Snow Equipment Owning/Operating Cutting / Groving / Siping R-4 for snow
/ Cutting / Groving / Siping R-4 for snow
I was wondering if you could explain this a little more. I don't really understand what is being said.
I'll try...
An uncut lug had no features to help it retain snow on it's surface. It is smooth. Like a slick.
On a hard surface, only the surface of the lug is in contact with the ground making the whole tire perform about as well as a slick. You get a little bite from the edge of each lug, but they get fairly round after you put a few hundred hours on them and don't bit well.
One of the basics of snow tire technology, is that snow gets better traction on snow and ice than the rubber used in most tires. So if you can get snow to stay on the contact surfact of the tires, it will get better traction in hard backed snow and ice.
Grooving does 2 things to help traction:
1. It adds biting edges to the tire (the edges of my groove are also much sharper than the edges of the lug)
2. Probably more importantly, and unlike the wide spaces between lugs that are too big to hold snow well, the small grooves trap snow inside them. Because snow sticks to snow (think of a snow ball or snow man) the snow trapped in the groove provides a strip of snow on the surface of each tire lug and additional snow actually sticks to these strips that are trapped in the grooves and spreads from these "anchor" points at the grooves across the lugs of the tire. On my tires, in the last snow, each 0.2 inch wide groove was causing a 1/2" to 1.5" wide strip of snow to stay on the contact surface of each lug for the length of the groove. If I made the groove longer, the strip of snow would be longer and improve my traction. This is why I said if I did it again i would make the grove longer. A few additional groves would also help.
Did that make sense??
/ Cutting / Groving / Siping R-4 for snow #22
I'll try...
You did a very good job of explaining that!
James K0UA
/ Cutting / Groving / Siping R-4 for snow #23
Does that mean turf tires would be better because the snow will pack in between the tread blocks? What about R1s? They have very little tread suface that contacts the ground,
/ Cutting / Groving / Siping R-4 for snow #24
Now you have a good excuse - er, I meant reason, to own another complete set of rims and tires for the 'real' work of summer.
Looks like you have a pretty steady hand.
You can find lots of discussion on this at TBN but here is my take both based on 30 years of experience with tractors and trucks.
The answer is... it depends. It depends on the snow, it depends on the vehicle and it depends on the exact tire within each category that you are using.
But typically, in deep snow you need voids that are big enough to clear themselves of snow but small enough to still pack snow tight enough so it holds together under some torque. How big that is depends on the snow. R-4s are great at this, R-1s might be good also but may have too much void space is some situations causing the snow not to pack tight enough to get good traction.
In packed snow / ice turfs will usually be better and turfs with lots of groves and sipes will be best.
And if you drive in deep snow, packed snow and ice and are avoiding chains, then a combination of a turf tires and R-4 tires may be the ticket! Oh, wait, that's what I just made ;) Maybe we can call them R34 tires.
I'm very happy with the performance of the tires so far and will likely always get R-4 tires in the future over turfs or ags. I can always cut an R-4 to perform like a turf on hard packed snow, but I think it would be harder to do the same with an R-1 because you have so little contact area on the lug to work with. There just isn't much space to make groves and if you did you have to be more careful about the potential lug strength issues.
/ Cutting / Groving / Siping R-4 for snow #26
Very interesting post. Got me thinking (I hate when that happens)
I removed my R4's on the front and put on turfs for summer mowing but now run the turfs all year round. R4's with chains on the back. I now have a set of front R4's on rims on the garage shelf. Maybe I will groove them.
My problem is I have an area of slightly sloped lawn that I keep snowblowed and the only way I can do it is on a side slope and the front of the tractor slides down hill. Maybe I will pull the R4's off the shelf and groove them. It might help plus I have no use for the R4's anyway so no loss if it does not work.
Where can I get the knife/groover and what should I expect it to cost me?
/ Cutting / Groving / Siping R-4 for snow #27
/ Cutting / Groving / Siping R-4 for snow #28
Many tire shops offer siping via an automatic machine. Done a lot up here. The siping head puts evenly spaced groves, about 3/4" apart. The head is sort of auger shaped and turns the tire as it sipes if I remember right. There is a bit more chunking with siping but not terrible.
Other option is screw in carbide studs for better ice traction. I wouldn't sipe in the area where the studs are.
For best side slope performance, i would sipe and grove in the direction of rotation. Or in other words, perpendicular to the direction the lugs run. That way all your biting edges would be working to keep you from sliding down the side slope. I'd try a groove every inch and a pair of sipes half way between each groove. Since the tire is only for snow use when the rubber is rock hard and the traction low, I think the chance of the tire chunking is low as well.
