replacement cylinder question
/ replacement cylinder question #1
zmansmac
Gold Member
Arcadia Township, Michigan
Kubota B7500
I am looking to replace a couple of loader cylinders on my B7500. However, I don't want to spend the extra money to buy them from Kubota. I plan to get them from Surplus Center or Bailey's. The rods are 1 inch and the outside of the cylinder measures 1 7/8 inch. I'm not real familiar with hydraulic cylinder wall thickness but I'm guessing these are 1 1/2 inch bore and not 1 3/4 inch bore. Does that sound correct? :confused:
JohnZ
B7500
/ replacement cylinder question #2
Why do they need to be replaced? Are they bent?
/ replacement cylinder question #3
I would guess they are 1 1/2" bore. Like Kenny asked, are they too damaged to reseal? Finding cylinders that don't need modifying to work may be tough. If they are like my BX, they will have crosstube ends, which makes it a common configuration, but finding ones with the correct retracted length and stroke may be difficult.
Kim
Yes the rods on the lift cylinders are slightly bent and will not completely retract. It was an unfortunate incident when I let a friend use my tractor. :mad: Obviously, a poor decision that will not get repeated.
JohnZ
B7500
/ replacement cylinder question #5
You might check with a hyd shop for new shaft and seals for those cyl and compare their price for two new surplus cyl.
/ replacement cylinder question #6
Assuming you feel comfortable disassembling the cylinders, you might want to check with Kubota to see if the rods are available independently.
/ replacement cylinder question #8
JohnZ
B7500
is said "friend" helping out with the repairs?
Just curious...
/ replacement cylinder question #9
Just curious...
I know if it were me who caused the problem, I would surely help cover the repair costs. :thumbsup:
Chad
/ replacement cylinder question #10
Chad
Especially when this was damage caused by abuse......if they are bucket tilt cyls then he was back-dragging with the bucket chiseled down.....
The "Friend" needs to get a bill for repairs after the smoke clears.....if it was a rented machine he'd pay for all costs associated with the damage...maybe even brand new OEM cyls.......
Why should the owner pay for this.....Ouch..!!
Yes, he's a good friend that will cover the repair/replacement cost. But he's not in real good financial condition right now and so I am trying to keep the cost down for him. Good friends are hard to come by these days. In the future I will do the loader work for him. Thank you all for for concern.
JohnZ
B7500
2023 26ft Freedom Trailers Akurate Dynamics T/A Mobile Spray Foam Trailer (A64556)
2023 26ft Freedom...
2007 INTERNATIONAL PAYSTAR 5600 Bucket Truck (A62679)
2007 INTERNATIONAL...
2014 John Deere 350G Hydraulic Excavator (A64194)
2014 John Deere...
Bainbridge,Georgia (A65640)
Bainbridge,Georgia...
2012 Peterbilt 337 S/A 16ft. Cab and Chassis Truck (A64194)
2012 Peterbilt 337...
2017 Ford Explorer AWD SUV (A64557)
2017 Ford Explorer...
