PTO Chain?
/ PTO Chain? #1
CANdiyMXER
Member
MX5000
What is the purpose of the small chain on a PTO, is it simply to keep the PTO from separating?
/ PTO Chain? #2
Hook the chain onto the tractor or implement. It keeps the plastic PTO shield from spinning with the shaft.
/ PTO Chain? #3
Yes, its supposed to stop the PTO cover from rotating. In my experience it just breaks loose, and scratches the paint off of everything it can reach. I now just remove them and accept the associated safety hazards.
/ PTO Chain? #4
[which are approximately none]
/ PTO Chain? #5
Interesting... I have not had any troubles with my PTO chains. Use them every time.
/ PTO Chain? #6
just grease both niple at the end of the shield and you wont break the plastic bearing who hold the chain
/ PTO Chain? #8
thanks for the orginal question. I thought that's what they were for, but was not sure. One attachement i purchased was made to use the stay chains, but the dealer did not have them on when it was sold/delivered. I've since added them.
/ PTO Chain? #9
So far, I've only had my RC for one season, but the PTO shaft cover spins very freely. I can't imagine how the chain would break. (It hasn't.) Perhaps if it starts filling with some sort of matter (grass clippings, dirt) over the years, it might start getting stiff and impede the rotational efficiency. I would imagine keeping it clean would be a big factor in its continued operational status.
Joe
/ PTO Chain? #10
mjym Re: PTO Chain?
This is stated correctly. If you grease the sheild zerks it will allow plastic parts to rotate easly and the light chains will not break under normal conditions.
/ PTO Chain?
Thanks all for the info, appreciate it!
/ PTO Chain? #12
When I first started using PTO powered equipment the shield was metal and rather smooth with a bell on each end. Shield spun with the shaft, seemed like a good system to me (also easier to grease) Then they went to plastic shields that spun, now apparently that is too dangerous so they have to make a plastic shield that doesn't spin with the chains attached. I just use the chain as something to hold the PTO shaft up when I park the implement, I never connect it to the shield when in use.
/ PTO Chain? #14
Seatbelt on, ROPS up and all safety guards properly installed. This is the only way to operate.
Oh dear ... Ill just stay inside where its safe.
larry
Mini Skid Steer Mount Plate, 5/16" Thickness (A62679)
Mini Skid Steer...
2020 KUBOTA SVL75-2 TRACK LOADER (A59914)
2020 KUBOTA...
New, Landhonor Skid Steer Pallet Fork  (A62679)
New, Landhonor...
New/Unused Wolverine Mini Quick Attach Pallet Forks (A65583)
New/Unused...
New/Unused CFG Industrial MH12RX Mini Excavator (A65579)
New/Unused CFG...
2022 EZ-GO ELITE...
