pipe fence
/ pipe fence #1
tglass
3320 w/cab
Anyone know how to cut the miter between the posts so they are parallel to each other when building a pipe fence ? Using a template one end is fine, but the other end is always a few degrees off or twisted. Hard to get a good weld there. Suggestions?
/ pipe fence #2
Haven't done it yet but this is how I'm planning on dealing with the very problem you're talking about. With the pipe on saw horse's I was going to make a template to make the mark to cut. Also was going to make a short vertical pipe on a stand (template was also going to be on a stand). Once the first cut is made using the vertical pipe to hold the pipe in position mark the other end and cut. Sounds good in theory and we'll see how it works.
/ pipe fence #3
There are a ton of threads on this topic here and on the welding forums, shop floor talk, welding web, Ask Andy (Miller), Hobart, etc.
I don't have any problem with it. What I do is I measure inside to inside posts. I add the notch cut. I use a Vogel (google it) pipe notcher so it's nuts on measurement. Let's say it's one and a quarter of an inch, five eighth's of an inch each end. If you're having trouble keeping the notches parallel then you can cheat by using the seam that is inside the pipe. You can put that mark on your pipe at each end on the outside. That will be the center of your cope, notch, saddle, however they say it where you are.
I like loose fit ups. They will keep your line of fence straighter. I see folks hammering them in because the length is too long and then they wonder why their fence like looks like it has snake itis.
Once again, measure inside to inside at each rail, just in case your posts aren't plumb. Add the notch measurement, let's say your inside measurement is 95", with the notch it will be 96 1/4" if you're using two inch schedule forty pipe. Cut your pipe, find the seam, mark each end at the seam. Do your notching. Your rail should slide freely up and down between the posts. You will need clamps to locate it for tacking. If you don't need to support it for tacking then you're rail is too long and you need to shorten it.
Let's say you find your rail is too short, it happens. The way I always do it is I do the longest spans where I'm working first. That way if I cut one too short, happens, I can either find a span where it fits as is or I only have to trim up one end to find a place where it will fit.
Another trick is to ALWAYS weld vertical up. It's a better weld and it is easier, really, promise. Yesterday I spent two hours repairing a repair made by a welder who ran 7018 down on sixteen gauge fence tube, galvanized, notched and fitted five rails 2 3/8" O.D. I hit his welds with the wire brush on the angle grinder and saw that he had a very bad day that day. It was tough welding sixteen gauge galvanized vertical ups with a stick welder over gaps up to three eighths of an inch in a couple of places.
/ pipe fence #4
Harv do you notice you have less rust because of the direction you weld, that the way it overlapps the weld lets the water run off instead of pooling.
/ pipe fence #5
... Another trick is to ALWAYS weld vertical up. It's a better weld and it is easier, really, promise...
A few years ago( about 23) I worked for a guy that specialized in erecting "miscellaneous" steel. We did a lot of bar joist, decking, and miles of stairs with pipe railings. He insisted on uphill with 7018. One of his part time welders had a lot of tank (water, oil, gasoline, etc) erection experience. He taught me how to weld 7018 downhill. Apparently it's commonly done where less penetration is adequate but sealing is absolutely important. Doubt I could do it today.
Gave myself a chuckle today reading this thread. Was reading the posts without noticing who posted & got to 'welding 16 gauge uphill' and started thinking YA Right -only guy that I know of that would do this is Wrou.... oh ya -OK! :D MikeD74T
/ pipe fence #6
There are templets that you can buy at just about any welding supply that have this already laid out. All you do is make sure the top dead center is the same on both ends when you wrap the templet around the pipe. Mark it and cut. It will be perfect. A pipefitters manual will tell you how to lay these out on the pipe (about $40 at welding supplies and book stores) You can make your own templet by just notching one pipe and grinding till you get it perfectly fitted then make a pattern from gasket material. On thin wall piping, it wouldnt take more than 5 minutes with a grinder to make a saddle on and then you can make the pattern from that so they will all be the same. The ends that match up must be perfectly squared so each time you lay it on the pipe the pattern is the same. After you get your super accurate distance measurement between post, cut the pipe to exact length, mark centerline of top dead center on each end. A level can be used for this if you dont have a pipe centerfinder. Just hold the level on top of the pipe and mark where it touches the pipe. Do this in two spots about 10 or more inches apart then scribe a straight line down the center of the pipe. This is where your templet should meet each time. If you make a pattern for each different size that you make, over time you will have a good pattern for all sizes, or just spend the bucks and buy a set already made. You can adjust the top and bottom notch-back in the pipe to compensate for a slanted post but I wouldnt think anyone would have a post that is slanted enough that it would make a lot of difference in a couple of inches.
