MF35 Trans/Hydraulic Fluid
/ MF35 Trans/Hydraulic Fluid #1
BoostedOne
Osteen, Fl
1960 MF 35 diesel
Hey yall,
Just picked up my first tractor the other night, a 1960 MF35 with the perkins diesel. Runs like a swiss watch.
However the trans case fluid is white-grey, meaning its got water in it. Im assuming the water got in through the shift boots, which I replaced today(and zip tied em tight to the shifter). Are there other points of entry I should look at as well on an otherwise clean tractor? One thing I didnt notice before I got it that is concerning me is I dont see a boot on the top cylinder?
Next, just what kind of fluid do I use in this thing?? The fill cap says 30wt in the summer, and 90 in the winter. Im in Florida, and Im guessing I would go with the lighter stuff, however can't figure out which of the fluids to run. I searched and saw mineral oils, and something called Permatrans. Is Permatrans for modern tractors or my old one?
Or do I just use the standard trans/hyd fluid from tractor supply?
Thanks!
/ MF35 Trans/Hydraulic Fluid #2
I have a 1955 Ferguson TO-35, which is quite similar to your MF35 model. Mine is gasoline powered. I also recently changed the transmission/ hyd. system fluid to remove quite a bit of water . Be sure to drain the fluid from both the front and back drain plugs, as a lot of watery fluid will remain in either sump if you don't. I also replaced the shift lever boots. If you're referring to the cylinder at the top link of the 3 point hitch, mine does have a rubber boot . Also be sure you have a gasket under the large fluid fill plug next to the shift levers. I too was wondering if all the possible water leak points had been accounted for, such as down the steering shaft. I decided to start keeping the entire tractor covered with a tarp . When plowing snow, or caught out in the rain, some water may still find it's way in , but hopefully not much. I found too much water in the transmission was causing the 3 point lift to stick in the up position in feeezing weather, and changing the fluid solved that problem. I changed the trans. fluid by draining at both drain plugs, adding 2 gallons of fluid and running the tractor for 5 minutes , while running the 3 point lift up and down several times, and also putting the pto drive in gear. I did that procedure 3 times, draining the fluid each time, before adding the entire 32 quarts of fluid. I've been using universal trans/hyd. fluid in the tractor for 35 years now, so I suppose it works ok.
Thank ya much William.
At this point Im pretty comfortable with the universal trans/hyd fluid idea. I mean in 1960 they were only so advanced when it came to lubricants anyhow. But when i started searching around to find out just what to put in it I was suprised to see so many variations in answers.
I dont have to worry about snow, but rain down here is an issue. This spring i will probably build a carport for the tractor and the implements to keep them out of the bad weather since I enclosed and slabbed the pole barn and turned it into my shop.
So yeah, I will look to drain BOTH plugs(at first I just noticed one, so thanks!) and I will make sure something is under the fill plug. Is that boot for the top cylinder of the 3 point a leakage point? I did some searches on the tractor websites yesterday between doing work and most of them are laid out in such a mess I hadn't found one yet.
When you're doing your fill process and running the hydrualics up and down, do you have something on the hitch to weigh it down at all?
/ MF35 Trans/Hydraulic Fluid #4
Boosted- I do assume that the boot at the top link piston , which is part of Harry Ferguson's draft control system, is a potential water leakage point. The boot on mine looks old and cracked, and , like the steering shaft leakage points, is best handled by coverering it all with a full tractor tarp. Some places have rubber seals, however, to keep dirt out , and lubrication in, as the tractor is being used, and deserve replacement even if rain water is kept out. Take care of the big and obvious ones first, and work your way to the others later. I've gotten to the point on my tractor where is sounds like the old joke: gee, if I'd known it would have lasted this long, I would have taken better care of it ! Nowdays, I am indeed taking better care of my tractor. As for running the 3 point hitch up and down when changing the fluid, you don't need a load on the hitch. My reasoning was that if the upper lift arms ( rock shafts) are pivoting, then the fresh fluid is flushing into and out of the cylinders and metering bodies that move the lift arms, and removing more watery fluid with each flush. The strategy seems to have worked.
