3-Point Hitch Top Link ?
/ Top Link ? #21
You're better off to wait until you have both the tractor and some implements before you buy the HTL. Take some measurements of the top link with implements set up and go from there. The stock top link that comes with the tractor may not have enough adjustment for all implements, it's why they're removable in the first place.
Sean
/ Top Link ?
Sean
Chilly, that sounds like great advice thank you. I think that is what I will do. I should be getting the tractor within the month and I also am getting a Land Pride 66" Box Blade. I think I will do exactly what you said. That makes great sense. I would guess that the mounting brackets of different implements may not be the same. I also think I need to find out the diameter of the hydraulic cylinder to use. I don't want it to be to weak. On the other hand if it is to strong could a person wreck the tractor? I am new at this so am learning. Thanks to all of you for the help. When I do end up getting this I will post and let you know what I did.
2011 Chevrolet Silverado 1500 Ext. Cab Pickup Truck (A64556)
2011 Chevrolet...
2003 Freightliner FS65 Thomas School Bus (A64194)
2003 Freightliner...
2017 Ford Fusion Sedan (A64557)
2017 Ford Fusion...
ATS ATS-PC90 Heavy Duty Plate Compactor (A62679)
ATS ATS-PC90 Heavy...
KIVEL PALLET FORK ATTACHMENT FOR MINI SKID STEER (A64553)
KIVEL PALLET FORK...
2019 KENWORTH T880 DUMP TRUCK (A65054)
2019 KENWORTH T880...
