CountyLine Carryall
   / CountyLine Carryall
Oh, and I assume it is pretty easy to add a simple deck to it?
   / CountyLine Carryall #4
Yes it's a good buy, can be used as a carryall platform, weight box, and my favorite as pallet forks and I rigged them up to attach to my buckket. I find it very good for collecting brush, tree branches cut logs etc,
All the ones I've seen come with pre-drilled holes in the angle irons for attaching things.
Go get it.
Go get it.
Do you have one? How has it held up?
Also, do you think it will fit in the back of a Ford Explorer?
   / CountyLine Carryall #8
I love mine and use for moving just about everything...
yes it will fit in a PU truck...two guys can easily load it...
[edited] sorry "Explorer"....I think it might but don't hold me to it...
get some 2x8 PT and some carriage bolts to make a simple platform deck...
get the bolts, nuts and washers etc. while you're at TSC and save some $ by buying by the pound rather than the package at other stores...
Thanks. Still not sure that I will get it. I'll have to check it out when I go to the store tomorrow...
The BX25 has a standard cat 1 3-point hitch and not a limited cat 1 hitch, right?
RIMS AND TIRES (A50854)
RIMS AND TIRES...
2006 X-L SPECIALIZED 40TON RGN (A50854)
2006 X-L...
FUEL TANK/TOOL BOX COMBO (A50854)
FUEL TANK/TOOL BOX...
2014 MACK GU713 WATER TRUCK (A51243)
2014 MACK GU713...
More info coming soon! (A49346)
More info coming...
2012 CATERPILLAR 259B3 SKID STEER (A51242)
2012 CATERPILLAR...
