FORD 4610 PTO
/ FORD 4610 PTO #1
challengr
FORD 4610
Is there a way to soften the hydraulic engagement of the PTO on a FORD 4610 with independent PTO, keep shearing rotary cutter shear pins.
/ FORD 4610 PTO #2
lower engine rpm so that it is low but won't stall under pto load , and feather the control in over 2 seconds?.. tis what my 7610s manual says to do..
soundguy
/ FORD 4610 PTO #4
You can install a feathering stop. Part number E7NNC766AB. It has a stop bolt you push the lever up to, when the pto starts turning, you flex the lever past the bolt to the fully engaged position.
