Trailering my Kubota B7800
   / Trailering my Kubota B7800 #1
logan97
Gold Member
Blue Ridge Mnts, Va
Kubota B7800 4/wd
I need to take my K B7800 about 50 miles to local dealer for some maintenance and repair. I have a tandem axle flat bed, 7000# capacity trailer to haul it with. I am planning on ratcheting a 5/16 chain in the front and one in the rear is there anything else I need to do to be legal ? Brakes,lights and tag are all good and up to date.
   / Trailering my Kubota B7800 #2
That's how I haul my B 2620.
Will
   / Trailering my Kubota B7800 #3
I have a B7800 that I haul on a 7,000# tandem axle trailer. I loop a chain around the front weight mounting plate (under the radiator). For the rear I put a clevis in the hole in the draw bar and loop a chain through that. Both chains are then tightened with ratchet booms. Make sure your chains are pulling against each other when you snug them. Also make sure you have enough weight on the tongue of the trailer.
   / Trailering my Kubota B7800 #4
I would chain at four points as is often discussed here. Under 10klbs, you really only need two chains in most states. But, my tractor dealer was hit, in the trailer, while hauling a tractor. Other driver missed a curve, and hit the trailer hard. With four points of attachment, that tractor did not move, even though part of the trailer was damaged, as well as the wheels broken from the axles of the trailer.
I chained from four points before, now I do for sure. I use two chains, but they are long enough I can make four independant attach and bind points.
Otherwise you describe how I hauled my old Kubota, which was the same size, but older.
   / Trailering my Kubota B7800 #5
Don't forget to stop after 4 or maybe 5 miles and check chain binders and tension. And then again maybe after 20 miles or so.
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2018 GENIE GTH-636...
2018 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A50046)
2018 FREIGHTLINER...
Parker 250 bu Gravity Wagon (A50515)
Parker 250 bu...
IF YOU BID ON AN ITEM YOU MUST PAY FOR IT!! NO BACKING OUT AFTER IT IS SOLD!! (A50775)
IF YOU BID ON AN...
2007 Terex RS350 Soil Stabilizer/ Reclaimer (A49346)
2007 Terex RS350...
2020 Kubota Z723KH 48in. Zero Turn Commercial Mower (A50324)
2020 Kubota Z723KH...
