3-Point Hitch John Deere 855 3 pt hitch
/ John Deere 855 3 pt hitch #21
My 855 has the JD style turnbuckles.
Had to choke them up to minimum length to take the sway out of Cat 1
(26" wide) attachments and draw bar.
You won't get all the sway out. You have to have enough play to be able to hook up and unhook implements.
The attaching points on the Yanmar arms may not be at the same point on the arms made for JD. You may need custom restraints. (chains)
Center the attachment behind the tractor. Measure distance center to center of attaching bolts. Make it even on both sides. Cut chain length and attaching hardware as close to this length as you can.
Good luck
Wyo
You could drill another hole in the 3pt arms a little further back and attach the chains there. That would give you the ability to pull the chains a little tighter.
/ John Deere 855 3 pt hitch #22
The sway chains don't seem to dampen the sway.
Those chains have to be tight - yours are completely slack, so they don't do anything. I have threaded rods with turnbuckles in that position, so they can be tightened down solid. That is an ineffective system design unless there is some kind of macro-adjustment possible.
JayC
Thanks for the picture of the JD sway chain and measurements. I think I'll measure out the distance for the Yan Mar links. If it looks like the JD chains will fit, I'll probably breakdown and pay the $160 for the pair.
/ John Deere 855 3 pt hitch #24
Put the horse shoe clevis in the link closest to the turnbuckle. That should get you where you need to be. Save the $ 160.00 for something else. :thumbsup:
/ John Deere 855 3 pt hitch #25
bob
Hopefully only as a last resort. Seems from your pics you could make what you have work just fine.
Please post a pic of your sway chain with ruler similar to the pic posted of the Deere chain. Sure would like to see you make the Yanmar work and save the $160. :)
2018 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A64194)
2018 Freightliner...
1995 Ford LT9000 Tri-Axle Dump Truck (A64556)
1995 Ford LT9000...
2007 TORO 3300-D CART (A66091)
2007 TORO 3300-D...
LOT OF SCRAP IRON AROUND CEDAR TREE (A63291)
LOT OF SCRAP IRON...
2016 SMITHCO SMQ-45-001 SAND STAR (A66091)
2016 SMITHCO...
2022 EZ-GO ELITE...
