Hydraulic Line ? for Log Splitter Project
/ Hydraulic Line ? for Log Splitter Project #1
LanceH
West Central Ohio
Hey Everyone.
I'm trying to figure out the hose setup on my homemade log splitter that I'm putting together.
As I'm sure you are aware, the fluid follows this path:
1. Tank to 2 Stage Pump
2. Pump to Valve
3. Valve to one end of cylinder
4. Valve to the other end of cylinder
5. Valve (through filter) to tank
My questions is can Item #5 be a low pressure line or does it have to be high pressure?
I plan on using a braided clear piece of tubing from Lowe's or somewhere for the suction line from the tank to the pump. Next will be 3/4", 2 wire, 2250 psi Apache hose from Northern for Items 2 through 4, and Item 5 will be dependent on what you all advise me of.
Thanks a bunch.
-Lance
/ Hydraulic Line ? for Log Splitter Project #2
I use hydraulic line on all the lines, no collasping ,no problems and they do not get brittle. I buy hose by the 50' on sale and screw on my own ends. Even if you buy off the shelf made up lenghts you can always swap a lenght somewhere.
Craig Clayton
Craig Clayton
Thanks for the info Craig. Where would you recommend me looking at prices for such a roll of hose and the fittings? Do you need a special tool to put them on or do the simply 'screw' on?
/ Hydraulic Line ? for Log Splitter Project #4
I live in Ontario so I guess you would need to check around your suppliers. There is a very good posting about screw on fittings. Under search type in( reuseable fittings ).
Craig Clayton
I'll read up on those ends. Thanks for the link.
On another note, something I left out of my original post, is about the pressures on the lines and how it realates to the force the splitter is able to create.
If this hose and the 3/4" from Surplus Center are both rated at 2250psi, depending on the formula I use, wont get me anywhere close to the 35 tons continuous that I'm aiming for.
I say Force=Area*Pressure, so [(3.1416*2.5^2)*(3000psi)]/2000 lbs = 29.452 tons of force.
The 3000 in this equation is the max pressure that my 16 gpm will create. But it contradicts my 2250 working pressure (9000 max psi) on the hose.
I just dont understand how the manufacturers are getting a higher tonnage with the same components I'm using?
/ Hydraulic Line ? for Log Splitter Project #7
The two stage pumps normally work at around 2550 psi, with a max of 3000 psi. I would go with a higher pressure hose. You might have to reset the relief pressure if you use lower psi hose. The pressure will determine the force, and the GPM will determine the cycle speed. With a 4 in cyl, and 2550 psi, you should get about 16 ton of force. If you could get 3000 psi out of that pump, the force will increase to about 18.8 ton.
The cycle time will vary, because the pump is sometimes pumping at the 16 GPM rate, and at other times, it is pumping at 4 GPM rate.
Here is an auto cycle valve by Prince that once set, it will split and return and set the levers to neutral with no more action by operator. That leaves you free to get the next log ready or re-split the larger pieces.
Surplus Center - 1 SPOOL PRINCE AUTO CYCLE LOG SPLITTER VALVE
I looked at this one, but can't justify spending $268 when I could spend $90 on this: Surplus Center - 1 SPOOL 25 GPM PRINCE LS30002 VALVE
The two way detent is the same price, but I've got a 3 year old crumb cruncher and I've got to keep his safety in mind. Maybe when he gets older I can graduate to the auto valve.
Thanks for the input JJ. I think I would feel better stepping up to a better hose versus turning down my pump.
My cylinder will be 5" not 4" so do you mind telling me how you figure your forces so I can run them myself?
You have offered a lot of advice and knowledge to me on dang near all of my threads....all relating to this homemade log splitter or my previous one. Thanks again!!!!
I have a 10 hp diesel engine, 16gpm 2 stage pump, 5x24x2.25 cylinder. I am not concerned with speed as much as I want to have the power available to power through tough pieces of wood. Do you see anything negative with this setup or offer any other suggestions?
Thanks again.
/ Hydraulic Line ? for Log Splitter Project #12
Do not use hydraulic hose for suction hose. Easiest way to blow a pump.
3/4" hose is way overkill. Use 3/4" suction hose to the pump, 1/2" from the pump to the valve and valve to cylinder, then at least 5/8" from valve to filter then tank. 1/2" hose bumps your pressure rating up to 3500 psi.