Remember - the warmer the tire is before cutting (even with a heated knife) the easier it cuts. My tires were 10 degrees when I started and it took a lot of force to cut them Once I got the tires hot to the touch with the forced air heater, the heated knift went through them like butter.:thumbsup:
/ Cutting / Groving / Siping R-4 for snow #30
I'm wondering about the Rubber composition. Will it be too hard to get a proper grip?:)
Rubber composition is just one characteristic of tire that can contibute to good snow traction. Tractor tires are generally poor in this category. That's why you need to rely on biting edges and holding snow with grooves to get that snow on snow traction so you are not relying on the tractor tire's very poor (for snow and ice), rock hard rubber compound.
Good car snow tires have very soft and porus rubber and that type of rubber can actually get decent traction on ice. But this type of rubber wears quickly and would probably tear appart too easily for a tractor application in the summer.
/ Cutting / Groving / Siping R-4 for snow #32
Have you thought about trying to "re-face" your R4 lugs? ...putting on a sharp "edge" on the sides of the lugs? Actually, I guess with a the new tire, the edge of the lug was somewhat raised. Guess you can't get that new tire grip.... without buying new tires :ashamed:
I think you can do MUCH better than new tire grip by adding multiple biting edges that are sharper than edges are new. Just because an edge is rased doesn't mean it's sharp. The edge on a ski is sharp and it is just a 90 degree angle. Yet it can cut you.
You could "reface" the lugs but I wont bother because the large gap between lugs will just wear that new edge down quickly. The edge of a groove will stay sharp much longer.
We've had multiple snows since I did the initial grooves and they've worked great. But I'm thinking if I do need more traction I will do the fronts. I have only about 20-30% tread left and the little front tires my tractor takes are cheap. So if I destroy them (which I don't think I will) I'll just by new ones. would rather experiment on these old ones so that when I get new ones and want to cut them I'll have a little experience with fronts.
/ Cutting / Groving / Siping R-4 for snow #34
Hey gladehound, your tires look good, :thumbsup:. I do not know anything about siping/groving tires, but have a question for you: Have you given any thought to putting a XXXXXXX pattern across the lugs, :confused:? KC :D :D :D
/ Cutting / Groving / Siping R-4 for snow #35
Good question, I was going to ask the same thing. Seem like it might help with forward, backward, and potentially sideways traction.
/ Cutting / Groving / Siping R-4 for snow #36
Amazing. I have spent several hours this afternoon looking at grooving irons and techniques to do this to my 790 Deere, then stumbled across this thread. I'm glad to hear that it works.
/ Cutting / Groving / Siping R-4 for snow #37
I ordered the Ideal Heated Knives 250W Grooving Iron from PitStopUSA.com
Should arrive UPS Wednesday. I think it will help my front R4's. All I need to do is design a pattern. Not much to work with though the lugs are only three quarter to seven eighth inch wide.
You should try it and let me know how it works! :D Since my traction issues were with going strait not sliding sideways I made my grove perpendicular to the direction of travel. But your idea makes sense for all direction traction.
Usta - I might do the fronts to. Same issue, small lugs. So I was thinking of making the groove so that it doesn't break the edge of the lug anywhere. That should help maintain lug strength.
/ Cutting / Groving / Siping R-4 for snow #39
Sorry, I will not be any help trying this XXXXXXXX pattern out since I have no traction issues, ;). I was just thinking out loud for others that need help, :thumbsup:. KC :D :D :D
/ Cutting / Groving / Siping R-4 for snow #40
I did this on my 1970 chevy plow truck. It never leaves the farm so I'm not worried about tire wear/life. I have a wide set of off-road tires on it that were terrible in the snow. The center of the tire was solid all the way around, and the outer edges of the tire were mildly aggressive. I carved a 3/8" groove across the center section every 4" and I cut a 1/4" groove through all of the outer lugs. It made a HUGE difference. That was probably 7 years ago and the tires are still holding up great. Granted they see nothing but snow in the winter and gravel in the summer. I work the truck pretty hard and haven't chunked out any sections of tire.
2020 BOBCAT E55 EXCAVATOR (A59823)
2020 BOBCAT E55...
500BBL WHEELED...
2017 KINZE KNOTCHED SINGLE DISK FERTILIZER OPENER FOR 3000/3500 SERIES PLANTERS (6 ROWS) (A55315)
2017 KINZE...
2025 Stump/ Trench Bucket Mini Skid Steer Attachment (A56857)
2025 Stump/ Trench...
Caterpillar 2PD5000 5,000LB Diesel Forklift (A56857)
Caterpillar...
20FT X 12FT LIVESTOCK SHELTER (A58214)
20FT X 12FT...
