Miller mig, what pressure to normally run
/ Miller mig, what pressure to normally run #11
It's all about shielding. If you can run at 12 cfh with no porosity, Turning it up to 24 would use 2x as much gas. If all is running well, Turn it down and save some $$. Your welds will tell you what to set it at.
/ Miller mig, what pressure to normally run #12
This is my take.
And your guage is probabally indeed CFH and NOT PSI.
Basically, take some scrap steel and start turning it down until the welds start to get pin-holes in them (porosity). Then turn it up a tad. Any more is just wasting gas.
/ Miller mig, what pressure to normally run #13
It could be either. My Harris gauge that came with my Lincoln is in PSI but my floating ball gauge regulator, Victo I think, is CFH. I was told that PSI is used for ease of set up since you don't need to flow gas but is not as accurate. I've never had a CFH meter in a round dial gauge, just the floating ball style that requires gas to flow to be set up.
Thanks guys, this gives me a good idea what to run, and save me a little gas also. thanks again. Allan
1965 Fontaine PS2824SP 28FT 15 Ton S/A Flatbed Trailer (A59230)
1965 Fontaine...
2019 Ford F-150XL (A60462)
2019 Ford F-150XL...
404 (A52706)
404 (A52706)
2016 Textron T/A 15 Ton Dovetail Equipment Trailer (A59230)
2016 Textron T/A...
2018 Ford Escape SUV (A59231)
2018 Ford Escape...
Freightliner Columbia (A61307)
Freightliner...
