One pump, 3 cylinders how to split it up?
/ One pump, 3 cylinders how to split it up? #1
allarizonaparts
Bullhead City AZ
Cadet 2135, 04 Duramax, Diesel log splitter
First off I'm new to the forum and I've searched but can't find the answers to my problem. We had a trucking company and our best mechanic taught me that if you don't know the answer just ask, theres people out there that knowthe answer so here is the questions. I have a log splitter with a push ram that has a 5" bore and a 24" stroke with a 2" rod. I built an extada-crane that the lift cylinder is 3" and an 8" stroke. The extenda-cylinder is 2" with an 18" stroke. The pump is a Haldex/Barnes 16 gpm pump powered by a 10 hp diesel engine. I put in a Prince adjustable priority flow divider. The 5" ram moves at around 8 gpm on the excess port. The priority port goes to the crane and and I have it adjusted to about 3 gpm so it doesnt move to fast and hurt somebody or tear itself up. Where is the rest of the fluid going because the 5" ram is moving so slow? It has a 12 gallon tank with an open breather. I'm thinking of putting on a 2 spool valve for the crane with a closed circuit. The inlet outlet ports of the valves are 3/4" for all of them. If I put the closed circuit on the crane end would the main ram have all the flow or am I missing something?
/ One pump, 3 cylinders how to split it up? #2
If the pump you are using is a Barns 2 stage pump, the fluid is flowing all the time, and what is not used goes to tank. Just use a log splitter valve and another 2 lever valve for the crane and whatever, maybe log lift. You will have full flow from the two stage pump. If the crane or log lift moves to fast, install a needle valve to control the flow.
/ One pump, 3 cylinders how to split it up? #3
Welcome to TBN:D
You can NOT put a CC valve in your system, so forget that idea...If you use these calculators (left side of the page, "force and speed") you will see that at 8 GPM, that cylinder is only gonna extend at 1.6 inches per second.
I think the better way to plumb your setup is to loose the priority valve so you have full flow through all of the valves, then you can use inline flow restrictors on the work ports of the crane valve to control speed. The use of 1/4" hoses would help also for the crane cylinders.
/ One pump, 3 cylinders how to split it up? #4
Welcome to TBN:D
Fully agree. I see no need for a flow divider, and it probably is hindering.
/ One pump, 3 cylinders how to split it up? #6
to the OP.
Your priority flow divider is a good choice IF you want to operate more than one function at a time. It will keep the ram speed constant regardless of what you do with the by-pass or excess flow. NOTE: When your operating pressure exceeds the the two stage kick down point you potentially not have any flow for the by-pass circuits.
What you may want to consider is installing the priority valve in the power beyond port of the main ram valve. This would allow you to reduce the flow to your auxiliary functions and give a more constant speed with out excessive pressure loss like needle valves create.
A couple of draw backs with the priority flow divider are:
These work via pressure drop so you are creating heat. Estimate 150 - 200 PSI loss average.
If the priority flow is blocked all flow will stop to all functions.
Roy
/ One pump, 3 cylinders how to split it up? #7
Flow dividers are useful, when you have to operate simultaneously synchronized actuators.
Priority valves are useful when you secure flow to a part of the system (sub system) that needs to be able to operate at the same speed, independent of pump rpm (flow). Power steering on a tractor is such a sub system.
Skip the flow divider on your log splitter. It will only do more harm than good for you. Like limiting your splitting cycle time, and creating unnecessary heat losses....
Thanks for the input:) I've read your posts and it got me to thinking....
I think I have the solution. I looked at how it was plumbed without the extenda-crane. ( just like an ex-tenda backhoe ) I ruined a fender because it didn't have enough reach. I have a 3/4 input output 3000 psi detent valve for the 5" push ram without a power beyond conversion. The pump is a 2 stage 16 gpm haldex. I agree with getting rid of the priority valve!! The other valve for the crane is a 2 spool with power beyond. I don't want to buy another "main" valve with pb so what I'm thinking is instead of the priority valve is placing a tee in the place of the priority valve and a closed circuit to the crane giving the push cylinder all the flow. To slow down the crane from the 16 gpm flow inline needle valves to the work ports. Does all of this seem reasonable? I'm going to post pics as I finish it. Clint
/ One pump, 3 cylinders how to split it up? #9
Clint, you can not use a CC valve-end of story my friend, and no Tee's on the high pressure lines. The last valve in the chain does not need to be PB equipped, so plumb that one last with the OUT port going back to the tank.
