Snow Attachments V plow for tractor
/ V plow for tractor #1
bc realtor
Vancouver Island BC
Antonio Carrero TTR4400
:dance1:Was hoping that someone in the membership would know of a v plow that would fit for my compact tractor. I have a TTr 4400 Antonio Carraro. I currently have a 3 pt straight plow with a rubber bottom that works great. I did meet the upper end of it capabilities the other day with over 2 feet of the heaviest wetest snow ever. I would slide to the side while doing the sidewalks. I was thinking That a V plow would keep the tractor centred and moving forward. The width I would need at a v would be around 52 inches. Open width would not be an issue.
Any thoughts or do I have another build project for the summer?
Buy the way I have about 20 miles of sidewalk to cover.
Thanks in Advance for any ideas or leads.
/ V plow for tractor #2
twenty miles of sidewalk to cover ! wow.Do you work for the city or is your property that big
I do Some plowing for the locals but the issue is we have no municipal sidewalk equipment , Also we have some nice kids in power wheelchairs. So I do the nice guy thing and make it easier for these kids and others to get around.
/ V plow for tractor #4
I have watched the Holder brand of machines with V plows tackle sidewalks in Toronto. They seem not to be using that idea much any more. A front straight plow that is adjustable.
Craig Clayton
Just gave holder a call and they have a used one . They are going to get back to me with the details and price.:thumbsup:
/ V plow for tractor #6
something like this?
or just buy a stock one
/ V plow for tractor #7
Boss makes V plows for quite a bit of stuff. You may have to make your own mount.
/ V plow for tractor #9
I just bought a Trackless one at an auction sale for $150. Gonna cut it apart and weld skid steer brackets on it to use with my kubota.
/ V plow for tractor #10
I would love a retrofit kit to take a fisher or boss v plow and run it on my b20. Cutting through deep snow with the v would be great. Scooping wind rows would be great too!
/ V plow for tractor #11
Kubota has offered a 72" V for the RTV which might help for some work.
/ V plow for tractor #14
I have a 5 foot scraper blade on the back of my Ferguson, but I've always thought a V plow on the front, mounted to my front end loader, might work well in deep snow. I've even considered making one out of plywood, although I suppose getting the curled contour right is important. I can recall the deepest snow we've had around here was back in the late 1970s, when it was drifted up to my chest out in the road. The county finally came through with a V plow on the lead dump truck, pushed by another straight plow dump truck from the rear.
/ V plow for tractor #15
You might try making your own like this one. Using 3/4 " marine plywood , oak, treated lumber, and steel this will open an 11 ft wide path in one pass. I am using a 35 hp Century 4wd tractor. So far the deepest snow I have tried is 8 ". But I feel certain I can move double that with the V angle at 45 degrees. Cost is about $200. In this part of Va. we do not get too many deep snows. It is no problem to reduce the width to 8' which would allow some serious depth to be moved. Hardest part is to make a mount that fits your particualr front end loader. Willie Jones
/ V plow for tractor #16
I haven't seen a fixed V-blade used over here in the last 25 years at least, interesting that someone still makes them.
Compared to what I'm used to, and there are thousands of them here for municipal streets and sidewalks, the Kanlan model looks good.
One of the swedish manufacturers is also in the US market, but it will be expensive, and probably too wide. It's a very nice construction though:
Holms inc Usa - Holms PV, adjustable V-plow "three in one"
/Marcus
/ V plow for tractor #17
Interesting machine! No doubt an adjustable V-plow would be a great upgrade for you. There are only advantages over a diagonals (except maybe price).
- It allows you to operate in much heavier snow because when folded it provides less friction by reducing the distance the snow needs to travel sideways in half, as well as keeping the tractor centered.
You will not be pushed sideways, wheel friction will be your limiting factor. Do You have chains?
- I provides the abilty to work just like a diagonal blade when needed, but also the very useful scoop configuration to push snow off the road or into a pile without spilling to the sides.
I found this example with your machine:
YouTube - Snow removal with the Antonio Carraro TTR 4400 HST tractor
The Ventracs are similar:
YouTube - Ventrac7's Channel
You are looking for 52" which is 130cm and a quite common size, shouldn't be a problem.
At least over here there are many mfg with such plows. My favourite:
Vikplog LVP 130-140
I used to run a P.Olsson plow on a Kubota 8200. See how close to the front of the tractor it fits.
/Marcus
/ V plow for tractor #18
Willie Jones- That's a nice V plow you made, and it looks like it moves some serious snow ! It's about what I envisioned making for my tractor.
/ V plow for tractor #19
............I used to run a P.Olsson plow on a Kubota 8200. See how close to the front of the tractor it fits.
/Marcus
Marcus
I like the looks and the fit of that V plow.
Would like to see some vidio of that plow working some serious snow. But alas, you say you used to run it and apparently don't anymore. :(
/ V plow for tractor #20
Thanks William, I suspect if we get one of the really deep >16" snows that show up here in central Virginia every 10 years or so I may find I have to reduce the width. Would like to see, but most folks around here do not share my enthusiasim for such a snow! Those adjustable V plows do look nice. Willie Jones
2013 Ford Escape SUV (A61574)
2013 Ford Escape...
Caterpillar 963C/953C Track Loader Service Manuals (A63117)
Caterpillar...
2016 FORD EXPEDITION SUV (A59912)
2016 FORD...
1986 INTERNATIONAL 1900 FLATBED TRUCK (A63291)
1986 INTERNATIONAL...
Lincoln Electric Shield-Arc SAE-400 DC Welder - Engine Driven - Radiator Missing (A63689)
Lincoln Electric...
2002 Vermeer SC252 Walk-Behind Stump Grinder (A61572)
2002 Vermeer SC252...
