hydraulic bypass question
/ hydraulic bypass question #1
lwalsh
Rockford MI
I think I know the answer but I want to verify. Am I correct in saying that a loader valve will not bypass from excessive load applied to the cylinder? I hit an immovable object with my 2720 front plow. Outside corner of the plow caught the frozen ground while going slow. The plow was in the straight position and instead of stopping the tractor it swung the plow about 15 degrees and blasted the underside of the tractor with hydraulic fluid from the banjo fitting on the output side of the valve. No apparent damage and the bolts are at 40 ft/lb per spec. I should mention it is a home built plow setup and the swing cylinder doesn't have much of a mechanical advantage. It's a single cylinder only about 6" offset from the pivot pin. Did I just get lucky?
/ hydraulic bypass question #2
Pics will help follow along. :)
/ hydraulic bypass question #3
NO and that is why you really should run a CRV.
/ hydraulic bypass question #4
No, the regular PRV (pressure relief valve) is not "in the circuit" when the valve is in nuetral. Both work ports are blocked so the fluid (and pressure) have no place to go but will find the weakest link-in your case the banjo. Lucky? Yes you sure are! Usually it's a blown hose, bent frame or a bent cylinder.
Snowplows have CRV's (crossover relief valves), AKA "cushion valves" for this very reason. They let the fluid "crossover" to the other cylinder (if used in a two SA cylinder setup typically found on plows) or to the other side of the cylinder for single DA cylinder setups like yours. They are also good to have on thumbs circuits on backhoes.
Here is a good one to get: Surplus Center - 1/2 NPT 30 GPM 1500-3000 PSI HYD CUSHION VALVE
Thanks Kennyd a perfect explanation and a link to the solution. What more could anyone ask for.
Volvo EC220EL (A60462)
2013 Ford F-150 Crew Cab Pickup Truck (A61573)
2013 Ford F-150...
UNUSED (15) SDLANCH PROTECTION MATS (A64281)
UNUSED (15)...
Caterpillar D7H Series 1 and 2 Dozer Service Manuals (A63117)
Caterpillar D7H...
APPROX. 1000 GALLON FUEL TANK (A63291)
APPROX. 1000...
UNUSED ATSPOWER ELECTRIC WINCH (A64281)
UNUSED ATSPOWER...
