Oil & Fuel Cleaning tractor motor
/ Cleaning tractor motor #1
robs660
Gold Member
Washington NJ
Kubota B20
I would like advice on how I can clean my tractor motor. It's a 1994 Kubota B20 that has never been cleaned and there is a ton of build up on the motor. What is the best way to get 20 years of grease and dirt of the motor without damaging anything?
/ Cleaning tractor motor #2
A hot pressure wash will do the trick. Just cover the alternator with a heavy (thick) plastic bag so it wan't get wet inside, and avoid spraying the starter, solenoid, and any electronic boxes with direct high pressure. Also, cover up the air filter intake and any crankcase vents as well.
Before you start, you can spray it down with a degreaser and let that soak for a while, then spray it with high pressure. After you have sprayed it, let it dry for a few hours with a heater blowing warm air on it. If you don't have heater to blow warm air on it, and you can wait till warmer weather, then you might be better off doing it in the spring/summer and park it in the sun to let it dry off.
There's a guy that lives near my parents and he has a high pressure steam wash outfit on a trailer and he has a pretty good side business doing just that with many of the local loggers there. He drives out to the logging site, and steam washes the skidders, feller bunchers, and 18 wheelers. That's pretty much the same technique that he uses, only they just let them dry overnight. If it's going to get below freezing though, he just waits for a warmer day to do it.
/ Cleaning tractor motor #4
I have no idea....I always felt that dirt and grime buildup was a good thing. It means I haven't had to fix anything lately. :laughing:
/ Cleaning tractor motor #5
I agree. You may find things you have to fix if it is clean. Grime may be holding something together. :laughing:
My garage is heated and I have a floor drain. Is there a way to do it without steam. I don't have access to that tool.
Need to clean it so I can find out where the small leak is, and my radiator is pretty clogged with 20 years of gunk
/ Cleaning tractor motor #7
I use a pressure washer and simple green with good results just follow the good recommendations from the earlier posts and do not focus the high pressure on electrical connections and such. Spray with simple green wash and repeat till clean.
/ Cleaning tractor motor #8
Air works pretty good for radiators. Be careful not to bend the fins.:D
Water hose and dish detergent may work on the engine.:)
/ Cleaning tractor motor #9
i would start with Dawn dishwashing detergent and a water hose. You'd be amazed how that works. Or just degreaser and a water hose. High pressure washers w/heat are nice, but a water hose does a good job. might take a couple of times to clean.
/ Cleaning tractor motor #10
Before pressure washers came along (and I have issues with using them, as gaskets, particularly in cooling system, aren't designed for very high pressures), we used to wet, sprinkle with Tide or kerosene, let sit and then hose off. Now we have liquid detergents. I'd wet, spritz with detergent, let soak and then spray off. Would help if you had hot water, but cold will work. We always just used from the hose. You could use Simple Green, Purple or similar in place of the clothes detergent. These weren't around in the old days.
Ralph
/ Cleaning tractor motor #11
I'd also go with some type of degreaser, commercial or just a good soap, let sit then rinse. The warmer the water the more it will help
/ Cleaning tractor motor #12
Simple Green is amazing stuff. Spritz, sit, rinse, repeat if needed.
I envy your floor drain. I wanted to put one in my out building that just ran to daylight, and the contractor that put the floor in wouldn't do it. Said it was against some regulation, but couldn't tell me what or under who's authority. I didn't have time to argue with him, but sure wish now that I had. I sure don't see the difference in environmental impact between a floor drain that runs to daylight and doing the degreasing type work on your driveway. :confused2:
/ Cleaning tractor motor #13
We use purple power for this task. Get it at the auto parts store for under $10 per gallon and put it in a old spray bottle. For this task I use full strength. I use a ELECTRIC pressure washer also for this task. It has about 1500 psi, about half of what a gas one does. Great for these tasks and washing cars.
Chris
The flor drain is illegal but it was installed before I bought the place. It's great for melting snow as well
/ Cleaning tractor motor #15
I have used Gunk engine degreaser in the spray can. It soaks thru most grime, but works even better if the motor is warm. Another commercial product is LPS, it works well too, but is very strong, when concentrated. Jy.
/ Cleaning tractor motor #16
We use purple power for this task. Get it at the auto parts store for under $10 per gallon and put it in a old spray bottle. For this task I use full strength. I use a ELECTRIC pressure washer also for this task. It has about 1500 psi, about half of what a gas? electric one does. Great for these tasks and washing cars.
Chris
What brand of electric pressure washer do you have Chris? I have though about getting one for cleaning stuff. I had a gas pressure washer for a house staining project and decided the engine maintenance wasn't worth it to keep it around, plus don't need all that pressure anyways.
Ditto on the advice to go easy around electrical. Just spraying a hose, if I direct too much against the cowling behind the engine, even my simple electrical system gets befuddled for a bit.
Dave.
/ Cleaning tractor motor #17
If you have access to an air compressor (it doesn't have to be anything big) you can use one of these. You can adjust the pressure so you don't blow the paint off the engine and it can get into small places. It let you control how much spray you want to use. There are several types of cleaning solution you can get at any parts store. Just stick the small hose into the cleaning solution and hook up the air line. Keeps the mess down considerably.
/ Cleaning tractor motor #18
Dave.
Yes, I made a mistake and put Electric, not Gas. I went back and fixed it.
I am on my 3rd power washer. My first was a Campbell Hausfeld. I screwed up and left it in the pole barn where it froze up and cracked the pump. The next one was a Kracher. My daughter cut the hose and it was going to cost $30 for a new one. The current one is a no name one from Menards. Had it for a year and it works great for $40 on sale. I got lucky and the hose from the old CH one had the same threads so I got a $5 adapter and hooked them together for a 50' hose now. Real nice. I use it weekly to wash the tractor, boat, cars, ect.
Chris
/ Cleaning tractor motor #19
I also use an el cheapo electric pressure washer that I got from Home Despot for around $50.00. I use this one for washing stuff that might get damaged by my gas powered 3000 psi one, such as radiators, small engines, barn cats etc. Well, not cats really. For what I paid, I didn't expect it to last as long as it has. I think I use it more than the gas one. The pump shuts itself off when the wand's trigger is released, which is nice. For degreasing, I mix Gunk 50/50 with kerosene and put it in a spray bottle. Although it isn't recommended with these cheap pressure washers, I often run hot water through them.
/ Cleaning tractor motor #20
Thanks Chris and Heywood. Sounds like just buy one that looks like it will not self destruct. I only need to use a washer 1 or 2 times per year. Not the best thing for a gas engine besides the having to drain the fuel and all.
Dave.
UNUSED IRGC80 Battery Powered Golf cart (A55272)
UNUSED IRGC80...
UNUSED WOLVERINE 8' FORK EXTENSIONS (A62131)
UNUSED WOLVERINE...
2017 Ram 5500 Bucket Truck (A63118)
2017 Ram 5500...
Arrow Quip EF10 Two Bow Alley Kit (A64047)
Arrow Quip EF10...
Sealmaster Chip Spreader Attachment (A61166)
Sealmaster Chip...
(4) Trail Quest 235/80R/16 Tires and Rims (A64047)
(4) Trail Quest...
