Wheelchair bound
/ Wheelchair bound #1
plousehouse
Hello
I am confined to a wheelchair. I am looking for a tractor that would allow me to stay in wheelchair while operating.
Any help would be appreciated
Thanks
/ Wheelchair bound #3
On youtube I spotted a vid/pic about 2 brothers that had a medical condition and they had a remote joystick control tractor that they sat in. They were in a wheelchair with only a limited wrist movement. I have seen some rough terrain 6 wheel drive vehicles that you drive the wheel chair up onto and strap the wheel chair down. This machine was gas powered and would go anywhere.
On the machine usage what would you like to do with the tractor?
How did you plan on using the tractor ie lift platform from behind ?
When you are out on the property are you going to be carrying a cell phone just in case.
As you can see I have thought about this because I had a one point both of my parents in wheel chairs.
Craig Clayton
/ Wheelchair bound #4
/ Wheelchair bound
Thanks for responding I will entertain any options. I have resources to MFG ideas if applicable. I'm a quad in an electric wheelchair looking to hobby farm 20+acres. I want to be able to mow, lift cut and till.
Thanks again, I'll look at all options. And yes cell phone is on me @ all times
/ Wheelchair bound #6
Hello
Thanks
Maybe you could give us a little more info, what type of work you'll need it for, type of terrain, etc....?
Another thought might be a skid steer with hand controls, possibly a JCB with side door entrance? Skid steer's have just as many attachments as tractors.
/ Wheelchair bound
I contacted them yesterday and here's his response..
Thanks for contacting Ventrac. Unfortunately, as the article mentions, this model (the Ventrac 2320) is no longer produced. It痴 possible that there may be used ones out there, but I am not aware of anything at the moment.
Are you looking specifically for a tractor that can be operated from a wheelchair? If not, we currently make the Ventrac 4000 series tractor equipped with power steering and easy hand controls (tractor is completely hand operated). I致e heard of higher functioning people who operate the Ventrac 4000 series that are able to transfer from their wheel chair into the tractor seat.
We also sell the Freedom 300 which isn稚 a tractor (more of a transport system), but allows wheelchair users to stay in their chair and buzz around their property:
Ventrac Freedom Model 300
Let me know if I can help answer any more questions.
Denver Steiner
Graphic Designer & Web Developer
VENTRAC by Venture Products Inc.
330-683-0075 x225
denver@ventrac.com
/ Wheelchair bound #9
My dad had polio and could not walk. I grew up on 24 acres, and he did a lot of mowing on the meadows there. He had Wheel Horse tractors from 5 to 18 HP, and then a GE ElectTrac.
All the tractors were modified by a local company, which interestingly enough was run by another gentleman that had polio and was wheel chair bound. That let him focus on good solutions. Translating that experience into something you can use today, I'd say that you want to find someone to modify tractors that has done it before.
This is the only picture I have of him on a tractor. You can see the straps added to keep his legs in. On the tractor's left, you can see a rod added that went down to the break pedal. On this tractor, as well as some of the others, the speed control was on the dash, much like my current JD 318. More and more, hydros use pedals. If you can get a tractor with electronic hydro control (Deere calls it "e-hydro") then it's a "plow by wire" tractor and the controls foot controls might be adaptable to something on the side of the dash.
Terrain will play a big role in what you do. How you keep your body "under control" when the tractor moves around is all part of the adaptation puzzle. Not sure what you mean by "being a quad", but if that means no arm control then the adaptation problem changes greatly. In your favor though, the world is geared up to adapt better than it was 50 years ago.
Only the 1st tractor we had was a gear, the rest were hydro. There is no doubt in my mind you want a hydrostatic transmission.
About age 65 it was to hard on his shoulders to swing himself up from the chair to the tractor. There were various solutions to this that were possible, such as a beam type lift or harness lift. I've always wondered how things might have been if he had adopted those tools earlier on. Would he have had more time because his shoulders didn't wear out as fast? Anyway, key concept here is work on some way to assist yourself getting on the tractor even if you can swing it now.
Finally, you have not mentioned other aspects of your life, so let me toss this out. I had a blast as a kid going around with my Dad doing things outdoors. It was a great match-up. When all us kids left home, the place was in pretty good shape and all he did was mow. So don't forget to factor in what sort of help you'll have. The right assistant for some jobs won't be a burden, and the experience can be good for all. Once the land is in good shape, you can mow alone and enjoy that experience.
Also, once my dad stopped using the tractor, he got a beefed up wheel chair that would still let him drive around the property. He paid others to cut the property. This was a nice way to transition out of driving a tractor. So keep the future in mind when working your land.
So by all means try to have someone adapt a tractor to your needs. Scale your needs so they are within your limits. Hopefully there are others who can accompany you on occasions as you tackle projects. And try to "terra form" your land so you can still enjoy it down the road when tractoring might not work. I don't know the specifics of your situation, but I assure know I know the determination you have.
Pete
/ Wheelchair bound
Thanks again for the response and information. I am an quadriplegic paralyzed from mid-shoulder down with arm function and strength but my hands are impaired. I would like to stay in the chair if possible, otherwise I would need to transfer into a Wheelchair seat on the tractor and make adaptations to all the hand controls w/a hydro-static drive.
Here's a link that's been done, but on a bigger scale
Farmer Designs a Wheelchair Accessible Tractor | Wheelchair Accessibility Blog and Disability News
/ Wheelchair bound #11
I just spent a few minutes on youtube and I found many vids about wheelchairs and tractors , but most do a transfer and the men appear to have full upper body strength.
I have not found the one about the brothers who built a RC tractor because of severe medical limations.
Craig Clayton
/ Wheelchair bound #13
I do not know of a tractor with that kind of access. I know there have been discussion here before, about adapting a tractor, but the person had more mobility. That was 5 or more years ago though. You might use the search on this site.
My NH TC40 is HST, and hydraulic steering. It would not be hard to set that up on a joystick; all the skidsteer companies already do that. It would cost $$$, but could be done.
I can not see it done without a lift to transfer from the wheelchair to the tractor though, like the one my Grandmother uses to get from wheelchair to pool at aqua-therapy. The one at the pool is more of a small crane/boom; we have to put a net in her chair, and chain that to the boom.
A skidsteer(or compact track loader) would be great, because it is already set up with controls. But, most would be impossible to get in/out of, even with a lift.
What you want is certianly possible, but I fear it would be prohibitively expensive.
/ Wheelchair bound #16
You did not say where you are from but Texas also has a Agr-Ability grant program to modify farm equipment for handicap users.
/ Wheelchair bound #18
You might post this question in the "owning/operating" or "customization" forums.
As I mentioned above, it is totally possible. Many skidsteer/compact-trac-loaders are completely joystick driven. I have used a couple; they worked great.
It surely could be adapted to a utility tractor.
2005 KENWORTH T800 OPEN ROLL OFF (A60736)
2005 KENWORTH T800...
2025 Unused SDLGC80 60v Electric Golf Cart (A60352)
2025 Unused...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
SKIDDED FRAC TANK (A60736)
SKIDDED FRAC TANK...
2014 Lincoln MKS Sedan (A61569)
2014 Lincoln MKS...
JOHN DEERE ROW MARKERS - SET OF STACK FOLD 12 ROW 30 INCH ROW MARKERS (A55315)
JOHN DEERE ROW...
