How do I shut it off ;-)
/ How do I shut it off ;-) #1
BurningBushFarm
WNC
YM2000D
This is the new owner's spinoff from my previous post on comparing the YM1700 and the YM2000 :)
When I was checking my very cool tractor-to-be out the owner said sometimes it diesels when shutting it down.
California wrote back then "YM2000 is stopped by pulling the throttle to zero which shuts off all the fuel."
So I have my terrific tractor home and it starts like a champ -- but when I go to shut it off, it doesn't. Shut off, that is.
My book is actually for the YM240 series so the throttle is the opposite, but I follow the shut down procedure and when I push the throttle forward ("slow"), the engine slows down ... ... .. .. . . . . . .
But it doesn't stop running.
Husband is going to check it out tomorrow.
Any ideas?
(And no, it's not still running. We do shut it off. Just not the way it's supposed to be shut off. :eek: )
/ How do I shut it off ;-) #2
No Big Deal Almost a good thing.Runs so good it doesn't want to shut off :p Here a pic of the Adj. and Linkage. Just loosen the Nuts and move Arm Backwards a little more. Shutting down the fuel.
Carey
/ How do I shut it off ;-) #3
Any ideas?
When my tractor started doing the same thing, I put a couple of drops of oil on the linkage and put a little more tension on the spring. That cured the problem.
/ How do I shut it off ;-) #4
What they said - adjust the linkage so it pulls the governor clear to zero.
I read of someone who had to reach under the dash and tug on that rod because the linkage was sloppy. If so I would replace it. Another alternative specifically recommend against in the manual is to idle down then use the compression release.
On my second Yanmar I had to add a screen door spring to the governor arm to pull it to zero, when the linkage was pushed all the way to zero.
But fix this. You have a safety issue if the engine keeps running after you fell off the tractor or something.
Congratulations on your new Yanmar! That thing is gorgeous, probably the nicest one I've seen.
Thanks y'all.
Will show it to my husband in the morning. I think that's what he had in mind as the problem. But this saves him the muddling around.
(I don't like to mess up the manicure with the nitty gritty stuff. :laughing:)
Oh BTW -- baptized the FEL with my horse manure this evening.
/ How do I shut it off ;-) #6
That's odd, because on all my GT's, the only way to shut it down is with the release. There's a seperate cable specifically for the compression release, but there's another specifically to shut down the engine. They both appear to do the same thing.
I would prefer the setup you guys have, as cables snap eventually.
/ How do I shut it off ;-) #7
On my YM2001 there is a release below the throttle arm, idle down and pull it out, it looks just like the decompression release (on left side of dash) but it just kills the fuel to the engine regardless of throttle position.
It is not recommended to shut a diesel engine down with the decompression release unless in emergency situations.
In regards to the question, if the tractor doesn't stop when the throttle arm is pushed all the way forward you can lift the foot pedal throttle up with your foot and it will generally shut off, the issue is as stated above the linkage spring needs to be adjusted.
/ How do I shut it off ;-) #8
The foot pedal thing was my guess, Smoody, you beat me to it. Had to fix that on mine.
/ How do I shut it off ;-) #9
What everybody else said. Mine will sometimes shut off using the lever, but most of the time i just am in the habbit of reaching down and pulling the lever on the side of the motor shown in the piture back, to ensure proper shut off.
/ How do I shut it off ;-) #10
That's the same thing I was doing until I decided to take a look at the linkage under the throttle arm. Took it apart, cleaned and put a couple of drops of oil on the friction plate. It has worked fine ever since. I think it comes from combined wear in the linkage and the a little sticking at the very end of the closed position to be just enough to not fully shut the fuel off. Putting a little more tension on the spring might have also helped out.
/ How do I shut it off ;-) #11
My Friction Plate/Washer desinagrated so I could only use my pedal. Take my advise on this one. If it does wear out Order the correct Nylon one from a parts supplier :ashamed:
Carey
/ How do I shut it off ;-) #12
Carey
I didn't even know it was supposed to have a nylon washer:laughing: Mine must have fell apart long ago. Now it's just metal on metal. Maybe that's why I had to put a little oil on it. Probably work a lot smoother if I get the washer put back in:thumbsup:
/ How do I shut it off ;-) #13
mine seems more like rubber than nylon? i just havent touched it much i guess. Maybe its just that its black? Some on here say to cut a piece of leather to use as a friction washer? I have not done it just read it, but seems like that would sieze up lightly every time it sits for a few months.
/ How do I shut it off ;-) #14
We always have plenty of nylon washers in various sizes from the equipment we install at the cell sites. I'm gonna look and see if I can make any of them work. Glad to know there was supposed to be something in there other than metal on metal.
/ How do I shut it off ;-) #15
Have to be Honest. After it broke and I was doing the same trying to make a o-rings, a smaller plastic and Yes even Leather I broke the Stud off the Handle. I was able to Tack it back on but it definitly got a WT_ :eek::ashamed::ashamed:
Carey
/ How do I shut it off ;-) #16
my YM14 has compression release and a stop pull cable which is connected to the pump,dont tell me thats another difference between a GT and a YM??
/ How do I shut it off ;-) #17
i thought mine was rubber also? not that i have pulled it out to check but it feels like rubber poking at it. i have tightened mine and sprayed it with silicone spray and it has been great for 18 months now,it did on occasions not want to stop unless you slammed the lever forward until i lubed and adjusted it.
/ How do I shut it off ;-) #18
my 1510 has a hand lever and foot throttle. if i set the hand to 'zero' (furthest from me) it ticks over - I then press a small button, under the dash, to release the last 0.5" of travel which kills the engine.
apart from stalling it several times a day that is..........
/ How do I shut it off ;-) #19
I'll have to look to see where it goes. Both my YM146 and GT14 manuals refer to it as an "Engine Stopper".. While the compression release is referred to as a "decompression knob"..
Makes sense that the "stopper" would shut down the fuel. Will have to look next time I can get to the shed.
20+ inches of snow on the ground with another 9-12 expected tomorrow night! :confused2:
2022 CATERPILLAR 259D3 SKID STEER (A65056)
2022 CATERPILLAR...
2013 CASE 580 SUPER N LOADER BACKHOE (A67714)
2013 CASE 580...
2015 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A69167)
2015 FREIGHTLINER...
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
2025 44in Single Cylinder Grapple Rock Bucket Skid Steer Attachment (A66734)
2025 44in Single...
2013 TYTAL CRUDE TRAILER (A67714)
2013 TYTAL CRUDE...