/ Hydraulic Line ? for Log Splitter Project #13
The max relief adjustment on that valve is 2750 psi.
Here is the standard log splitter valve at Surplus Hyd for about $69.
https://www.surpluscenter.com/item.asp?item=9-1262&catname=hydraulic.
This valve has max relief of 2750 psi.
You really don't want two way detent standard valve.. That locks the valve on. If you walk away after setting a detent valve, it will get to the end of the cyl travel, and start screeching. The log splitter valve is designed to set the detent, and when the pressure gets to the detent release pressure, the lever shifts back to neutral.
Ok, so you're advising to use a 'suction hose' which provides less restrictive flow in lieu of a true hydraulic hose. I understand this concept.
As far as 3/4" being overkill, I was told by another fellow on here that 3/4" is the best size all around for a 5" cylinder and 16gpm pump. In your opinion, will it "hurt" anything if I use 3/4" hose from the pump to valves, thru the cylinders and to the tank?
It makes sense that dropping to 1/2" hose increases pressure, but a smaller size means less flow. Is that right?
JJ-I understand how the detent works, this one has it only on the return stroke and its spring centered on the extend stroke. I would prefer this kind versus the two way detent for safety reasons. But I thought/still think that I need to have the style with the 3/4" work ports for proper use with my 5" cylinder and 16 gpm pump. Would you agree with going to the style that has 3/4 work ports? Thanks again for your help.
/ Hydraulic Line ? for Log Splitter Project #16
You use suction hose because it is made to not collapse under a vacuum. Your hydraulic hose will get sucked shut and starve your pump. I have seen it happen. There is a hyd hose company in Jersey that bought an excavating company a $7,000 pump because they were out of suction hose and sold hyd hose instead. Suction hose has the same flow as hyd hose, just a different construction so it won't get sucked shut.
My opinion, using 3/4" hose won't hurt anything. Guys like J_J are better than the math than I am. 1/2" will last longer because of the higher pressure rating and log splitters I have seen in this class all use 1/2" hose. If it were mine, I would use 1/2".
That makes sense. Thats a good way to put it in prespective. Maybe I'll pay the extra money for real suction hose instead of skimping by and buying the reinforcing clear hose from Lowe's. Thanks again for the info.
/ Hydraulic Line ? for Log Splitter Project #18
In a fixed displacement pump/constant flow system, a smaller size hose means higher oil velocity and higher pressure drop (power loss). As long as part of the pump flow do not get diverted in control valve or by passed through the pressure relief valve, flow will stay the same through a smaller size hose.
Most hose size recommendations (nomograms) for 16 gpm, will show at least 5/8" for pressure line, 3/4 to 7/8" for return lines and 1 1/4 to 1 3/8" for suction line.
Under size pressure and return lines will gamble with heat creation, you might get away with smaller size under intermittent operation. Under size suction line can starve the pump
Note that you might need 4 wire hose for larger sizes....$$$....
All recommendations are based on a fixed viscosity, thicker oil takes larger size.
AkkaMaan...you posted up one of these nomograms/charts that showed that a 3/4" hose and it only makes sense. I mean Prince offers these valves with 3/4" working ports and it specifically states (on Northern's website) that this valve is designed for use with 5" cylinders and up to 16gpm pumps. So I can only believe that there is no harm in using 3/4" pressure line. Are you pulling those nomograms from somewhere online that you could share or is it a scan from a book you own? Thanks for your knowledge.
/ Hydraulic Line ? for Log Splitter Project #20
If the cyl port size is 1/2 in, and the valve is 3/4 in, You will have to adapt one end of the hose. Which ever way uses less fittings. I would go with 3/4 on all hoses except the suction hose. Use the same size that is on the suction port of the pump.
Inlet port on those 16 GPM pumps is 1 in.
2016 International WorkStar 7500 T/A Dump Truck (A61573)
2016 International...
2022 EZ-GO ELITE...
2011 Freightliner B2 School Bus (A61568)
2011 Freightliner...
2008 Freightliner Allegro Bay Class A Motorhome (A61574)
2008 Freightliner...
2013 CATERPILLAR TL943C TELESCOPIC FORKLIFT (A64279)
2013 CATERPILLAR...
Kubota Industrial Turbo Diesel Engine - Tag Missing - Pump Takeout - Approx. 80-85 HP Class (A63689)
Kubota Industrial...