/ MF35 Trans/Hydraulic Fluid #5
Flushing is a great idea, and if possible wiping out the bottom of the case through the side cover will also help to determine if you have any other sort of contaminants in the case. The last time I did mine I noticed a sludge build-up, which I discovered was in fact excess grease from the grease points on the lift arms. When I changed the filter it was all but blocked off due to the grease, am much more careful now not to use the "grease until you see it come out from the circumference of the bearing" philosophy we were all taught to abide, a little is better than too much in this case and may save a pump in the long run.
I was actually planning on putting some diesel in there to thin out some of the slop in the sumps before filling with hyd fluid, but you bring up a good point.. Does the 35 even have a filter? If it does, where would I find it?
Yeah, the boot I was referring to is on the top cylinder. I did manage to find one online at yesterdays tractor I think. Started filling a shopping cart yesterday, but stopped short of ordering. Between a new back tire(and still need one more), the fluid, buying the tractor last week, a bush hog over the weekend, etc I need to keep the spending under control. I had tie rods, spindle bushings, fuel tank shut off, and various other knick nacks on the list.
I do want to take care of this thing. I'm not restoring it for shows, but figure if I fix it up nice and take care of it, it should take care of me. Its apparantly been taking care of people for 50 years already
/ MF35 Trans/Hydraulic Fluid #7
http://www.tractorbynet.com/forums/...g/196721-wire-tie-mf135-hydraulic-filter.html
There is a hydraulic filter in my 68 135, the attached thread will give you an indication where it is, you need to take the side cover (PTO engagement lever) off to get at it, the filter is right there. There should be a piece of lockwire preventing the cap from backing off, aside from that, you may need to loosen it with a pair of pliers and the rest is by hand (filter should come with a new o-ring, try to be careful not to spill too much contaminated oil into the pump during removal).
Filter is inexpensive and readily available, should change it if you can, especially if your fluid was contaminated. :thumbsup:
Thanks for the pics!
Hopefully I will get a chance to play a little tonight. Was planning to do it yesterday but the woman wanted to go out to dinner, and since she did such a great job cleanin house I obliged. By the time we got back the week caught up to me and I was in bed by 8:30, lol..
I need to replace a back tire first though. The previous owner has an old and too skinny tire on one of the back rims and it keeps popping off the bead. Tuesday night I fired it up to bring it in the shop, and apparantly managed to puncture the tube so now I HAVE to take care of that before the gear box.
Not really looking forward to it since I also have some other work than just replacing the tire.. I'm guessing the previous owner must have gotten the rim from another tractor, because it only has 4 tabs instead of 6. Since only two tabs on the rim match the hub, they welded down the other 4 locations.. That really doesnt bother me that much, but the kicker is they must have had a brain fart when they did it because they welded the disc on backwards(so the valve stem is on the inside), AND they welded the disc to the wrong danged side of the tab so it sits waaay too far inboard...
So once I get the old tire off, I gotta cut these welds out somehow, then either fab some rim tabs or weld it back down..
/ MF35 Trans/Hydraulic Fluid #9
Don't ya love it, always something to do. Shouldn't be too bad though with the rim off, good chance to clean it up have a good look at everything. :thumbsup:
/ MF35 Trans/Hydraulic Fluid #10
You do have several choices on how to mount the rims, to alter your rear track width to suit your needs and provide tire clearance . With stock rims, there's no one " right" way to mount them. My TO-35 actually provides 8 different rear track widths from 48 to 76 inches, and that's without the optional power adjusted rims. Perhaps you noticed because one side is mounted differently from the other. Take a good look at them, and you'll realize the possibilities. Not only can the outer rim be reversed, but the spider can be reversed on the axle studs. I wound up with the valve stem on one rim on the inside, and one on the outside. It seems to just be the difference between an old rim and a new replacement rim. Owners also frequently buy different width rims for each side, which is poor form, in my opinion. They also wind up mounting one rim farther out, or in, than the other side. Again, poor form. However, welding a four tab rim onto a six tab spider is worse than poor form ! Replacement rims are about $145 delivered for my TO-35 , so getting the right rim won't break the bank. Measure the rim width from one tire bead sealing surface to the other, and not the overall width which includes the little flange. Buy your rim width to suit the tire you plan to use. Stay away from calcium chloride if you fill your tires for weight, as it will eventually leak out and rust your rim badly. I learned that lesson twice. When I replaced both of my rear rims, I removed the 6 rim nuts that connect the outer rim to the inner spider with an impact wrench after soaking the threads with penetrant. I replaced the 6 rim bolts and nuts with hot dipped galvanized carriage bolts and nuts and lock washers from Lowes. Mine were 5/8 inch diameter. The carriage bolt heads, with their square shank section under the rounded head, were a perfect match for the loops on the rim. Trying to reuse the original rusted bolts and nuts was not worth the effort. Good luck with your tractor, and keep us informed as to your progress !
