blowers may be easier to find and I would rarely use it anyway, 1 year in 30 we get snow like this, but requires a blower. Plus the fact that front quick hitches for a 2210/2305 are getting rarer and harder to find as I continue to procrastinate because I haven't had a raise in 4 years... but if it keeps snowing this March I will have little choice; buy a blower , or ... wait for a farmer or neighbor with a big machine to get here in the morning and I'm late for work.
/ 2210 Rear or front snowblower? #8
I've got a question that I hope isn't of track.
I was wondering if there was a difference in snowblower performance if the same snowblower could be attached to either the mid or rear PTO.
Looking at the tractor specs. I see the PTO is listed as X HP.
If a tractor has both mid and rear does that mean both the mid and the rear are same HP?
P.S. Just trying to learn as much as possible before laying down hard earned money.
Good question! On a 2210, perhaps other models, the mid and rear pto's can be shifted to work at the same time, or either. Both PTO's should run directly from the engine, BUT the mid PTO operates at about 4x the speed of the rear. As I recall High School physics horsepower is a function of force vs speed, but I have no idea if mid pto would rate the same as the rear? On a 2210 as I recall the rear pto hp is 18?? which seems about right for a 62 inch mower deck.
/ 2210 Rear or front snowblower? #10
Pretty simple really: Cost, versatility and availability...all advantages of the rear blower.
Added: And, you still have the loader installed, if you need it...
/ 2210 Rear or front snowblower? #11
I had to join the front mount group, I did a search, and, I found a JD 59, from a JD 790, sitting on JD dealer's lot in Michigan, hard to believe that it had been there since last November, but it was mis-labeled as a 2575, Unless that is how they number them in the UK? It took 2 days shipped from MI to VA,
So, anyway, I have my almost new, rear 3PH, 60" Meteor for sale, in the classifieds, if anybody is interested, any reasonable offers considered, including meeting halfway, etc.,
/ 2210 Rear or front snowblower? #12
I have a rear snowblower and it works just fine. I picked it up second hand and as there are lots of these around, the price was good.
If I had a bucket of money lying around, I would buy the front blower and keep my landscape blade on the back........
No such luck tho, so its a second hand rear blower and my bucket on the front. Driving backwards is a pain, I will admit, but the pain is less that the cost of a front blower.
At the dealer the front blower was $4500 and the rear one was $2300, and my used one was half that again....... in the end its your money....
/ 2210 Rear or front snowblower? #13
I too opted for a front mount. While looking at john deere 59" I stumbled upon an Erskine. Not cheap, some initial assembly required but I can switch from my snow blower to loader in about 5 minutes. Mine is an older 770 so the entire bucket& boom arms come off. The Erskine is a rear PTO driven front blower and a rugged piece of equipment. I really like the idea of going foward, and to me it's worth the price as I don't replace equipment often.
http://erskineattachments.com/snow_attachments/snow_blower_front_mount/index.cfm
/ 2210 Rear or front snowblower? #14
/ 2210 Rear or front snowblower? #15
I was talking to my dealer about a front-mount for my 2320 for next season and he told me Deere may have a hydraulic front-mount blower next fall -- attaches to the FEL arms. Don't know more, i.e., if it requires its own SCV, etc. Lose the bucket but keep the rear blade and might be faster to mount and dismount than mechanical drive. I believe hydraulic front-end blowers have been around for a while for big equipment.
/ 2210 Rear or front snowblower? #16
They offer that now for the BIG tractors, but it cost's close to 10K for the whole setup. I don't think you'll see it for the small tractors.
/ 2210 Rear or front snowblower? #17
harddock That's one heck of a snow blowing machine!:thumbsup:
/ 2210 Rear or front snowblower? #18
I am nearing the end of my first winter using a rear PTO blower. My driveway is 500' long and flat. Here are some humble opinions at this point:
I have no gripes about turning 1/2 around and driving in reverse to blow snow. However, if I had to back downhill, I don't think I'd be as content.
Last week, we had a lot of "wintery mix" -- snow, rain, and more snow & rain. The blower can't force this wet, heavy mush through the chute. I cleared the driveway with the FEL which, with the blower on the rear, I've left mounted on the tractor. Very convenient.
For me, the choice actually came down to the dollar difference between front and rear snowblowers. I'm sure that if I had gotten the front mount, I'd be perfectly happy with that as well. Sometimes the hardest choices are when neither choice is wrong.
/ 2210 Rear or front snowblower? #19
I have the SB1154 on my 2305 and it does really well. I think I could have gone to the 60 inch but I like the one I have. Having the bucket on the front and the snow blower on the rear works well for me. Looking backwards to use the snow blower is not a problem but I do have a tendency to hit the bucket lever with my knee causing it to slowly curl open.
/ 2210 Rear or front snowblower? #20
Hi
I have a rear mount blower on my 2305 Deere, its actually a 48" Buhler Farm King Blower, it works great but if you get that heavy wet S%!T thats slushy it will plug up the blower. I wish my 2305 had a loader.
I like the rear mount blower as its easy to hook up and take off the 3 point hitch when changing seasons. No crawling underneath to disconnect the drive shaft for the mid-mount PTO that is used if the blowers on the front. Maybe because I am young, but I don't have any problems with looking backwards while blowing snow, now granted if I had several 1500 foot + driveways, I would opt for a front mounted blower.
I actually had a front mount blower on an Agco gas garden tractor that worked well, but I really like the manuerablity of the blower on the back.
Take Care Jason B
(INOP) 2007 VOLVO A35D OFF ROAD DUMP TRUCK (A60429)
(INOP) 2007 VOLVO...
2022 EZ-GO ELITE...
2023 LHD 7000MB Mega Buggy - Only 35 Hours - Kohler Gas Engine - Rotating Dump (A63689)
2023 LHD 7000MB...
Zero Turn Mower (A59231)
Zero Turn Mower...
UNUSED WOLVERINE HYD 6 WAY DOZER BLADE (A64281)
UNUSED WOLVERINE...
2005 Toro Z Master Commercial 72in Zero Turn Mower (A61572)
2005 Toro Z Master...
