Bursting Hydraulic Lines while snow plowing
/ Bursting Hydraulic Lines while snow plowing #1
cvettori
Western Ma
John Deere 790
Hello,
This is only my second post, I"ve learned so much already just by reading along.
Last week I was away on business and asked my brother in law to come plow my wife out of our driveway. He had a hydraulic line burst on one of the loader hoses directly after the valve. I assumed it was operator error, because he hasn't used my loader to plow snow with yet. So a trip to the local JD dealer and about an hour of newbie labor and I had it fixed.
Well tonight I was plowing a pretty sticky, wet 8" of snow and don't you know it, another hose burst on me. I guess I can't blame operator error (well maybe not) this time.
My question is, the tractor is about 10 years old, but only has 230 hours. The hoses do not look overly worn, or brittle. Are these hoses just old and bursting due to age? If this is the case, can I expect them all to burst relatively soon? So far they have been simple to fix, but I don't want to have one bursting every other time we get snow. Its only January, it could be a long winter.
Thanks for any advice that may be out there.
Craig
2001 JD 790
/ Bursting Hydraulic Lines while snow plowing #2
How are these hoses bursting? Blown out in the middle of the hose or ends coming off? Is this a JD blower? Have the hoses been damaged or worn? Metal showing?
/ Bursting Hydraulic Lines while snow plowing #3
We need a little more info about your equipment here.
Do you have a plow on the loader???
Were you just plowing with the loader bucket itself??
What lines burst?? Curl cylinder lines?? Lift cylinder lines?? Plow angle cylinder lines(if you have a plow)????
What were you doing when it burst?? Bucket dumped all the way and backdragging??? If so, that causes a extreme pressure in the curl circuit cause the bucket is actually trying to collapse the cylinder.
Again, give us a little more info and I am sure we can figure this out.
/ Bursting Hydraulic Lines while snow plowing #4
Ad this to the list:
Is the tractor stored outside?
Have you turned up the pressure?
OK, So I'll try to cover all of the questions.
1. Plowing with the loader and bucket, no plow
2. Both were curl function hoses that burst
3. Hoses breaking not exactly in the center, but definately in the rubber portion
not the metal.
4. The Hose tonight burst as I was curling the bucket at the top of the pile.
5. Tractor is stored outside (unfortunately, i want to build a garage asap)
6. I have not increased the factory pressure.
7. No noticable damage to the hoses, i.e metal showing worn rubber etc.
Thanks for the quick responses everyone!
/ Bursting Hydraulic Lines while snow plowing #6
Ok, so we know it was in the curl circuit.
Was it the lines that make the bucket curl, or dump??
And when you say you were in the pile curling when it happened last, were you curling up, or curling down (dumping). Because it you were curling down while backing out of the pile, this could possibly cause the hose that makes it curl up see extreme pressure (as mentioned earlier similar to backdragging).
If none of the above, I guess you can just chalk it up to hoses getting fatigued/weak, provided you are still in the normal operating PSI speced by the MFG.
Personally, I would put a guage on it to double check. If that is okay, I would replace the other hoses as well, because they probabally arent far behind. Provided you are sure it wasnt operator error, like some of the scenerios I mentioned. Having a lift hose fail could make for a dangerous situation.
/ Bursting Hydraulic Lines while snow plowing #7
not the metal.
Were the blown hoses on the same side (hydraulically or physically)? Rod side or piston side? Left or right? Were you creating extra force on the hoses with traction?
/ Bursting Hydraulic Lines while snow plowing #8
I think the age (10 years) and the fact that it's stored outside is the reason...bend your other hoses and look for cracking-I will bet you'll find some.
/ Bursting Hydraulic Lines while snow plowing #9
I agree. Its a 'normal' wear issue. I used to run a fleet of wreckers....... you can imagine how many hydraulic hoses I had to deal with. A blown hydraulic line is a regular occurance once a piece of equipment has a little age to it. Your BIL isn't to blame . Are the rest of them ready to burst? Its a crap shoot. I'd leave them alone until they are a problem. Might blow in a week, might last another ten or twenty years.
/ Bursting Hydraulic Lines while snow plowing #10
Interesting thread, I noticed one and only one of my hoses to my FEL getting rubber cracks. Stored indoors. Built FEL and had hoses made up at the same time. Only been about 7 years.
FORKLIFT (A56857)
FORKLIFT (A56857)
(APPROX. 20) 4' X...
12ft x 8ft Military Flat Bed (A57454)
12ft x 8ft...
2009 Honda Pilot AWD SUV (A59231)
2009 Honda Pilot...
WOOD GRABBER FOR MINI EXCAVATOR (A58214)
WOOD GRABBER FOR...
2021 MULTIQUIP WHISPER PORTABLE AC GENERATOR (A59823)
2021 MULTIQUIP...
