JD2320 DIY PB kit
   / JD2320 DIY PB kit #1
dmay
Gold Member
Winnipeg, MB
2010 JD2320
The John Deere power beyond kit for my tractor lists for $304 CDN. Looking at the kit and reading and gathering knowledge from the expert members here I think one can build their own PB kit at substantial savings. I'm hoping this thread (with the help of others) will become a DIY PB Kit shopping list.
Am I correct that to go from my stock JD2320 valve to having PB flow in basic form requires adding one plug into the valve block and two fittings onto the bottom PB ports? On looking at the LVB25603 PB kit (see attached) this looks like:
#23 - PT13744 plug = $4.42
#19 - M808055 fitting = $98.12 x 2 = $196.24
#18 - M809071 fitting = $30.43
Total $231.09
The plug cost is reasonable and I guess only a JD part. Fine. The fitting prices seem to take the bulk of the kit cost. Are there cheaper fitting alternatives and if so, what exact vendor part numbers have you found work best?
   / JD2320 DIY PB kit #2
Yes, you can do it without the JD "kit", just like Jim did in the one post I linked in your other thread. You will need the "plug" (it's just a little set-screw) form JD. The fittings are standard-but I don't remember what they are-ORB I think but not 100% sure, they don't need to come from JD.
   / JD2320 DIY PB kit
What size hoses (1/4 or 3/8) does JD supply in their PB kit?
   / JD2320 DIY PB kit #4
For the record...... $300 doesn't sound that terrible. I'm sure I had the better part of $200 in fittings and hoses when I did mine on my Kubota. Considering the JD kit will have the JD fit an finish....... might not be a bad option, considering.
   / JD2320 DIY PB kit
I think the equivalent fittings and hoses of the JD kit will come in around $50 priced from Surplus Center. The actual pieces required are minimal. There is only one part that must come from JD and thankfully this cost $1.35 CDN. The rest are standard hydraulic fittings and hoses simply grossly overpriced by JD.:confused2:
   / JD2320 DIY PB kit #8
In most case that is 100% correct since it includes the QD's and brackets...But he just needs the hoses to feed a valve so he would not use most things that are included in the kit.
   / JD2320 DIY PB kit #9
Total $231.09
Hello
Did this work? Can you provide help?
Thanks
2020 New Holland 105 Workmaster MFWD Compact Tractor with 632TL Front Loader - Poultry Special (A55302)
2020 New Holland...
2011 Ford E-350 Passenger Van (A53422)
2011 Ford E-350...
2024 KMC 7406 LOT NUMBER 11 (A53084)
2024 KMC 7406 LOT...
2013 Cadillac SRX SUV (A53424)
2013 Cadillac SRX...
2011 FORD F-250 Crew Cab 4X4 Pickup Truck (A53422)
2011 FORD F-250...
2017 Freightliner M2 106 Medium Duty Truck, VIN # 3ALHCYCY5HDJD6749 (A55788)
2017 Freightliner...
