Replaced dash park brake indicator micro switch - pics
   / Replaced dash park brake indicator micro switch - pics #1
Mousefield
Elite Member
Qualicum Beach on Vancouver Island, BC. Canada
Sold 2008 CK35 HST
My dash park brake light was staying on all the time. I had tightened the lever, which was a bit loose, but it still stayed on all the time. The steel spring on top was going up and down so figured the switch was stuck, played around with it a bit but stayed stuck. Got a replacement from my dealer and replaced it. First I took off the black fuse box. Then I tried to unscrew the micro switch, no way was it coming off. :mad: So then took the shiny plate that the micro switch was screwed through by removing the two bolts holding the plate on. Once the plate came off I saw why the micro switch was not coming off. :thumbsup: The two long skinny bolts through the micro switch had nuts on the back. :p Once I could grab the nuts then I could unscrew the bolts holding the micro switch to the shinny plate. Got it back together and it is working properly. :D
   / Replaced dash park brake indicator micro switch - pics #2
Sounds like you have the problem fixed for sure.. I sent you an E- Mail as
requested.. Doesn't take much to knock them out of adjustment or have dirt get into them and screw them up. The installation on the CK30 HST is a little different then your tractor but works the same ...
The Fox.
Auger Drill Bit (A56857)
Auger Drill Bit...
Bush Hog 3pt 14' Mower (A53317)
Bush Hog 3pt 14'...
2017 Komatsu PC490-11 Hydraulic Excavator, S/N A41596, PIN# KMTPC251JHWA41596, Turbo Diesel Engine, (A59076)
2017 Komatsu...
2019 DODGE RAM 3500 (A58214)
2019 DODGE RAM...
2012 PETERBILT 388 (A58214)
2012 PETERBILT 388...
2017 Rogator RG1300B Dry Fertilizer Applicator (A56435)
2017 Rogator...
