Soldering vertical copper pipe
/ Soldering vertical copper pipe #11
The key to soldering is heat...liquid solder will draw to the heat...as others have said...
don't try to melt the solder with the torch, allow the metal on the opposite side of the torch to get hot enough to met the solder and it only takes a small amount of solder.
When replacing sections...sometimes it is easiest to take a small file/blade and remove the "stops" inside of a copper coupling...this allows you to slide the couplings above and below the cuts...then cut your section in, flux everything and slide the couplings so they center on the joints...then solder
Couplings are sold with no "stops". Ask for a repair coupling.
/ Soldering vertical copper pipe #12
bcarwell- Do you have any "end-play" at all? These (relatively new) "Shark-Bite" couplings are the cat's-butt, for repairs like this! No soldering, and removable, and reuseable! Pricey? Yes, but well worth the money if you can get them to work, with your application. Available at Lowe's, Home Depot etc. I'll try to find a link......~Scotty
Here ya go: http://www.sharkbiteplumbing.com/?gclid=CMDCgpeYgacCFQJN4Aod1TCieg
/ Soldering vertical copper pipe #13
I'm aware of this and I started to mention them...but many that read this thread will not be able to find them at the box stores and many local hardware stores...
FWIW...the couplings that only have a couple of little bumbs...a good pocket knife will shave the bump right off...
/ Soldering vertical copper pipe #14
You can get " non- stop couplers" at the plumbing supply store. They come without the stop nib and you don't have to file anything off.
You can also get a "repair pipe" where the entire piece (12") is sized to fit over the original pipe. These are designed for fast repair of frozen pipes.
kidr, I solder a lot of pipe. The best advice I have is to upgrade to a Mapp gas torch, (they use the yellow tanks sold right next to the blue ones). It is much hotter than propane, and that makes it easier, and faster.
Watch for the flame color to change to green, when that happens, time to apply the solder, and then get off of it.
Use the "tinning flux", and if your solder is old, it does not work well. Buy some new solder, and compare, you will be surprised at the difference.
/ Soldering vertical copper pipe #15
Apply heat to the fitting. Not the pipe itself. It's really no big deal.
/ Soldering vertical copper pipe #16
I think the question you are asking that is not getting answered is the order in which you work joints. Heat rises. You want to start with the bottom-most joint, and work upwards. If you go the other way, the heat rising up from working the lower joints can make the solder in the upper joint melt and drip out. If the joints are close together like a coupler, you still need to be careful not to overheat it or you can still run into problems.
Repair couplers without the internal bump/stop are readily available at the big box stores too, if that is what you need.
/ Soldering vertical copper pipe #17
...Heat rises...
This is a common misconception...heat does not rise...heat moves from hot to cold.
Hot air (and most other gasses) rise...
when soldering copper the solder will always flow toward the direction the heat is being applied...up or down it doesn't matter...
/ Soldering vertical copper pipe #18
Technically, sure. Or if you like, cold moves from cold to hot :) But there are always multiple modes of heat transfer going on...including convection. Try going from top to bottom and bottom to top on order of soldering the joints and see which works better...BTDT
/ Soldering vertical copper pipe #19
I have a vertical 3/4" copper pipe I just cut a section out of which froze and cracked. Now I'm replacing it with a new piece of pipe and two standard slip joints- one on either end. My question is how do you sweat solder when the joints are vertical ? I know how to solder and I know about capillary action sucking in the solder even vertically, and that you make the part hottest in the direction you want the solder to flow. But: once you've soldered in one side of the slip joint when soldering the other side won't it heat up the side you just soldered to cause the solder to flow out ? What order should I solder the joints in or does it matter ? Should I first solder on the slip joints onto the piece of replacement pipe at my workbench so I only have two joints left to solder when I put the replacement pipe in place ? Still seems like in doing so I'd be heating other side of the slip joint that I had soldered at my bench. And how long should the spliced-in piece of pipe be or does it matter ? Just a few inches long to replace all the bulged pipe where the crack was ?
Thanks for any tips (or reassurances if it will work just fine)...
Bob
Bob, seems per your post, you already have repair couplings, at least that"s what I read into it.
Since as you stated, you have soldered before knowing about preperation, 90% of success in my opinion, just apply the heat holding to hot part of flame at center of coupling.
Then when temp is ready apply solder at top joint and then apply to bottom joint, go all the way around the joint, also for a clean looking joint, have a wet rag to wipe the excess solder that runs down the pipe.
Also a note to those who say to file the stop out of the coupling, these days the stop is made by stamping the o.d. of the coupling forcing the material to form a ridge on the i.d. of same, filing this ridge diminishes the wall thickness at this point, possibly future leak as this creates a weak spot.
/ Soldering vertical copper pipe #20
Another interesting point, thank you.
2017 Ford Transit 350 Passenger Van (A59230)
2017 Ford Transit...
2007 Volvo VNL Truck Tractor (A61307)
2007 Volvo VNL...
WHISPERWATT 220 DIESEL POWERED GENERATOR (A58214)
WHISPERWATT 220...
2019 Freightliner B2 School Bus (A59230)
2019 Freightliner...
2016 Case CX55B Midi Excavator (A60352)
2016 Case CX55B...
iDrive TDS-2010H...
