CountyLine Carryall
   / CountyLine Carryall
Oh, and I assume it is pretty easy to add a simple deck to it?
   / CountyLine Carryall #4
Yes it's a good buy, can be used as a carryall platform, weight box, and my favorite as pallet forks and I rigged them up to attach to my buckket. I find it very good for collecting brush, tree branches cut logs etc,
All the ones I've seen come with pre-drilled holes in the angle irons for attaching things.
Go get it.
Go get it.
Do you have one? How has it held up?
Also, do you think it will fit in the back of a Ford Explorer?
   / CountyLine Carryall #8
I love mine and use for moving just about everything...
yes it will fit in a PU truck...two guys can easily load it...
[edited] sorry "Explorer"....I think it might but don't hold me to it...
get some 2x8 PT and some carriage bolts to make a simple platform deck...
get the bolts, nuts and washers etc. while you're at TSC and save some $ by buying by the pound rather than the package at other stores...
Thanks. Still not sure that I will get it. I'll have to check it out when I go to the store tomorrow...
The BX25 has a standard cat 1 3-point hitch and not a limited cat 1 hitch, right?
2021 Delta Redirective Crash Cushion 75000 (A49461)
2021 Delta...
2007 TRANSCRAFT 40X96 FLATBED (A50854)
2007 TRANSCRAFT...
Sakai TS160 TTS5 Pneumatic Asphalt Roller (A49461)
Sakai TS160 TTS5...
2018 INTERNATIONAL LT625 SLEEPER (A51219)
2018 INTERNATIONAL...
SHOP MADE  MANIFOLD TRAILER (A50854)
SHOP MADE...
2018 International WorkStar 7400 T/A Dump Truck (A50323)
2018 International...
