Cold starting a new 3520
/ Cold starting a new 3520 #1
LHS Inc
Gold Member
Eastern Shore, Maryland
JD 3520 eHydro w/300CX FEL
I've seen this topic beat to death but not on a 3520 so here it is. When I push in the key for the pre warm start the pigtail lights up on the left side of the dash and a message scrolls across the display saying wait to start but it seems to long a wait. Does anybody wait for the light to go off? Mine will start right up with out doing this but I want to do the right thing. The coldest I've started it was just below freezing. It starts better than anything I've ever owned. I mean this thing doesn't hardly make one full churn and it starts right up warm or cold. Just to sum it up I'm not having any problems I just want to start out doing things the right way. I believe when you're good to your equipment it will be good to you. Thanks for any info.
/ Cold starting a new 3520 #2
I think you are fine. The manual does not say you have to wait for the light. I don't know about the 3520, but some JD tractors have sensors that prevent the air heater from turning on at warmer temperatures even though the light may still come on.
From manual:
If temperature is below 0deg C (32deg F), follow the cold weather starting steps in this section.
9. For cold weather starting, use the intake air heater system. Activate the intake air heater system by pushing in the ignition key switch with the key, and holding it there for the required time:
10 - 15 seconds for temperatures as low as -18deg C (0deg F).
15 - 30 seconds for temperatures below -18deg C (0deg F).
/ Cold starting a new 3520 #3
Great Question. I've questioned this in my mind as well. I have a 2009 JD 3720, and the same thing. push in the key...LED says "Wait" but I've never waited until that went away...seemed too long. IMO, the manual is not very helpful under this section. I just put in the key for 10-15 secs. and it starts right up. I read somewhere on this site somebody said "if it works, just keep doing that" - makes sense to me.
/ Cold starting a new 3520 #4
That is a manual system. You can preheat as long as the battery holds out, but 20 seconds should be plenty unless it's really cold.
/ Cold starting a new 3520 #5
I have a 99 4600. When the temps are below 20 degrees, i just bump the throttle, push the key in and count to 10. Have not had a problem.
Good Luck
Chuck D.
/ Cold starting a new 3520 #6
I only pre-heat for about 5-10 seconds when below freezing, and not a problem in 11 years of WI winters. If I don't preheat, then it starts but passes some bluish smoke for awhile. So I preheat a bit to avoid the smoking.
Like what chuck diesel said. :)
/ Cold starting a new 3520 #7
all of you guys have intake heaters as opposed to glow plugs?
/ Cold starting a new 3520 #9
I've been told that the newer 3720s, like my 2009, does not have glow plugs.
/ Cold starting a new 3520 #11
I've got a new to me 2008 3520 and a couple recent cold starts made me wonder what is happening. The dealer mentioned something about pressing in the key heats something but we didn't get into the details. I guess I should have read the manual, but just it starts via just turning the key just like my truck (gas burner).
I thought it automatically ran on glow plugs at first and then, once adequately warm, shifted over to regular operation. Apparently not!
So what is going on when the motor sounds like its running on glow plugs and smoking some? Is the fuel just not fully burning? Is it running rich like a choked gas motor?
I discovered that use of block heater prior to starting helps it warm much quicker. Now I'll try holding the key in for 10 seconds but that seems to probably only give it an initial shot of warmed air so seems like it would only help initial startup and have no affect on warm-up. Right?
Thanks.
Dave
/ Cold starting a new 3520 #12
The glow plugs are just for starting. A diesel engine runs by the heat of compression (no spark plugs). The glow plugs preheat the air so it can begin running on its own. They have no effect after it starts.
/ Cold starting a new 3520 #13
i also have a new 3520. after looking in the tech manual & checking with the dealer the injection pump has a "cold start advance device" in addition to the heater in the intake. when the temp gets down around freezing it changes the timing of the pump that makes the engine run slightly faster with a lot of extra knocking & greyish/black smoke. this lasts a short time then it returns to a smooth idle and runs normally. my dealer says this device is on all newer diesel engines to meet gov smog standards. i was concerned the first time mine did it but he said it was normal & to be concerned if the motor doesn't return to running normally after a short period of time. hope this helps...............bud
/ Cold starting a new 3520 #14
Yeah Bud....thats the odd noise...knocking and such and smoke. I originally thought that was glow plug operations. I guess the smoke is poorly combusted mix.
