Electronic Handheld Tach.....
/ Electronic Handheld Tach..... #1
Shmudda
Gold Member
Western Pennsylvania
Kubota BX24
I'm looking for one to adjust chainsaws. Want an electronic unit where all you do is hold it very close to the plug/wire. Must go to about 16K RPM reading.
Whats out there and what do you guys use?? Not looking to spend more then 60-70 bucks either.
Thanks,
Craig
/ Electronic Handheld Tach..... #2
Curious, no advice on your tach cause all I have is a mechanical one and with a chainsaw, well that would be just crazy. :confused2:
But when you say "adjust", are you talking carb ?
/ Electronic Handheld Tach..... #3
Have a look over on arbourists site. Theres a couple available, some better than others and the reviews are there. Sorry but the name of the recommended one escapes me but i think its the Stihl one.
I usually tune by ear
/ Electronic Handheld Tach..... #4
I seem to remember a thread on some forum said Grainger, Northern Tool, or Harbor.
I have two at work. We have to monitor and report speeds of fans on fan/heatsinks for PC microprocessors. It is an inexpensive one, but is also calibrated. It is good to within a couple rpm. It's about $250 with a calibration cert though. That, is dirt cheap compared to some though....
/ Electronic Handheld Tach..... #5
Stihl makes a decent one, as Scooby said. I too tune by ear, although I've used the Stihl tach.
Sean
/ Electronic Handheld Tach..... #6
We have a Stihl tach at the shop. Small and easy to use. I'll try to get info on it tomorrow.:thumbsup:
/ Electronic Handheld Tach..... #9
I use a Fast Tach, from Edge & Engine. Small, handy, but it is $85.
Yeah that is the one I use. Works great!!!
Many of the newer saws can rev very high, and will damage themselves if run too lean. For instance, my Dolmar 5105 needs to be tuned with a tach.
/ Electronic Handheld Tach..... #12
I went through this about 5 years ago.
You have 3 different levels of refresh rates. So buyer beware before spending your money.
Cheapie tachs for $20-$25 have a 2.5 second refresh rate. They work and I had one to start off. Just the 2.5 sec refresh rate got old when checking stuff. Cheap tach
The new Baileys and Stihl 7 and 8 are big bucks but still a slow refresh rate at 1.5 seconds. Take that money you would spend on them and buy the next level.
The best out there are .5 second refresh rate. Older stihl 5, echo 1000, stihl 302 etc. The NEW ones with .5 refresh rate are. IF I were to buy a tach today it would be this one
This one would be 2nd in line with .5 refresh rate too
/ Electronic Handheld Tach..... #16
I looked at a few of the links in this thread; there was a range from ~$40 to $350.
Funny, but hanging around this site since '98, I have found bazillions of uses for things I thought were single task items. Like my flatbed trailer for the tractor. It hardly gets used for the tractor. It has hauled cars, boats, lumber, firewood, hay, Cub Scout parade floats ect ect. The loader on the tractor does much more than I imagined when I first got one.
That laser tach is the one I have experience with. It is fast and simple; mostly point and shoot. Depending on the rotating object, might have to add a tiny spec of reflective tape.
You're right, it may be a challenge on a saw; it has to "see" something that is rotating.
Some day though, the OP may need to monitor the FHS in his PC if it overheats... :D. And verify his tractor tach. And the motor on the clothes dryer.
How is that "moderately priced" when the Fast-Tach is $85?
And the OP wanted something for a chainsaw ignition.
/ Electronic Handheld Tach..... #17
/ Electronic Handheld Tach..... #18
I just watched the video of this tach posted above on youtube. I dont care what they say the refresh rate is. It is way to slow for me and my likings.
I agree its a little slow, plus it doesn't store max rpm. I was just pointing out another "moderately priced" tach that seemed extremely suitable for chainsaws.
I personally could not afford an $85 tach for one chain saw.
But like RobertN mentioned, I've got a Fast-Tach that I can use on my car's, trucks, motorcycles (if I ever get the bikes rebuilt).
But to me the clinker in buying what was regarded as the best tach for the buck for chainsaws was when I went from 1 Stihl 021 to a Stihl 021, an efco MT3600, and a John Deere CS62 in 3 weeks, and then later acquired 2 Stihl 660's.
Especially with the 660's, which are both modded, it seems important to "tune" them for different bar lengths. I've got 24", 28", 32" and a 42" bar, and although I try to tune by ear I like the tach for setting the low idle and checking the WOT in the cut.
Now if you really wanted to save $$ there was a thread somewhere on AS that someone showed how to hook up a DM as a tach. I just got one from Harbor freight for free. Looked like to much trouble for me, as in trying to figure out how to put reflective tape on something to use an optical sensor, especially in the cut.
I need something I can pull out of a pocket w/ gloves on, point and shoot.
Others may be willing to put up w/ wires to save $$ or spend $$ to measure the speed of a PC fan, each to their own.
/ Electronic Handheld Tach..... #19
IMO the easiest way to set a carb without spending any money for a tach is.
Adjust carb till it 4 strokes out of the wood and cleans up in the wood as your cutting. Perfect IMO.
Here is a Dolmar 166 sounding like crap out of the wood 4 stroking and then listen to it clean up in the cut.
YouTube - Sachs Dolmar 166 30" 404 making 21" cookies
/ Electronic Handheld Tach..... #20
That is rough, having two 660's and having to decide which to use :D
Measuring PC fans is part of the job. Measure a lot of them. Thermals are a big deal, especially in compact chassis. The cpu fan has to work off the motherboard speed control, and match software rpm registers. Fan heatsinks usually are only 700-3000rpm. Measuring up to 20,000rpm on anything that turns in a circle is a side benefit.
,or spend $$ to measure the speed of a PC fan, each to their own.
John Deere D110 Riding Mower (A62679)
John Deere D110...
2017 Cadillac Federal 70 IN Limo - 30,529 Miles w Premium Coachwork by Federal (A63689)
2017 Cadillac...
1997 Fontaine FTW-5-8048WSAW 48Ft 34 Ton Flatbed Trailer (A64194)
1997 Fontaine...
Landhonor TP2-13-08D Skid Steer Mount Tree Puller  (A62679)
Landhonor...
John Deere 1025R (A64126)
John Deere 1025R...
(INOP) 2002 CHEVROLET 3500 BUS (A59823)
(INOP) 2002...