/ One pump, 3 cylinders how to split it up? #10
My understanding of allarizonaparts situation is this. He is not talking about a CC valve. He is talking about a closed circuit. If you have two valves in series, The lever that you operate will have full hyd flow, and can be feathered. The valve first inline will have priority. I would install a two spool valve with PB first inline, and then a Prince log splitter valve next. This setup will do what you want. If any cyl is to fast, either feather the valve or install a needle valve to control the flow. If you are thinking heat build up, the crane probably will not be needed for a lot splitting. It will depend on the weight the crane is lifting as to whether the valve will be using high GPM's or low GPM's. In the normal splitting mode, you will be using the log splitter valve, with full force.
/ One pump, 3 cylinders how to split it up? #11
I would advice having the most POWER using and frequent CV first in line, to minimize return flow power losses through the rest of PB valves.....That would put the splitter CV first in the series...Would of course require a PB capable splitter CV....
will still need to feather with needle valve, needle valve will make just make feathering more "responsive"...
/ One pump, 3 cylinders how to split it up? #12
I really don't understand what you are saying. If you mount a two spool valve with PB on the log splitter unit, the flow is going to the two spool valve first, and then to log splitter valve. One of the spools would work the log lift, and the other could would work the crane. If those spools are not being used, the full flow will go to the log splitter valve, with full flow.
/ One pump, 3 cylinders how to split it up? #13
since the PB require separate return from the PB host valve, it will be less back pressure, on return from splitter cylinder (which uses most of the flow gpm)
so when operating splitter cylinder a minimum of flow will enter and go through the down stream two spool valve.
if the two spool valve is upstream the splitter valve, all flow to splitter valve will have to go through the two spool valve, with more power losses as a result...
K??
K??
Makes perfect sense. I was trying to get away from having to buy another valve but looks like it's time to find a pb single spool detent valve and make this one the first in line then run the pb to the 2 spool. If I would have been on here earlier I would have saved money and not given myself a headache on how to poor boy it. Thanks, Clint
While I'm spending the money on another valve I'll have to order a couple of needle valves and THEN it should be done and done right. Anybody need a priority valve and a detent valve? I'm soon to have extras.....;) thanks again. Clint
/ One pump, 3 cylinders how to split it up? #16
Take a look at this valve by Prince. It is an automatic log splitter valve. It has PB and is connected to a two spool valve downstream like this . RD-5200, and another two spool valve for log lift and wedge lift.
Here is a log splitter all set up for the two sets of valves. Look at post #26.
http://www.tractorbynet.com/forums/power-trac/183187-log-splitter-3.html
You could do the same thing.
If you use a regular log splitter valve the out of log splitter valve must go to tank, and is not recommended for a two valve setup.
http://www.princehyd.com/Portals/0/products/valves/LS3000InstS.pdf
/ One pump, 3 cylinders how to split it up? #17
I think once you start playing with hydraulics, you will always find a use for that priority flow valve. Put it with the spare parts.
2017 Ford Explorer SUV (A64557)
2017 Ford Explorer...
2023 Kubota L3560 Compact Utility Tractor with LA805 Front Loader (A63689)
2023 Kubota L3560...
2013 Vermeer Vac-Tron LP855SDT T/A Vacuum Trailer (A64194)
2013 Vermeer...
2020 FREIGHTLINER M2 4X2 26FT BOX TRUCK (A67147)
2020 FREIGHTLINER...
2020 23 Ft. Godfrey Marine Hurricane Boat with 26ft T/A Boat Trailer . (A64557)
2020 23 Ft...
2024 JCB 35Z-1 EXCAVATOR (A65053)
2024 JCB 35Z-1...