JD755 - thanks! I always figured, from my construction days and watching/listening to big Cats firing up when cold, that the glow plugs ignited the fuel for a while until the engine got up to temp in the same fashion that spark plugs work in a gas motor. I know they sure sounded 'knocky' and put out lots of smoke!!
/ Cold starting a new 3520 #15
The engine will smoke a little upon starting but should quit after a it warms up which should take less than a minute. Even with my engine block heater mine smokes just a little on startup which is normal.
If your engine smokes a little on startup you shouldn't be concerned but if it continues to smoke then there could be a problem. Is it hard to start or does it fire right up? Do you have fresh fuel in the tractor? Have you checked the fuel bowl for any condensation build up ?
You may want to try leaving the key turned on for a bit longer before starting it. I leave mine on for at least 15 seconds before starting. Starts easy with very little smoking.
/ Cold starting a new 3520 #16
It fires right up. I put Power Service white bottle treatment in the fuel before it got cold, but don't really know how old the fuel is because it was in there when we bought the tractor and since we haven't had hardly any snow, I haven't had too many reasons to run it. Still about 1/3 tank. I believe diesel doesn't deteriorate as fast as gas though.
99% of the smoke quits once she's warm. Just a little haze when the lights just right.
I'll try pushing in the key first this weekend! And the block heater!
Going to change the oil, so another excuse to fire her up and run her around a little.
/ Cold starting a new 3520 #17
Dmac
Pushing in the key before startup will heat the intake air and reduce the smoke. Just as well use it, as that it is what it is for. :)
And by now, you've prolly read that in the manual too. :D
There are no glow plugs as indicated. Apparently that is old technology, for better or for worse. ??
You need more tractor seat time. :cool2:
/ Cold starting a new 3520 #18
You would think with the electronic system they have, a light would come on to tell you when it's ready.
/ Cold starting a new 3520 #19
Use of a cold start device primarily reduces the beating that your battery and starter take. While the blue smoke, white smoke and misfiring isn't nice, it won't hurt the engine. So use the cold start device when you need it. If your engine readily starts at 10F, don't feel like you are hurting anything firing it right up. Contrary to popular thinking, the CSD can help keep the engine running, or reduce white smoke if you activate it AFTER the engine starts! I have seen white smoke go away when glow plugs are activated on a running engine at -40F, and then start again when the glow plugs are turned off. 99% of operators don't know this, and don't need to!
More important is to run the engine in the 1200 RPM to 1500RPM range (generally for small tractors) while it's cold. Camshaft lobes are often lubricated by slinging oil. If you hold low idle at extreme low temperatures, that is bad because you might not be getting normal lubrication. I have seen Kubota engines with the lobes worn half off because of warming up at low idle repeatedly. 1500rpm warmup cured it, but didn't pay for the new camshaft and lifters.
Likewise, your hydraulic oil is thick like honey. The faster you spin the pumps the more you starve them. So high idle would be a dead wrong way to warm up a tractor too.
Stay around the 1/3 throttle range. After a minute or two start driving the tractor if you need to. Think it has to sit still during warmup? NOPE. That's an old wive's tale. Just don't make it work hard while cold. Wait until the thermostat opens and the hydraulic temp is maybe 32F or higher before you put the engine to full load.
Do this and you will probably never have any cold start damage.
/ Cold starting a new 3520 #20
Good tips guys! Thanks! Got the manual out and looking through it now. I'd been warming at low idle. Figured slower revs is better...will kick it up a bit. Manual says start at 1/3 throttle and set to 1/2 to warm it. I'm going to see what gets me to 1200 - 1500. 1/2 seems too high (from my computer chair anyway).
beenthere...you're right! I need more seat time! In hindsight...I need more land! That would lead to more seat time!
Dave
2018 ALLMAND MP40-8B1 PORTABLE (3) PHASE GENERATOR (A63276)
2018 ALLMAND...
2020 VERMEER LP873SD1 VAC-TRON VACUUM TRAILER (A63276)
2020 VERMEER...
Adams 5 T Fertilizer Spreader (A63688)
Adams 5 T...
2016 Freightliner 114SD T/A Lely 3,300 Gallon Septic Wet Vacuum Truck (A61573)
2016 Freightliner...
2015 John Deere 310SL 4x4 Extendahoe Loader Backhoe (A61572)
2015 John Deere...
213081 (A64276)
213081 (A64276)
