Looking For Odd Hydraulic Adapter Fitting
/ Looking For Odd Hydraulic Adapter Fitting #1
Steve Bosshard
Temple / South Mountain, Texas
JD 4310 and 3 cyl 820, IH 1086 and 806
About a year ago I bought a Hydraulic Multiplier from A&I Parts to give my IH806 a second remote to operate my JD530 baler and AC Tandem Disk. Works great UNTIL -
A few weeks ago the tongue broke on my HarroGator and pulled the Multiplier out of the Female ISO fittings on the 806, breaking in half both of the Offset nipples that go between the valve body and the male ISO fittings of the multiplier.
This adapter looks to be 1/2" JIC Male Boss with a nut and O ring that go against the valve body of the Multiplier and a 1/2" JIC Male that goes into the male ISO fitting.
(I hope I have the terminology correct - sure not an expert here).
Anyhow, this adapter / nipple can be rotated to bring the ISO fittings closer together or farther apart to match the Female fittings on the tractor. Trouble is these adapters are both broken in half and I cannot find a picture / catalog with a replacement. I have emailed A&I and also have a local tractor supply place looking.
Anyone else be down this trail before and know where I can find these odd ball adapters - I have spent many hours looking at different on line catalogs already. Thanks, Steve Bosshard, Gatesville, TX
bosshard@gmail.com
/ Looking For Odd Hydraulic Adapter Fitting #2
Steve, you are not going to find that "off the shelf", it's going to have to come from the maker of the valve. I am not familiar with A&I but Fasse has the same type setup-maybe they made the valve for A&I?
Short of that-if no parts can be found, then possibly two short hoses could be used instead of the offset fittings.
Thanks Kenny,
Turns out the Multiplier was labeled from The Ad-On Company, Kearney, NE. Same town as Fasse. No web info for the Ad-On Company - no reply from A&I Parts - just sent a note to Fasse with the Ad-On Co. Part Number 610180. Looks like Fasse may have acquired The Ad-On Company - will see. Steve Bosshard
/ Looking For Odd Hydraulic Adapter Fitting #4
Good luck Steve...The short hose thing is a good option also if they can't help.
Got in touch with Fasse on the telephone - their pn is 210180 and for $26.10 each they will ship in the morning. Durn little adapters just wouldn't pull a 20 ft Harrogator. Thanks for the assist, steve
/ Looking For Odd Hydraulic Adapter Fitting #6
bosshard@gmail.com
That nut and oring similar size to jic 1/2 probably means its an SAE 8.
larry
/ Looking For Odd Hydraulic Adapter Fitting #7
Steve, I'm a little confused. The fitting you describe sounds like a male O-Ring Boss (which has the same threads as JIC, but no flare) x male JIC. That's actually a very common fitting. especially in the size you describe.
Does this look your fitting? SAE 37? Flare (JIC) x O-Ring Boss (ORB) Adapter
If so, any decent hydraulic repair shop should have these on hand, and for a lot less then the $26 you said you just spent.
/ Looking For Odd Hydraulic Adapter Fitting #8
By the way, the terms "SAE" "Straight Thread" "O-Ring Boss" and "ORB" are all commonly used to describe the same connection.
The #8 fitting (for 1/2" port) has a 3/4-16 thread, same as 1/2" JIC.
/ Looking For Odd Hydraulic Adapter Fitting #9
HHG, this is what he needs:
This "offset" or eccentric fitting allows the male QD's on the valve body to plug into differently spaced female QD's on the tractor.
/ Looking For Odd Hydraulic Adapter Fitting #10
kenny, were you intending to post a photo or a link when you said "this is what he needs?" I'm not familiar with offset fittings. Is this an adapter where one side is parallel but not on the same center line as the other side?
That seems to be what you're describing, but I haven't actually seen a fitting like that myself.
/ Looking For Odd Hydraulic Adapter Fitting #11
Exactly. They would be kind of like the conduit fittings that have a "jog" in them.
Like this:
Conduit Nipples - Offset/Rigid & IMC Fittings
When you have 2 of these side by side, you could adjust them to give you different center to center spacing by turning them to match the tractor remotes.
/ Looking For Odd Hydraulic Adapter Fitting #12
Not the best pics, but here is the fasse fitting, you need more than just a jog in them so that you can set your exact width in the multiplier base. Has to have a tightner nut.
/ Looking For Odd Hydraulic Adapter Fitting #13
Thanks for posting the pictures. This is the first time I've seen one of those things. Showed it to some other people here, and they never saw one either.
Guess you learn something new every day.
2018 Chevrolet Suburban 4x4 SUV (A64557)
2018 Chevrolet...
2026 DEVELON DX27Z-7 EXCAVATOR (A65053)
2026 DEVELON...
2023 Bobcat E88 Excavator (A65579)
2023 Bobcat E88...
New/Unused ATS Grass Proof Cloth (A65583)
New/Unused ATS...
(1) HD 24ft Free Standing Corral Panel (A65579)
(1) HD 24ft Free...
90in. Work Bench (A65640)
90in. Work Bench...
