Filter cross reference.
/ Filter cross reference. #1
davygp38
Gold Member
where NY,NJ, and PA all meet
Kubota L4400
Since I am on call today, I took the time to cross reference the engine oil, and hydraulic filters on my Kubota L4400. It only took me 20 minutes, and now that I know what to do It should take you all a Little less time. I took the part numbers for the OEM filters off the receipt for the ones I bought from the dealer, and started hitting filter sites. The engine oil filter was easy,I found one from Fram right off the bat. I don't use Fram filters, if I can avoid it, but I had to use the fram part number to find the purolator part number (the kubota number would not come up.) The cost savings for this filter was not that great Kubota $10.79, Purolator $9.99, however the dealer is 40 miles from here, and I can now get one locally.
The hydro filter was harder to find, but I was able to get it off the Wix site, and from there I could cross reference it to a NAPA filter. The Savings is remarkable. Kubota Hydraulic filter $41.17, Wix/Napa filter $19.99. I know some of you out there feel strongly about only using OEM parts, and filters. My hats off to you, and I am sure Kubota loves you. However I feel I can use these filters, and I always change the fluids, and filters sooner than required. I hope this was a help to some of you. it is at any rate an option.:thumbsup:
/ Filter cross reference. #3
Everyone has to do what they see as right.
I see absolutely nothing wrong with using quality filters from Wix, Hastings/Baldwin or FleetGuard.
The problem I have is that, in many cases, no true cross or true replacement exists. Once one gets into crossing to a cross to a cross, my enthusiasm wanes considerably.
While I don't worry much about a hydraulic filter or engine oil filter, I have found much more difficulty in using anything other than an OEM when it comes to the Hydro Trans filter. Internal magnets? Those seem to be very specialized and seldom are there true replacement filters available.
/ Filter cross reference. #4
I like matching filters for myself but for my business I appreciate those who buy off make filters. Right now we are working on a machine that the owner couldn't believe that we wanted to change out the oil and filters before we went any further with trying to find the problems with sticking valves and erratic operation of the hydro's.
funny thing that his 50 micron paper filters didn't do well enough when replacing 100 micron! Oh well, his initial savings are being eaten up a bit at this point at 2600 hours.
/ Filter cross reference. #5
Yep, in troubleshooting situations there is nothing better than well trusted name brand or OEM filters to eliminate potential issues with cheap aftermarket, maybe it will work filters.
Brian
/ Filter cross reference. #6
I dont use the kubota engine oil filter either.
BUT I do on the hyd. filter.
I did the same thing as you on my first service by trying to cross the filters. NO LUCK at ALL on the hyd. But the dealer is on my way to and from work and they had pleanty in stock. So in a last ditch effort to find one to cross, I went ahead and took the old one off to measure the o-ring diameter and the threads and just go by that. When I did this I noticed the big ring magnet inside the o-ring on the filter. I have never seen any other common hydraulic filter have this. And I was also unsure if their would be room to put the old magnet on a different filter.
I decided it was best to stick with the OEM. Afterall, the hyd. filter service is only every 200hrs, so the cost isnt going to be a big issue for me.
So my question to you would me, does your filter have this magnet??? And if it does, were you able to clean and re-mount it inside you new NON-kubota filter??
/ Filter cross reference. #7
I attach a magnet to the outside of a lot of my filters, including the oem kubota engine oil filter.. inside the transmission oil pan on cars and trucks. Unless it has an oem in there already.I don't know if your situation would work, as I don't have that type hydro filter.I added a filter and adaptor to my return line from FEl, to"help" my screen clean trans oil. **** maybe, but that oil is clean, to protect cylinders and valves..
/ Filter cross reference. #8
I did the same thing and changed all my OEM filters to WIX. The Amsoil and WIX sites also both have cross reference tools. FYI the NAPA filters are rebadged WIX as well.
/ Filter cross reference. #9
Really? I didn't notice that thing. I just replace the hydro filter on my L4200 a couple of days ago. I did use a Kubota filter though, so I guess I have a magnet in there?
$30 still strikes me as an awful lot for an oil filter though. I did discover that my local dealer's prices are identical to the popular M/O places like messicks and/or tractorsmart, which is surprising, since my general impression of the shop is that they are a bunch o' thieves.
JayC
/ Filter cross reference. #10
I just ordered about $250 worth of filters (air, oil, fuel transfer, cabin, hydraulic) from
Filter1 Wix heavy duty engine, oil, automotive, truck, and tractor filers.
The site is well designed, easy to use and locate needed filters.
Prices are better than I can get locally.
They have a complete line of filters, I ordered Wix.
Free shipping if you order 6 or more filters or more than $50 worth.
The convenience is worth a lot to me to have all the filters I need delivered. I maintain a tractor, 3 pickups, 3 cars, thus being able to sit down, order replacements and spares all at one time works for me. It's a lot of filters.
There is one hydraulic filter that NOBODY has except Kubota... however, one of the Kubota hydraulic filters they (and others) do have a cross reference for.
Or you could have just gone to the Napa filter site.
Napa filters for L4400
Brian
You have to start somewhere. It would have been nice, if I had picked the NAPA site first, however, there are a lot of filter brands, and I started with the first one that came to mind. That being said, now that I did the work, I can now do what you just did, and post a link.
/ Filter cross reference. #12
I would be careful crossing a filter several times to find one that fit also be extra careful with the fuel and hydraulic filters a lot of the newer equipment the filters they are using are a lot smaller micron rating than the aftermarket filters even though they are the same size
/ Filter cross reference. #13
/ Filter cross reference. #14
We a bit pessimitic over using wix or napa filters as there filter for the cummins 5.9 would void engine warrantee.
The best aftermarket company that also makes many oem filters that we have come to use is Fleet gaurd.
When people order multiple filters we and many other dealers also have discounts on quanity mixed orders.
Many filters from manufacturers come with things like anti drain back valves so the filters remain full for better lubrication on start-up. Many times to get to far off not only is the filter median is compromised as well as the filteration process.
/ Filter cross reference. #15
If you want to scare yourself go start crossing filters for the BXs. they have a small filter and that same size is used on a lot of motorcyles. Then go to the site where the guy cuts them apart to see what is in them. For a replacement engine in the 3K to 4K range it is not worth it. Also there is no cross for many Kubota charge pump filters, hydraulic strainer maybe but not worth it for every 300-400 hour change.
david Kb7uns
2019 Cadillac Sayers and Scovill 70IN Limo w Only 7729 Miles (A63689)
2019 Cadillac...
2006 CATERPILLAR 307C EXCAVATOR (A63276)
2006 CATERPILLAR...
2011 JOHN DEERE 672G MOTORGRADER (A63276)
2011 JOHN DEERE...
2006 International 4200 2,000 Gallon Water Truck (A61573)
2006 International...
2019 Nissan Sentra Sedan (A61574)
2019 Nissan Sentra...
Case IH True-Tandem 330 Turbo (A60462)
Case IH...
