Reusable fittings
/ Reusable fittings #1
Kitz
anywhere usa
IH 244
Does anyone out there know how to assemble the reusable hydraulic fittings. or know of a site where i can get a description of how to assemble. Thanks
/ Reusable fittings
Thats it i thought i seen it before thanks rick
/ Reusable fittings #5
Hi guys.. there are 2 types of reuseable fittings, no-skive and skive types. It depends on the manufacture as to what type it is. On a no-skive you have to leave the outer rubber on the hose then assemble it ( some manufactures have a tool to guide the hose/fittings together and with out it they will not guarantee the assembly) and the Skive type in which you have to remove the outside rubber down to the outer layer of steel wrap (this requires a special tool to remove the rubber). Just remember that you can not interchange fitting manufactures and hose manufactures when assembling them. I have a full set of couplers in the service truck when we have to field repair hoses but i still prefer to have crimp hoses installed. Jim
/ Reusable fittings
So Jim your saying that if i have weatherhead fittings i have to have weatherhead hose. or can i use a hose that is manufactured interchangable with weatherhead. thanks
/ Reusable fittings #7
I've never been told this. Is there anything documented pertaining to this?
I would think if the hose is meant to be used with a reuseable fitting,the fitting brand shouldn't matter.
Greg
/ Reusable fittings #8
Greg
Every mfg has a note like Parker's below
42 Series Fittings
Parker No-Skive 42 Series Fittings is a field attachable (reusable) style fitting which permits quick, easy field assembly without special tools. Assembly of No-Skive hose and fittings does not require removal of outer cover of hose. This eliminates premature hose failure caused by skiving too long or short. 42 Series Fittings has zinc dichromate plating and are used with 421, 431, 436, 482TC, 482ST Hoses - the Parker Hydraulic/Braided Hoses.
Parker - 42 SERIES FITTINGS
/ Reusable fittings #9
NEVER interchange fittings and hoses from different manufactures..... it only takes a few thousands of an inch and you are in trouble.... ask me how i know.... we had #6 crimping die that was worn and the crimps were under pressed by less than 2 hundredth of an inch, everything was ok until we started to have failures at high pressures, the crimp ends were blowing off. You will never get a manufacture to say that it's OK to interchange, so why risk it. Hoses are different in exterior dimensions even though they are the same interior size. Jim
/ Reusable fittings #10
I don't know what you guys are yapping about?
I have used and reused many of these reusable hose ends over the years,they where more common in the past than today(i guess people where smarter back then)
A 1/2" fitting will fit a 1/2" hose of most brands,same with other size fittings and hoses.As long as it ain't metric.
On a single braid hose one usually can leave the rubber outer layer on,or skin it a wee bit.
On a double braided hose one needs to cut the rubber down to the steel.
No need for a special tool either,any sharp knife will do.
There is most times a mark on the fitting sleeve to tell how far to wittle the rubber back,no harm done if the rubber is cut back to far either,it just looks stupid.
I never had one fail yet.
Can't say the same of crimp fittings.
/ Reusable fittings #11
All that states is what Parker hose to use with their fittings. Nothing about NOT using another brand.
The Gates fittings I used to make my plow lines weren't mated with Gates hose. Not my fault,that is what I received in my order.
Greg
/ Reusable fittings #12
.{[ I don't know what you guys are yapping about?
Can't say the same of crimp fittings.}]
God i love it when people say things like this... i'm certified for 10000 psi hoses and i know a few things about hoses and fittings, and that if i mix things and some thing happens my lawyer will be very busy and my insurance company will be very unhappy... i will take a guess and say that most people don't know that if a reusable blows off you need to replace the fitting and hose assembly???
/ Reusable fittings
Hey Wayne I have bought weatherhead reusables p.n. 42504N-606 and was going to buy 100R2AT hose from discount hyd hose. Do you know if that will work or do i need H425 Weatherhead hose Thanks
/ Reusable fittings #17
Bison said:
I certify myself,i got better luck with that than with "professionals" who push their own products.:p
Keep spinning that cylinder and pulling the trigger.
Oh, BTW, I have sent many people over to Ken at DHH. It is not my product, I don't make a nickel off of it.
/ Reusable fittings #18
There is reusable fittings from many different manufacturers where you dont need any "special" hose from the same manufacturer. I guess thats one of the nice thing with standards ;)
If I look at Hydrscands assembly instruction they just mention to use EN 853 1SN or 2SN.
/ Reusable fittings #20
you hit the nail on the head Wayne County ... most of these people have no idea what happens when you are called in by workmans compensation board to testify as to why something happened. I've been their twice and it's hard to look at the widow and tell them that if some one had spent the extra $20 he may still be here.
Why risk an accident that can be avoided by not doing it right the first time, most times the second chance comes with a painful reality..
2008 MACK CHU613 DUMP TRUCK (A63569)
2008 MACK CHU613...
New/Unused Wolverine Quick Attach Trencher (A65583)
New/Unused...
(2) 30 Yard Roll Off Dumpsters (A65579)
(2) 30 Yard Roll...
2018 JOHN DEERE 650K LGP CRAWLER DOZER (A64279)
2018 JOHN DEERE...
New/Unused Heavy Duty Plate Compactor (A65583)
New/Unused Heavy...
2017 Ford Escape AWD SUV (A61569)
2017 Ford Escape...
