Fence Post tops
/ Fence Post tops #21
Thanks for all the suggestions. Keep them coming. Maynard, I really need you to post a pic of the boots (The wife loves the idea, her horse pens anyway). Robert, I like yours too, how messy is it, or can you paint it on neatly?
I can't figure out how some people can go through that many boots, but they must or have all there friends and family bringing them boots. I will see if I can get a picture. Not surprised you haven't heard of it, you know, "What happens in Dodge stays in Dodge." :)
/ Fence Post tops #23
I've been thinking of ways to do this to. I want it to be attractive and have a WOW factor to it, but not be junky or tacky. I've beent hinking that a dinner plate, glued to the post unside down might look nice if I had something nice to put on top of it. I don't know what, but have thought of things like a bottle or a decorative ceramic animal or bird. I've also thought about a metal disk and then putting a phinial on top of it of some kind.
Eddie
/ Fence Post tops #24
Mix up beeswax and linseed oil, heat it up and you can seal the tops.
I used this mix on the outside of my bee hives to keep them "natural".
/ Fence Post tops #25
Forrest,
I took a roll of (I think its called) metal flashing I bought at HD and cut it into sized squares. I beat it with a hammer to form around the post. There was no need to attach with a nail. Ten years later, I now realize the treated post weakest part is in the ground, not at the top.
Housten
/ Fence Post tops #26
Almost all of ours rot out at the ground level, very few go bad at the top enough to make a difference in the integrity of the fence.
We try to use black spruce and juniper as much as we can, although a red spruce gets in the mix from time to time. Balsam fir is largely a waste of time.
Sean
/ Fence Post tops #27
Does it really make a difference to put a coating or topper on a post? I'm skeptical. Never seen a post rot away from the top down.
/ Fence Post tops #28
We have been using roofing tar. Horses won't bother it and it's cheap.
The reason for topping the post keeps the horses from cribbing the wood.
2020 Takeuchi TL8R2 Track Loader with 72in Tooth Bucket (A63689)
2020 Takeuchi...
2008 Yale GLP070VXE 6,500lb Propane Forklift (A61572)
2008 Yale...
Freightliner Tender Truck - Adams Tender (A63688)
Freightliner...
2025 BrushFox XHD72 72in Rotary Brush Cutter Skid Steer Attachment (A61572)
2025 BrushFox...
Mini rock grapples (A61567)
Mini rock grapples...
Patterson water pump (A59230)
Patterson water...
