front loader bucket
/ front loader bucket #1
rlmooremail
Mahindra 3510
Loader Bucket will not roll UP. If I tap on top of valve it will roll up slowly. Maybe "Load holding check valve"??? Maybe "Main relief valve"??? are they repairable? Nimco: 10373-25: 04-22: 261364 My phone 9186557529
/ front loader bucket #2
Your numbers are hard to track with out knowing model#
example cv432 and request pdf
see this site...
Or look up your valve at this Finnish distrbutor
Poor service support in US...Maybe some alive in Wisconsin
Valves repairable?? depends on parts support...
Valves "cleanable"!!....most likely...
/ front loader bucket #3
Maybe the valve body is over tighten, and warping the valve. Can you see if the spool is moving. Did you inspect the bottom of the valve spool for rust, etc.
/ front loader bucket #4
Is this valve manually operated or electrical solenoid operated?
Lifts (A61567)
Lifts (A61567)
2021 CATERPILLAR 326 LONG REACH EXCAVATOR (A64279)
2021 CATERPILLAR...
2020 VERMEER LP873SD1 VAC-TRON VACUUM TRAILER (A63276)
2020 VERMEER...
2017 Bobcat E55 (A60462)
2017 Bobcat E55...
2019 Ford F-350 4x4 Crew Cab Pickup Truck (A61568)
2019 Ford F-350...
2016 Ford F-150 Crew Cab Pickup Truck (A59228)
2016 Ford F-150...
