Trailer for L5740 or M5040
/ Trailer for L5740 or M5040 #1
ITHINKICAN
Gold Member
Fort Bend, TX
Kubota
We intend to get one of these two tractors. We'd like to start shopping for our tractor.
L5740 HSTC - with FEL and probably one or two other items; shredder, box blade, disc
Tractor weight - 4233 (Tractor with cab - but dont know weight of attachments)
M5040 HDC - with FEL and probably one or two other items; shredder, box blade, disc
Tractor weight - 5335 (Tractor with cab - but dont know weight of attachments)
Any help would be much appreciated.
Thank you!
/ Trailer for L5740 or M5040 #2
Just remember, when you add a brush hog, you might need more trailer lenght, maybe more than you had in mind. It will give you more weight on the hitch, being you have to make room for the brush hog by moving the tractor closer to the front of the trailer, not to bad on a gooseneck. But have to watch for that on a hicht pull type trailer. Not trying to tell you what to get, just trying to help.
/ Trailer for L5740 or M5040 #3
My current trailer is probably well suited for your needs. Here is a description, and photo.
20' x 83" car hauler
8" channel frame, 3" channel crossmembers, 2 6k axles, 1 brake axle, 10k drop leg jack, 2-5/16 bulldog coupler, 6" channel wrap tongue, diamond plate fenders, raised floor, treated floor, break a way kit, rub rail, brace in center of fenders, clearance lights, receiver tube in rear, slide in ramps
Total cost = $2690.00 new
/ Trailer for L5740 or M5040 #4
I would want at least a 10K trailer but a 12K would be better to allow some growth for things like loading the tires, future tractor, ect. 20' is a good length. I have a 18' trailer and it gets real short real quick.
Make sure your truck and hitch are also up to the task.
Chris
/ Trailer for L5740 or M5040 #5
You didn't mention what truck you are pulling this with. I hope it's at least a 3/4 ton.
I have an M5040. With loader and 6' cutter, I figure it's close to 8000#. I haul on a 20+4' 14,000 GVW gooseneck. Handles very well, fits well. Maybe a bit more than the minimum needed, but I'd rather have more rating than be over rating. My trailer was bought primarily for hauling a mini excavator and skid steer, but also is well suited for the tractor.
In the past, I hauled a M4700 with loader on a 7000# 20' car hauler and a half ton truck. It was overloaded and I only did it a couple of times.
Although the cost is higher, a gooseneck is much more stable and capable carrier.
Make sure you have plenty of length. It allows you room to adjust the tractor for balance plus if you overhang the rear even a short distance, you may have problems with storing the ramps.
Ken
/ Trailer for L5740 or M5040 #6
I would go with at least a 22 footer. It isn't that much more money and the extra 2 feet would be money well spent.
/ Trailer for L5740 or M5040 #7
Agreed. I am always much more comfortable towing an equal load on a gn vs. a bumper pull.
This is a style of GN that I think I will buy on my next go around. I like the ability to side load pallets, or implements over a traditional style Gn Lowboy. I also like that the trailer sits low to the ground for loading wet or muddy equipment, coming off of a flatbed is no fun.
/ Trailer for L5740 or M5040 #8
While I agree that a low bed is much better for loading equipment, it limits the width of equipment that can be loaded. Depending on how the wheels are set, an M5040 will probably not fit between the fenders on the above pictured trailer.
A higher deck "over the tires" provides much more width for loading equipment. My car carrier was like the above pictured trailer and I had about 1-1/2" total clearance for the tractor between the fenders.
Ken
/ Trailer for L5740 or M5040 #9
I keep a 27+5 tandem dual around for hauling the wide or heavy loads. If I could only have one trailer, and it had to handle just about any task, it would probably be a flatbed gooseneck, for the reasons you mention above. However, I just assumed the OP was looking to haul the M5040, or whichever M class tractor he ends up with. Looking at some online specs, it appears the M5040 has an overall width of 73", leaving 10" of clearance on a 83" trailer.
/ Trailer for L5740 or M5040 #10
The problem with a lot of lowboys is the spacing between the fenders. My older car hauler trailer only had about 2" total spacing with the M4700. I doubt my M5040 would even fit in there since we are in hill country and I have the wheels set for maximum width.
Ken
/ Trailer for L5740 or M5040 #11
Ken
Car haulers come in 2 standard widths. 76" and 82". The 82" is the only way to go. I have used the 76" and its a tight fit but doable.
Chris
/ Trailer for L5740 or M5040 #12
Chris
I have the wide one. As I said, only a couple of inches clearance with the M4700.
Ken
/ Trailer for L5740 or M5040 #13
Towed with a bumper pull before my current trailer and this gooseneck tows much nicer. The longer deck allows you to position the load perfectly.
2018 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A59911)
2018 FREIGHTLINER...
Caterpillar D9 Dozer Parts and Service Manuals (A63117)
Caterpillar D9...
Merlo MF34.7 CS (A62177)
Merlo MF34.7 CS...
John Deere 4955 (A64119)
John Deere 4955...
2022 EZ-GO ELITE...
2014 Ford Escape SUV (A61574)
2014 Ford Escape...
