4400HST block heater installation?
/ 4400HST block heater installation? #1
Mike_S
South of Kansas City
JD4400HST
This is the first winter my 4400HST has had the "opportunity" to stay outside and commune with nature all winter whereas it has always been parked in a heated basement garage.
What is the installation procedure in installing the $75 block heater in the water jacket -- from the parts dept. description, it sounds like it is a matter of draining the radiator, unscrewing a plug and screwing in the block heater and refilling the radiator. OTOH, that sounds too simple -- can anyone shed some light on what is needed for the installation of an OEM block heater on a 4400HST?
Thanks
Mike_S.
/ 4400HST block heater installation? #2
Shouldn't be any more difficult than that.
What part of it seems out of whack?
What is the part number?
Nothing seemed out of whack -- just did not want to get in over my head which I too often do with my DIY jobs -- this one appears easy.
P/N AR87167
Thanks,
Mike
/ 4400HST block heater installation? #6
I installed mine on my L4400 HST-1 and I had to remove a freeze plug and insert the threaded piece in place of the freeze plug. I took about an hour and a half taking my time. The heater came with a good set of directions as well.
2004 Quincy QSI500WNW31SG Air Compressor (A61572)
2004 Quincy...
2013 VOLVO A25F 6X6 OFF ROAD DUMP TRUCK (A62129)
2013 VOLVO A25F...
JMR TREE BOOM (A61572)
1995 John Deere 5200 45HP 4x4 Utility Tractor (A61572)
1995 John Deere...
Stertil Koni 18000lbs 4-Post Auto Lift (A61572)
Stertil Koni...
Caterpillar 980G Wheel Loader Service Manuals Vol. 1 and Vol. 2 (A63117)
Caterpillar 980G...
