Box Scraper Reversible Blade for JD2060 Box Blade
/ Reversible Blade for JD2060 Box Blade #1
Hi Everyone,
Quick question, My small box blade (JD2060) has a worn out front blade. I was told that it had reversible blades. So my question is- does that mean the front and rear blades can be interchanged or does that mean that I can flip the front blade over?
Any suggestions?
/ Reversible Blade for JD2060 Box Blade #2
Hi Everyone,
Any suggestions?
Unbolt the front blade, rotate it clockwise 180 degrees and bolt it back on with the fresh unused edge down and the used edge up.
Expect to need new bolts / nuts. You may even need a torch to persuade them to loosen up.
