Price Check iMatch & Balast Box
/ iMatch & Balast Box #1
Elklakedoug
Member
John Deere 2320
Any input on what you've paid for an iMatch and balast box? I have a new 2320 and need balast for the FEL use...:thumbsup:
THANKS-
/ iMatch & Balast Box #2
No idea (can't remember), but know it was well worth whatever it was. :)
/ iMatch & Balast Box #3
Priceless:thumbsup:
Seriously though...I think the iMatch is going for close to $300 now and the BB about $200 or so.
/ iMatch & Balast Box #4
Priceless:thumbsup:
You're right on with the prices. Bought a hitch last Spring.
However, in retropect, the Pat's Easy Change works better for less money (had one on my 790...gave it away when I traded the tractor and wish I'd kept it).
/ iMatch & Balast Box #5
THANKS-
You will also need an iMatch bushing adapter kit. The issue is the iMatch is a one size fits all offering from JD and is sized for CAT-3 implements. The ballast box is CAT-1. The JD kit (BW15056) is somewhat costly for what you get. It also does not include a top link pin which your ballast box may need as well. You can gather your own complete kit for less at various online ag stores.
/ iMatch & Balast Box #6
I never had the use for the iMatch and figured it made the BB stick out that much further. But I don't change implements that often, once or twice a year.
/ iMatch & Balast Box #7
The purchase of the iMatch includes one set of bushings.
/ iMatch & Balast Box #8
Correct. One set comes with the iMatch. If you have multiple attachments you need additional bushing sets.
/ iMatch & Balast Box #9
take 2 catI lower bushing and slide them into 2 catII bushings from your local tractor supply store and Bingo new set of bushings, should come in at a whopping $4 or so.
THANKS-
OK, so the IMatch stick out. What do you guys recommend for ballast instead? open to ideas...:confused:
/ iMatch & Balast Box #11
I recommend the iMatch with the ballast box. That works great for me, and wouldn't want it any other way.
Not sure what "iMatch stick out" means. ?? The iMatch will add about 4-5" to the 3 ph arms. :)
/ iMatch & Balast Box #12
I use the ballast box but not the iMatch. You don't need the iMatch but most people have them.
/ iMatch & Balast Box #13
I think we all recommend the iMatch + ballast box combination. Kennyd pointed out that the iMatch includes one BW15056 iMatch quick-coupler bushing kit. This needs to be added to the ballast box so it fits securely onto the iMatch.
For your additional attachments (if you have any) you may need to add another bushing kit to the attachment. The JD kit is somewhat pricey. You can get all the pieces elsewhere for less. Here is an example:
Ag Supply
#D-21192 TOP LINK BUSHING CAT 2-3 = $1.86
#D-21190 TOP LINK BUSHING CAT 1-2 = $1.55
#D-10222 QUICK HITCH ADAPTER KIT CAT 1-3 = $11.00
Picture of the John Deere BW15056 kit is below:
/ iMatch & Balast Box #14
Ag Supply
Here is another source for the bushings: QUICK HITCH ADAPTER KIT CAT 1-3
2015 Ford F-150 4x4 Crew Cab Pickup Truck (A61568)
2015 Ford F-150...
40' CONTAINER (A62131)
2005 GMC Canyon (A57148)
2005 GMC Canyon...
(2) TRAILER RAMPS (A62131)
(2) TRAILER RAMPS...
40ft 10-Door Shipping Container (A61567)
40ft 10-Door...
2019 VOLVO A45G OFF ROAD DUMP TRUCK (A62129)
2019 VOLVO A45G...