/ pipe fence #7
Some great advice that I received ... consider ... We switched from tube posts to square posts. 90% of all rails, or more, only required square cuts versus the saddle cuts required for tube posts. Eliminating saddle cuts reduced the "skilled" labor required for fencing so it was possible to save money and have a great learning experience.
Having never welded ... I did some research on how to weld and bought a couple 120 volt Lincoln 140 HD Mig setups using 0.035 flux core. I hired a couple guys who had one 120 volt Lincoln 100 Mig setup using 0.035 flux core. They helped me put in another 1200 feet of 3 rail fencing, 20 gates, and a couple more horse stalls. Neat experience since only one person had welding experience, and we finished the fencing as nice or nicer than the 2500 feet put in previously by a full-time welding crew. Of course, the previous crew(s) could put a weld down like butter but cost much more per manhour. Still, I think our welds are water tight if not as pretty or fast (fast enough). :D
/ pipe fence #8
How is the pricing of square tubing compared to pipe of the same wall thickness?
/ pipe fence #10
One thing also to consider is that if your were using a 4" round post, you would have the same amount of metal in a 3" square post so you could reduce the size appropriately strength wise.
/ pipe fence #11
In November, square posts cost approximately 30% more than the round posts. I was buying 24' sticks of square and round and cutting them into 8' posts.
Put another way, if each round post requires 3 saddle cuts for 3 rail fencing, then the price increase of square posts to eliminate the the saddle cuts equals about $3 per saddle cut or $9 per post. Additionally, we used 12' rails instead of 8'. I went this route to eliminate enough of the skilled work so that I and the guys I hired could reasonably do the fencing work myself/ourselves as a total beginning welder(s). Plus, total project time is so much faster cutting rails with a chop saw then custom cutting saddles.
/ pipe fence #12
You can use a small piece of angle iron, lay it on your pipe and mark a straight line. Clamp your pipe in a pipe vice or regular vice, use a centering head with a tri-square, (when bubble in vial is center) to make sure the line is right at 12:00 O'clock then place your coping pattern / template accordingly. Or you can use a Flange Wizard centering head with center punch to find 12:00 O'clock on the pipe.
/ pipe fence #13
Here is a better picture, (well not of quality:mad:) of how I was trying to explain how to use a centering head with a tri square.
/ pipe fence
Exactly what I'm looking for. Where can I get one??
/ pipe fence
/ pipe fence #17
According to some thermal expansion figures, a 40 degree increase in temperature will lengthen the rails on a one mile pipe fence about 16 inches. Is there a common method in the pipe fence industry to compensate for expansion and contraction so the rail doesn't snake.
/ pipe fence #18
I never use expansion joints. Mostly because we have expansive clay soils around here. The expansion of the rails isn't the reason the fences move. The soils move houses and swimming pools, buckle roads, and generally can't be trusted.
I have four lines about 11 hundred feet I see almost every day. Their movement is vertical and that is all about the clay. I have one in sandy soil that has a couple of five hundred foot lines that are almost ten years old and are still nuts on. I've built them a half mile long in southern California and never had a problem.
Most of the snakey fences I know of, they kinda catch my eye, are because they were made by welders instead of fencemen.
2004 Suzuki GSX-R750 Motorcycle (A64557)
2004 Suzuki...
2015 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A67148)
2015 FREIGHTLINER...
2018 HARPER ATM 72LC MOWER (A66091)
2018 HARPER ATM...
2018 GEHL RS5-19 GEN3 TELESCOPIC FORKLIFT (A65053)
2018 GEHL RS5-19...
2014 Dodge Charger Sedan (A64557)
2014 Dodge Charger...
2012 FORD FOCUS SEL (A65054)
2012 FORD FOCUS...
