Can't find neutral on TC25D
/ Can't find neutral on TC25D #1
birdsgarage
TC25D
I have a TC25D which has 2 N (Neutrals) - the lower N started giving me problems (had to move around while holding the key to start) - finally wouldn't get neutral so I started using the other N (which worked ok).
Now, I have a real hard time getting it to work (I always try to find the N before leaving the tractor so I can start it next time I need it). I am told that there is a neutral safety switch on the transmission that costs $75. Is this a common problem and is this the solution?
Thanks.
/ Can't find neutral on TC25D #2
:welcome:
Can you find the wires going to the neutral safety switch?
Do you have a wiring diagram?
I don't have a wiring diagram - I need to order a manual (any suggestions?)
I bought it used from a neighbor when he moved away - I think it is around 8 or so years old..
I really haven't looked at anything - I talked to the place where he bought it but they didn't seem to know but they did mention the neutral switch and said it was on the transmission - I will go take a look and see if I can find it - it's cold outside..
Thanks for your prompt reply..
/ Can't find neutral on TC25D #4
Just checked Messicks, and sure enough there are two of them and they are expensive - $68 for one, and $64 for the other.
So first I'd pull the switches and make sure there's not a mechanical issue with them - hung up with heavy oil, broken connector, etc.?
Then if that didn't work, although I'm a firm believer in neutral safety switches, at those prices I'd be jumping out one for sure, if not both. That's an obscene amount of money for a switch...
I crawled under there last evening and saw what looked to be a neutral switch just above a couple of shift levers - the wires are good and my first thought was to just clip and tie them together. I am also a real proponent of safety but I figure I've got the key and I'm the one who uses it and I always check/leave it in neutral. I'll have to see if I can find the other switch - although I would probably only bypass one of them.. I really need to get a service manual. Thanks for your input..
Thanks for the Messicks.com website -- I went there and found:
4) mid-pto safety 67.64
5) range gear safety 63.65
6) rear pto safety 28.57
I'm thinking it would be #5 - would you agree? I'm not sure what mid-pto would be - maybe the 2nd one (if there really is 2)? I'll try and get an answer from Messick-
My shift pattern: II N I N III which says I have a N between speed 2 and 1 another between speed 1 and 3.. I used to alway use the one between 2 and 1.. now trying to use 1 and 3..
/ Can't find neutral on TC25D #7
I'm thinking it would be #5...
Yes, I agree, not sure why I thought the mid-pto safety one would be involved, looks like it's probably just that one.
That is an odd shift pattern, might be why the switch is so expensive!
/ Can't find neutral on TC25D #8
I would never bypass the Nuetral switch....ever. You can, however, adjust the amount of pressure that the little roller puts on the switch. That is likely your issue. Take a look and let me know. Cliff
2006 John Deere 250D 25 Ton Articulated Dump Truck (A59228)
2006 John Deere...
2025 72in Hydraulic Grapple Rake Skid Steer Attachment (A61572)
2025 72in...
2016 Peterbilt 579 Automatic High Top Sleeper (69") (A62613)
2016 Peterbilt 579...
CHRYSLER V8 GAS ENG (A63291)
CHRYSLER V8 GAS...
IRMC High-End Massage Chair (A64047)
IRMC High-End...
Adams 5 T Fertilizer Spreader (A63688)
Adams 5 T...
