L3830 rear hydraulics
/ L3830 rear hydraulics #1
KBL3830
Member
Kubota L3830 HST
I am adding rear remotes to my L3830, I have most of the components already, just need to start thinking about hoses and tubes. Anybody know what size the output port on the rear hydraulic block is?? I know, I know I can take the seat platform off and look at it, just feeling lazy right now and my garage is full of a partially dismantled 40 year old Case 580CK.
Thanks
/ L3830 rear hydraulics #2
If you are going to use hose connections you will have to take it off the loader connection under the right foot rest, just a bypass plate under the seat where the factory block bolts on. To use that location you will need the kit from Kubota or machine up a block to connect to.
David Kb7uns
Thanks, I'm sure I can machine a block but forewarned is forearmed. Good to know what I'm getting into.
/ L3830 rear hydraulics #4
If you are using your own valve it would be easier to just intercept the power beyond coming from the loader going to the rear hydraulics and you can T into the tank return, they did this with the backhoe I have mounted up.
David Kb7uns
/ L3830 rear hydraulics #5
David Kb7uns
Pretty much exactly what I did with the 3400.
Sean
Sounds good, thanks to all for your input, I'll post pictures when it gets own and dirty. Still have to get a new clutch into the Case BHFEL before I can start a new project.
2013 Chevrolet Tahoe SUV (A64194)
2013 Chevrolet...
NEW IDEA 323 - 1R CORN PICKER (A64277)
NEW IDEA 323 - 1R...
New 5400LB, Rachet Binders and G70 Chains (A62679)
New 5400LB, Rachet...
LOT OF SCRAP IRON AROUND CEDAR TREE (A63291)
LOT OF SCRAP IRON...
Mccormick Farmall Cub Tractor (A65579)
Mccormick Farmall...
New/Unused CFG Industrial H15R Mini Excavator (A65583)
New/Unused CFG...