I wasnt there when the previous owner did what they did so I have no idea what they were thinking, LOL...
I got the tire off the rim last night... What a butt kicking experience that was hahah... I was wore out. I took the core out of the tube and ran over the tire with my dually to bust the bead loose. Was easy since once side was already off.. I then tried to work the second bead off first with a big pry bar, and finally worked it off using a wedgie for the porta power.
After that I cut the welds for two of the tabs to reweld them in the right spot, and then I was going to fab two more tabs... Now I dont know. I measured the rim to be like a 9" rim if I remember right(inside of bead to inside of bead), so the 10" tire shouldnt have been blowing off unless it was damaged. I notice that the rim does have a spot where the bead is bent a little outward so maybe thats the problem, but other than not wanting to part with the money for a new rim shell I cant think of too many reasons to try to salvage this one anymore..
Here is a pic of one side(with the little one posing)
And a crappy angle of the otherside. I dont know why anyone would set it up quite like this on purpose.. I have an inlinking that the guy got a used tire on a 4 tab shell, and just had a brain fart when he decided to weld on the hub when he welded it on the wrong side..
Well, I guess as an update its getting a new rim..
The local dealer just called me back and is sending me new fuel filters, oil filters, and a hydraulic filter(incase I find one). Told him to throw on a new rim shell to the order while I was at it....
/ MF35 Trans/Hydraulic Fluid #12
You will love the beast, always ready for work and fun.
/ MF35 Trans/Hydraulic Fluid #13
I'm working on getting my 1962 MF 35 back in working order. The lift had weakened to the point it wouldn't pick up the scaper I was using to move dirt around. I learned contaminated hydraulic fluid could be the problem, and sure enough, when I drained the fluid, it appeared as milky water. I read previously about checking the filter just inside the PTO lever plate. Another forum said the filter would be "wire mesh"...this one looked like more than just wire, what was left of it anyway. I was expecting "wire" and to just wash it out and reinstall it...no such luck. The filter is deteriated and needs replacement; and of course by the time I learned this, the parts store was closed. I don't know what filter to get though. I've searched through the internet, and can't get a real, no kidding part number. I live in a small town, and a 1962 tractor really isn't something the folks at the parts store are familiar with. Anyone know what filter I need? Also, on the left side of the engine, there are 3 filters. Anyone know of a diagram I can reference to learn which filter does "what". The tractor was my Father's who passed away recently, and I'm trying to keep his toy up and running smoothly, however, I am more accustomed to working C-130 Gunships than tractors. Any assistance will be greatly appreciated.
/ MF35 Trans/Hydraulic Fluid #14
You need to start a new fresh thread (post) so we don't get confused with the one your currently attached to. There are plenty of experts in here that can guide you to what you need to do. There is a database online that shows parts number that AGCO dealer use. Go here AGCO Parts Books and use the GUEST login. Put your model and make in and find the 35 Tractor folder. You must have microsoft Silverlight to view the graphics. Silverlight is Microsofts custom PDF viewer. Find the page and print it out. It will printout a nice page with exploded view along with part numbers you can reference when calling about replacement parts. That website has saved me alot of grief many times. :thumbsup: BTW Welcome to TBN.. Lots of friendly folk in here.
/ MF35 Trans/Hydraulic Fluid #15
Thanks for the information. Hopefully I'll have her up and running by Sun down.
Enjoy the UGA-TN Game tomorrow, ;-)
/ MF35 Trans/Hydraulic Fluid #16
G,Day Boosted.
The 35 did not have a hydraulic filter when sold new but you could buy an upgrade filter kit which required a bit of drilling to fit,it is the same filter set up as the early 135 tractors with the Mark Two pump.
Regards.
Hutch.
