3pt hitch question
/ 3pt hitch question #1
handirifle
Central Coast of CA
Massey Ferguson 1010
Yesterday I took my gannon box off the back of my tractor, to use the draw bar to pull a trailer. Also, for the first time, I realized that it was connected entirely with quick disconnect pins, EXCEPT for the top connection on the 3pt hitch.
That was a bolt with a nylon locking nut.
While at the local tractor shops, I see the various 3pt items sitting around, for sale, also had the same top bolt setup.
WHY? Why not a pin all around? I don't see there being a need for the bolt, as it would be easier and a wrench free operation without the bolt.
/ 3pt hitch question #2
I have pins with circle quick clips for both side and top link... Quick and easy, have nooo idea why you would use a bolt? Maybe they were concerned about slop??
/ 3pt hitch question #3
/ 3pt hitch question #4
Better yet get the black extra strong lynch pins at tsc .They don't get hooked on limbs and dislodged as easy.
amaxwell
/ 3pt hitch question #5
I agree, ditch the bolt.
My Frontier BB has a bolt, but that works fine for me because I have a quick hitch and that may be why your blade was set up that way.
/ 3pt hitch question #7
If your looking at something like this, the lower bolt (or pin) is for a quick attach hitch and is usually a bolt or welded pin. Gives the option to use either the quick attach hitch or the standard top link.
I just realized, I probably put this in the wrong forum. Thanks for answering anyway, and not razzing me.
OK, I was wondering if there was a REAL reason. There is no setup on this box for a quick attach, so it must have been what was available at the time.
LD1
Why the two different size pins? Are the 7/16" for the draw bar? Is that the normal size? It has no pin for the draw bar and figured I get one of those too. We do not have a TSC here, but do have a Farm Supply. I doubt seriously if they are that cheap there. NOTHING is cheap in that store.
/ 3pt hitch question #9
LD1
The 7/16 lynch pin goes into the hole on the 3/4" pin to keep it from falling out. It is the same style of linch pin that you put in the little holes on the lower pins as well.
2018 Tycrop Vector Belt 22ft. VB-16H Portable Sand Belt Conveyor (A64194)
2018 Tycrop Vector...
2014 BOBCAT T870 SKID STEER (A65053)
2014 BOBCAT T870...
2003 Sterling L7500 S/A Day Cab Truck Tractor (A64556)
2003 Sterling...
UNUSED IRMC HIGH END MASSAGE CHAIR (A65055)
UNUSED IRMC HIGH...
2008 Allmand Max-Lite ML20 20KW Towable Light Tower (A64194)
2008 Allmand...
2013 CATERPILLAR 120M2 MOTOR GRADER (A63276)
2013 CATERPILLAR...
