BXpanded snow plow?
/ BXpanded snow plow? #1
bellweather
Western MA
Kubota BX22
Anyone have an experience with this product? Care to provide some comments pro/cons?
Thanks
/ BXpanded snow plow? #3
I purchased the Front End Loader stand and the hitch for my new BX1860 and both worked as advertised. I like both of them.
/ BXpanded snow plow? #5
Seems overpriced to me....
Craigslist for a used 6' plow for less than $200 and cut to size, and even if you are not a welder, you could get a shop to make a braket for $100 or so...
Just a thought....
/ BXpanded snow plow? #6
For that kind of money you can do alot more. This is my setup - I paid $50.00 for the plow (found it on craigslist) and have about $30.00 in plate and hardware. I am sure that is a great setup but that's a ton of money to spend on a bucket mount snow plow.
/ BXpanded snow plow? #7
I dont know.i think it looks like a good lookin well thought out rig.Id like to see how it hooks to your bucket ,isnt any pics of that.Says no welding or drilling??must be a wedge type design,you wedge your cutting edge into?Wonder how it could backdrag if so?
ALAN
/ BXpanded snow plow? #9
Good install video.Id like to see one of someone plowing a gravel drive with it to see how its doing.Couldnt find one
ALAN
Thanks for the comments...I was hoping someone would have had some actual experience with this product....guess it's not a big seller.
/ BXpanded snow plow? #11
I just looked at the link to this product (Dec 29, 2010) and there are no reviews on it. I bought the Kubota frame and snow plow when I bought a BX24 in 2006. I miss my front end loader in the winter, though, for moving stuff. So I was thinking about this set up, too. Maybe I will fashion a set of forks to drop over my snow plow so I can move the 90-gallon trash container to the street and move wood around.
/ BXpanded snow plow? #12
Actually, it's selling well. Many of our customers don't frequent TBN. Also, since the snow season has just started, many have had little chance to use their equipment.
Good to hear that it's selling well. I would love to read some owner reviews and see a video of one in action (atually plowing snow under tough conditions). How recently was the product introduced?
/ BXpanded snow plow? #14
We introduced it mid-winter last year. We were able to give it a good work out with the unusual weather (record snowfall) last year, but weren't able to get everything together for videos. Here in North Carolina, it's pretty tough to get a good snow and a video operator together at the same time. We had hoped this last storm would give us that chance but it didn't work out. We had everything arranged and we got a pretty substantial snowfall, but it all melted from the roads.
/ BXpanded snow plow? #15
After looking at that setup, I'd say that the price isn't out of line. Looks well thought out and appears to be high quality...A bargain compared to the $2500 I paid for the power angle for my RTV.
My only concern would be the stress on the lift arms etc...I suppose I you behave, that wouldn't be too much of an issue.
Good idea...
/ BXpanded snow plow? #16
Tractor people are famously cheap.... Uhhh I mean frugal.
The thought of paying anything for any implement is too much =).
That said I've got one of BXpandeds plows.
I like it a lot.
I've only used it in one storm so far (4") and it made a major difference in the time it took to clear my 600' drive. Set the angle to 15 to one side. Made one pass down to the main road and then turned around and drove back to the garage and I was done. That same job would have taken me 30 min with the loader due to constant need to empty the loader.
I've got a rear blade, but with the BX if you've got more than a few inches of snow you run out of ground clearance moving forward. Using the BX blade to get 90% of the snow, and then the rear blade for the final scrape seems to work quite well for me.
The county saw fit not to plow the neighborhood roads this storm, and only that big state road was plowed. So I used my little plow to open up the road out to the state road. (probably 1/2 mile). The BXpanded blade plus rear blade made short work of it... and we were down to bare pavement the next day before noon. The rest of the neighborhood had snow pack on their street for 2 more weeks.
The only problem I've seen with the blade is there is not quite enough resistance for the blade sliding on the bucket. I've got the chain&binder tight as I can get it, but it still allows the plow to slide left/right on the bucket. The chain and binder combination that came with mine seems to be of a length that leaves me just between too loose and too tight to close the binder. I may look into replacing the binder with a screw type that would give a bit more adjustably of tightness.
All in all a HUGE improvement in my ability to clear snow... absolutely worth the cost in my world.
/ BXpanded snow plow? #17
Hi JDonovan, Glad you like the blade. We appreciate an objective view of our products.
There is a provision to adjust for the "not quite tight enough chain" that you mentioned. The hook on top of the bucket has 2 holes for the bolt to the binder. These holes are 1/2 chain link different. If you move the bolt to the other hole it should take care of the not tight enough, too tight, situation. It's a one time adjustment that takes about a minute. Once set for your bucket, it shouldn't need to be adjusted again. We've added a note to the recent version of the instruction sheet.
We tried to consider all the operating conditions that might be encountered. Freezing rain, blowing snow or outside storage can render any ratchet or strap type system inoperable, so we disqualified those. We decided on an all steel binder that works in any weather and doesn't depend on ratchets or screws. Since operating temps might be 30 below zero, we felt it was important that the blade could be installed quickly even with heavy gloves or mittens even when all the mechanisms might be covered with ice.
Happy New Year!
Harry
/ BXpanded snow plow? #18
A couple of questions about your experience with the bxpanded blade:
Did you have any problem steering the tractor while plowing? It seems like a blade that far in front of the wheels would shove the front end around.
Is your drive paved or gravel? If gravel, any problems tearing things up?
Thanks.
I like it a lot.
/ BXpanded snow plow? #19
None.
The blade is able to float w/o the loader in the float position, so the tractor doesn't lift its front wheels.
Gravel. No problems with tearing things up. There are a few spots on the drive that were much higher than the surrounding area that I hadn't taken care of this summer.... well they have been leveled now.
I don't consider that tearing up as I really DID want them leveled out.
/ BXpanded snow plow? #20
jdonovan,
Thanks for the info. One last question - what would you estimate is your install/removal time for the blade?
I'm on the fence between the BXpanded blade and the Kubota manual blade. Cost difference is only $200 but Kubota unit requires removal of FEL. I like the idea of quick change between blade and FEL since I don't know in advance what snow conditions will require.
None.
UNUSED ATS PA400 ELECTRIC HOIST (A62131)
UNUSED ATS PA400...
429768 (A61166)
429768 (A61166)
Kubota MX5400 land mgmt package
Kubota MX5400 land...
Hustler Super Z 72in. Zero Turn Commercial Mower (A61567)
Hustler Super Z...
2017 Bobcat E55 (A60462)
2017 Bobcat E55...
(APPROX. 60) UNUSED MISC SIZE RATCHET STRAPS (A62130)
(APPROX. 60)...
