L275DT repairs
/ L275DT repairs #1
brain55
Brentwood, CA
This is a tractor I started working on yesterday for a customer of mine. I'm replacing the clutch, I repacked all of the loader cylinders, will be replacing all of the hydraulic hoses, and putting new o-rings in the loader valve. It's getting a new seat, exhaust pipe, drag link and tie-rod ends, the left hand bevel case seals, all of the fluids changed, the decomp wire, hourmeter cable, and high-speed reverse lock-out cable. It should be about 20 hours work by the time I'm all done.
Brian
/ L275DT repairs #2
Brian
Are you replacing both clutch disks or just the travel clutch?
That's a big list - and a lot of work- it would take me way more than 20 hours (I'm slow). :eek:
Good luck Dick B
/ L275DT repairs
Good luck Dick B
Just the drive clutch and the drive plate, the PTO is seldom used. I will replace both belleville spring though. I should be finished today. All I have left to do is reinstall the clutch, push the machine back together, replace the o-rings in the loader valve, and replace those cables that I mentioned, plus replace all of the fluids.
Brian
/ L275DT repairs #4
Hey Brian, my friend has a L355 with the shuttle and his travel clutch needs replacing. I have an alignment tool for the L345 travel clutch. Do you happen to know if the 355's clutch uses the same pilot tool? Anything else about a L355 clutch job we should know? It would be great if you could drop in for a beer - but it's a hike from Brentwood to Mass. Take care, Dick B
/ L275DT repairs
I'm not sure that I have ever done a clutch on an L355. If I did it was close to 20 years ago. So, I guess my answer is, I don't know. I'm sure the pilot bearing is the same size but I'm not sure about the splines on the disc.
Brian
/ L275DT repairs #6
Cant you put the clutch on the tranny shaft, roll the tractor back together, then install the pressure plate bolts? Used to do John Deer 2630, 3020 etc that way. It was much easier to align. All you had to hit was the pilot bearing as you wiggled it together!
/ L275DT repairs
I guess you could do it that way. Personally I'd rather use a wooden dowel with masking tape wrapped around it to the right diameter.
Here is the assembly on the bench mounted in the Kubota tool.
12T Grain Bin (A65579)
1980 Fontaine Flatbed Trailer (A65563)
1980 Fontaine...
2016 Peterbilt 579 Wet Kit T/A Day Cab Truck Tractor (A64556)
2016 Peterbilt 579...
New/Unused Wolverine 66in Quick Attach Smooth Bucket (A65583)
New/Unused...
2005 LUFKIN 45'X102" FLATBED TRAILER (A65643)
2005 LUFKIN...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
