Car hauler for round bales
   / Car hauler for round bales #1
L_Nicholson
Madison, Indiana
1998 JD 4400
Hi All,
I was wondering if anyone has made something for a car hauler trailer that would allow you to haul 2 rows of round bales and that propped the bales up over the fenders.
Thanks
Lee
   / Car hauler for round bales #2
We just set one between fenders and 2 side by side front and rear of the fenders
   / Car hauler for round bales #3
Does your trailer have stake pockets, if so wouldn't be hard to use some steel tube or something that would slip into the stake pockets on each side of the fender and keep the bail off them.
How long and wide is your trailer?
Mine is 16' with 2' dovetail for a total length of 18' and 6'-10" wide.
Yes, it does have 6 side pockets/hook areas per side.
I figured it wouldn't take too much to come up with something. I use 5' bales and have only been hauling 3 at a time for safety sake.
   / Car hauler for round bales #5
I live in Georgia and it seems that none of the hay people make 5' round bales. DOT was hassling them about wide loads. Now everyone is doing 4'x6' rounds which keep the DOT from fussing.
   / Car hauler for round bales #6
I have just loaded them on top of the fenders. Eight bales at a time. More secure IMO than just loading one between the fenders.
No problem with wide loads for farm operations in Ohio AFAIK. If in doubt, slap a SMV triangle on the back but I've never done that.
Ken
   / Car hauler for round bales #7
A single row on a "car" trailer will usually be plenty of load.
   / Car hauler for round bales #8
YMMV. Making 10 2-hour trips instead of five? Especially when you want to get it out of the field before it rains?
   / Car hauler for round bales #9
3 1600 pound bales is all you can haul on a typical 7k GVWR "car" hauler weight wise. 6 would be way over weight.
Anything short of a semi hauling hay 2 hours is a waste of time IMO.
Each bale is subject to different weghts. I buy 5x5's and they run about 1200 lbs each.
Lee
2021 CATERPILLAR 953 CRAWLER LOADER (A51242)
2021 CATERPILLAR...
2017 Ford F-150 Ext. Cab Pickup Truck (A50323)
2017 Ford F-150...
MIDLAND POLY PIPE REEL TRAILER (A50854)
MIDLAND POLY PIPE...
LONG 445 TRACTOR (A51243)
LONG 445 TRACTOR...
3in Poly Pipe (A49461)
PALLET OF BRAKE AND AXLE PARTS (A50854)
PALLET OF BRAKE...
