Trailer Needed - 4K Load
/ Trailer Needed - 4K Load #1
Scrambler82
SoCal
Mahindra Max 28XL, HST, TLB
Ok guys need suggestions on what to buy for a trailer to move a small tractor ?
3K Tractor + a couple of Attachments.
Need brake
Light weight - aluminum ???
Narrow if possible
Thks
/ Trailer Needed - 4K Load #2
Need brake
Narrow if possible
Thks
You need a 7,000# car hauler. Remember, a trailers weight class must also support the weight of the trailer itself along with the load. So lets say you get a 16' 7,000# car hauler. It may weight 2,000# empty so it can legally and safely haul a 5,000# load as long as your truck is up to it. Aluminum will save you a few pounds but cost about twice as much.
I would skip narrow. Very limited use. Get something you can use for many tasks including the rescue of broken down cars, ect.
The main thing with a tractor is to measure it with the loader down and the biggest implement you have then add about 3' to that length. That is the length of the trailer you will need to secure and balance the load properly. You tie down chains will need a angle to do the job hence the longer trailer.
Biggest mistake most people make is getting just barely enough trailer, me included.
In my opinion a 7,000# trailer with a modern 1/2 ton truck is just fine. Brakes on one axle is ok for a 7,000# trailer but anything bigger get brakes on both. Of course brakes on both is always better.
According to my trailer towing guide book brakes are not even required in Mass. May want to check on that but I would want them and it seems like you do also.
Massachusetts:
Maximum Speed Limit: 55
Maximum Dimensions for trailer:33'L x 8'6"W x 13' 6"H
Maximum Length with Trailer:N/A
Minimum Weight requiring Separate Trailer Brakes:N/A
Trailer Equipment Requirements:
Safety Chains:Y
Brakelights:Y
Taillights:Y
Clearance Lights:Y
License Light:Y
Turn Signals:Y
Reflectors:N/A
Flares:Y
Breakaway Brakes:N/A
Tiedowns:Y
Two Trailers:N
Insurance:Y
Chris
/ Trailer Needed - 4K Load #3
i bought a standard 16' car trailer for about 2400 us, and beefed up the rear drop gate with some c channel. I also built a front box. i can drive my jd870 up the ramp with no problem. ive also carried a medium sized track hoe on occasions. i fitted 2 rotating trailer jacks on the rear end to allow for heavier equipment to be loaded without stressing the trailer ball. ill have to sell this trailer and get a 5th wheel unit to support the weight of my new tractor though. some sort of dove tail unit i suppose.
/ Trailer Needed - 4K Load #4
get brakes on both axles if at all possible. I have never heard anyone complain about too much braking power..
/ Trailer Needed - 4K Load #5
I picked up a 8000 lb car wide car trailer last year, only two years old for 800 bucks off from craigs list, great tires, electric brakes on both axles, it is around 1700 lbs empty, and works great for hauling my Yanmar around, and last fall used it to haul over 7500 lbs of roofing 35 miles from a big box store. I have put stakes on it so I can use it for runs to the dump. Very "multi-use".
Any pics?
Thanks to all for the info, I think I see your point on size vs use and all whell braking.
Will be checking Craig痴 List locally and hoping.
/ Trailer Needed - 4K Load #7
ditto .. get a 16' 7k tandem rated car hauler with whatever # of brake axles your state dictates.. plus a break away kit...
soundguy
2016 Ford Explorer AWD SUV (A61574)
2016 Ford Explorer...
2013 Ford F550 Bucket Truck w/ Jib (A62613)
2013 Ford F550...
2008 Kubota RCK60P 60in. Zero Turn Commercial Mower (A61572)
2008 Kubota RCK60P...
(APPROX. 24) 2X6X12.5 ROUGH SAWN PINE (A64276)
(APPROX. 24)...
New 2200lb All Steel Adjustable Gantry Crane (A62679)
New 2200lb All...
Plastic Drain Pipe (A64119)
Plastic Drain Pipe...
