Help with fuel system question -BX2200
/ Help with fuel system question -BX2200 #1
rjmatt
Kubota BX2200
Hello everyone. I'm new to the blog, and the proud new owner of a used Kubota BX2200. I've had the tractor for about 4 months and have had no problems. However, yesterday I was clearing the driveway of snow and the engine started to slow/cough. It never died, but lost power. I shut it down, checked all the fluids, and started it back up just to drive it back to the garage. During that startup, and now as well, I don't hear the fuel pump when I turn the key. How do you recommend I troubleshoot? Could it be as simple as a blown fuse (where?), or does this mean the fuel pump is blown? It's been cold here in CT, but I do put diesel fuel stabilizer in the fuel...would the pump not make noise if the fule is gelled?
Any help would be appreciated..more snow is on the way!
/ Help with fuel system question -BX2200 #2
By hearing the Fuel Pump do you mean a defined click or clack noise? If so that may be the fuel solenoid being activated.:confused:
Does the tractor run well now?
/ Help with fuel system question -BX2200 #3
RJ,
Welcome to the board and to your BX.:) I had a stick hit the wires to the fuel pump. I had to rewire the pump. I know you were plowing snow which means the entire bottom of the tractor is exposed. If you picked up a stick on the driveway this would have occurred. Take a look at the wires to the pump and see that they are OK.
Other things to consider with a diesel fuel once you get the pump running are: 1. A clogged fuel filter, when was the last time they were changed? 2. Water in the fuel line, do you use a fuel conditioner in the fuel?
Hope you can solve your problem. The folks here will help u until you do.:thumbsup:
/ Help with fuel system question -BX2200 #4
Read the following!!!!!!!
If your indirect injection pump is shot your looking a huge chunk of money,
You dont have or need an electric fuel pump on an indirect injection diesel engine and I sincerely doubt the injection pump is bad as they last for many hundreds of hours of operation.
You have a gelling problem with the diesel fuel and its summer blend fuel.
I would heat the tractor up with a salamander/kerosene forced air heater to warm up the tractor before you use it (if you own one) or purchase a small salamander to warm it up(they come in very handy believe me) the purchase will not be a mistake for you.
You could add a splash of kerosene or gasoline to thin the fuel and after a bit of running it will thin the fuel out and reduce the gelling to all most none.
If you have water in the fuel which is most likely you will need to drain the fuel, change the fuel filters, and purchase new diesel fuel after you take the old fuel to a gas station for safe disposal.
Hey guys, thanks so much for the advice..keep it coming! Let me answer a couple of your questions and then I have another of my own.
When I got the tractor in October, I did the general maintenance of replacing the fuel filters, changing the oil, and a new transmission filter. Not to say that the fuel filters aren't clogged (haven't checked yet...see below) but they are not old. And yes, the tractor will start and run, but I don't know for how long since I parked it as soon as I had the issue. Since I'm not hearing the pump I just assumed I shouldn't run it.
I've got the tractor in the garage now, and fired up the kerosene heater as recommended. Once it warms up, I'll get underneath to check the wires (that would be great) and fuel filters as well. I'm hoping that it is a gelling issue as noted, but I have a question about that. Is it normal in a gelling situation to have the fuel pump not pump? In other words, normally I turn the key and hear the bzzzzzz noise of the pump, then turn to the glow plugs, then start the tractor. Right now, I don't hear that noise. Is that because the pump can't 'pump' in a gelling situation?
Again, thanks so much for the help. I'll be laying under it in a couple hours when things warm up!
/ Help with fuel system question -BX2200 #6
You do not have an electric fuel pump
as the indirect injection fuel pump does
two jobs; it pulls fuel from the fuel tank
and pumps the overflow unused fuel back
to the tank to aid in warming the fuel and
to keep it flowing as well as not wasting
any fuel.
its the shut down solenoid you may or may
not be hearing. All the Kubotas I evr dealt with
had manual decompression and manual shut down
levers/cables.
/ Help with fuel system question -BX2200 #7
You do have a small electric fuel pump and it has likely quit either a bad wire or the pump failed. It is about the same size as your fuel filters and they usually place it between the first and second filters.:)
/ Help with fuel system question -BX2200 #8
Yes your tractor DOES have an electric fuel pump. It also has 2 fuel filters, one next to the fuel pump and the other in the engine compartment. And yes you should hear a clicking sound when you turn on the ignition. If it not running it is either the wires got clipped as I said before or has failed. I have been on TBN since 2002 and I can not recall anyone saying they had to replace the fuel pump on a BX.
/ Help with fuel system question -BX2200 #9
You do have an electric fuel pump. The fuses are right next to the battery. The battery is behind the cowl right under the steering wheel. The fuse/fuel pump may or may not be the problem. My BX22 ran ok with a blown fuse, but I wasn't working it at the time, so don't know how the power was. I'd for sure get the pump working before you troubleshoot any further. I believe its the same fuse as the tail lights, so if you have tail lights, I think the fuse is good.
Kim
/ Help with fuel system question -BX2200 #10
You may find that the pump is fine once it is free of any gelling issue. The clicking noise is a part in the pump that shuttles back and forth to pump the fuel. You may also notice that a pump that is working correctly will change it's clicking with load and pressure... this is normal. These pumps are simple and do not fail very often. As others have said, you will find it between the two filters, under the tractor.
I expect you will find a little gel, gunk or ice in the line. Clean it out and you will be back working.
/ Help with fuel system question -BX2200 #11
It is the same fuse as the tail lights,don't ask me how I know this. Chances are very good that it is the first fuel filter and that it has water in it. It's the first thing that I would check.
As for the tractor not having an electric fuel pump, perhaps some should look at a Kubota manual sometime, cuz like $114.00 is a big price to pay for something that don't exist.
/ Help with fuel system question -BX2200 #12
Someone posted a long time ago that a fuel pump for a 95 Chevy 6.5 diesel would fit a bx23. I made note of that in case I ever needed one for my bx. Don't know if this is true or not.
/ Help with fuel system question -BX2200 #13
WHAAA?! I just checked that at diesel pros website and the pic looks eerily similar. the wire end plug looks different tho. can anyone confirm this too?
/ Help with fuel system question -BX2200 #14
any fuel.
levers/cables.
The fuel pump fuse is the 15A fuse with the Red/Yel wire.
If I traced the diagram correctly, the blinkers, and even the headlights would be effected if the fuse were blown.
Thanks to everyone, you have been incredible. Yesterday I warmed the garage, added a splash of kerosene to the fuel, added some diesel fuel stabilizer, and filled the tank with new diesel. I checked the wires to the fuel pump, and they appeared to be connected properly. I also checked the fuse and that looks fine. The tail lights, blinkers, and headlights all work.
I started the tractor and ran it for about 20 minutes moving snow around. I then parked it overnight, and ran it again today for another 20 minutes or so. I have had no problems at all!
Now, here's where I'm confused...the fuel pump is not making any noise at all. I get no sound when I turn the ignition key, yet the tractor runs fine. Can these things run fine without the pump? Do I risk causing damage running it this way?
/ Help with fuel system question -BX2200 #16
You can check the fuel pump by pulling off the line at the injection pump and then turn the key on and see if it develops any pressure. You will not hurt anything other than your engine will be running in a semi starved condition and it may not even run once the tank gets close to empty.
/ Help with fuel system question -BX2200 #17
I have a newer BX2350, and mine makes a clicking noise when ever it is turned on. It could be the main pump has enough suction to keep it running.
/ Help with fuel system question -BX2200 #18
Sounds to me that when the key is on but the engine is not running, you used to hear the electric fuel pump. If this is the case, you can take the line off the injector pump, turn your key to the on position without starting motor, and it should pump fuel. If it does, shut it down and reconnect, it's working. Most systems with an electric pump, the pump is switched on with the key to "prime" the system before startup. Just for clarification, this "stabilizer" stuff, do you mean anti-gelling additive? Diesel doesn't really go bad like gas. From what I remember, it actually grows a form of algae, but that takes a few years. When diesel gels, the waxes "solidify" and plug your filter. I use Power Service white bottle to prevent gelling, the Power Service 9-1-1 (red bottle) is for already gelled fuel. Add some of that and change your filter, and you should be good to go. As for hearing your fuel pump, check your fuses and the wiring. I have heard of the injector pump pulling just enough to keep the tractor running, as well as gravity. Somewhere there is a water seperator drain. I would drain that too, just in case. Won't hurt anything. Good luck!!
/ Help with fuel system question -BX2200 #19
Are you sure this is not the shut down solenoid opening?
These Indirect injection pumps are capable of suctioning fuel 40-50 feet
to power reefer unit engines without a wimper after priming and bleeding air from the suction and return side of the Direct Injection Fuel primer if used in a remote primer on the fuel tank mounted under the reefer floor frame rails.
The fuel pumps in the tanks are a strange issue as it sounds as if they bought the premolded tanks with pumps included from a manufacturer to fit the models in question which is also troubling as the damaged electric fuel pump would impede fuel flow if the electric pump was jammed.
/ Help with fuel system question -BX2200 #20
leonz
I have a Carrier reefer unit and it has a 12v lift pump about 18" from the injector pump.
Jim
Caterpillar 330C Excavator Service Manual (A63117)
Caterpillar 330C...
2009 GMC Sierra 2500 HD Pickup Truck (A61573)
2009 GMC Sierra...
Safety Basket Forklift Attachment (A61572)
Safety Basket...
2018 International DuraStar 4300 26ft. Box Truck (A61573)
2018 International...
Toro Z Master Professional 72in Zero Turn Mower (A61572)
Toro Z Master...
Like New! Kubota L2501 HST Tractor Package – LA525 Loader, RCR1260 Cutter
Like New! Kubota...
