coolant recovery tank gurgling
   / coolant recovery tank gurgling #31
Blue... did the dealer have a new p/n for the head gasket or mention anything about a change out or supercede #?? If so, it might indicate a past issue that has been since resolved thru engineering changes...
As others suggested, check/verify the reusability of the cylinder head bolts and consider replacing them. The pictures you posted that appear as though the cylinder head torque relaxed, and eventually allowed compression to escape by the fire ring and enter the cooling system.
A hot torque check may ease your mind, along with a 50 hour check... Although unlikely, IF it happens again, one sure way to fix it for good is to pull the cylinder head again and send it off to be fire-ringed..
The dealer didn't mention anything about a part number change. The manual calls for retorqueing after 3o minutes. I think I will do a 50 hour re-check.
I'm being stuborn on replacing the bolts. I will call the dealer and see if they recommend replacing them. Typically....with good quality head bolts....I would re-use them once. The next time I would replace them. The torque value is supposed to be set with the bolt material stress below the elastic limit. So in theory the bolts are good forever. We know in practice this doesn't always work out, so to be safe we repalce them. They should be good.
I'm not familiar with "fire ringing". What is this?
   / coolant recovery tank gurgling #33
If the bolts thread easily by finger turning, the bolt hasn't yielded and should be ok for re-use. If you have to work the bolt into the thread, replace them. If we need to replace 1, we replace them all.
   / coolant recovery tank gurgling #34
Some of the newer gas and diesel engines that are being produced are using one time use bolts.... (GM, Ford and Dodge are all using them, as well as some diesel engine manufacturers) but if your manual is calling for a re-torque, I doubt this engine uses "disposable" bolts.. Although I would check the overall length of them just to make sure.
Fire ring or o ring.. is a process used by performance engine builders where a machined groove is cut around each combustion chamber and a wire ring is inserted. When the cylinder head is torqued down, it provides a stronger seal than your typical factory head gasket.
OK...I was stubborn and tight about replacing the head bolts.
I will not be a tight ***.
That's my punishwork....10 times. (plus getting to do the job twice)
I put my new head gasket in today. I torqued it down to 60 ft/lb (spec is 57 - 61.5 ft/lb). I set the valve clearance and cranked it up for the 30 minute break in run. After 30 minutes as prescribed I retorqued. All 14 of the head bolts required a small amount of retightening. On bolt 14 it popped like a piece of glass. I had to diaasemble to remove the broken piece from the block.
My advice from here on...replace the head bolts when replacing the head gasket on the CK25.
I ordered a new gasket ($41) and 14 head bolts ($3.80/ea). Will try again soon.
   / coolant recovery tank gurgling #36
I can imagine the words you said after bolt 14's pop. I probably would have done the same as you if all the bolts threaded in easily as MIE mentioned. Just think how good you'll be now at R&R the head. :) Just kidding. I hope you never have to do it again. Maybe a lesson for all of us to remember if we have to remove the head.
   / coolant recovery tank gurgling #37
Dang stupid bolt!!..
If it popped at 61 lbs.. the bolt was already fatigued... By the pic, it looks as though it seperated just about where the parting line is between the block and head. Thats a common place for a bolt to give up. The threads may look fine where they are engaged into the mating threads of the block. Sometimes you can use a 0-1 inch micrometer and actually see the deformation of the bolt. I'm surprised that the repair manual didn't give a maximum tolerance for the length for the bolts. Usually if a bolt is at or near the overall length its junk and should be disposed of.
If it doesn't seal down and stay this time, I would consider calling an ARP dealer and getting a stud kit.
   / coolant recovery tank gurgling #38
Dam that sucks, but better now than in 50 hours when you least expect it.
I for one really apreciate your thoroughness in reporting your progress and accomplishments.
The photos are great! I understand that this takes time to document so that we all can learn,
Thanks Man
Keep up the good work
   / coolant recovery tank gurgling #39
Thanks Man
I'll second that..
With a clear head, I would have seen that the bolt snapped in the head and not the block. I assumed it snapped in the block and would require a drill and easy-out. In hindsight I could have found a wooden dowel or tree branch the correct diameter and length. With this I could have tapped it with a hammer to imbed it onto the broken stud and unscrewed it. It was not tight in the block, it easily unscrewed and it stuck up at least a 1/2" and the break was not flush and smooth but very jagged. I could have saved a head gasket and some time. I would have replaced just this bolt. But in hindsight this bolt didn't feel like the other 13 during torqueing and I should have removed it to inspect it before it broke. After it broke I was trying to think of someone I new who was mechanically inclined to call and just think through with my thoughts and I couldn't think of anyone I wouldn't be imposing on. So I went with my gut to rip it all apart and start over. My advice to you is be more patient than me and let the helpful folks on this site help you think it through.
2019 GALYEAN...
44052 (A55852)
44052 (A55852)
2014 Mazda CX-9 Sport SUV (A56859)
2014 Mazda CX-9...
2012 FORD F450 XL SUPER DUTY TRUCK (A51406)
2012 FORD F450 XL...
2022 John Deere 1023E MFWD Compact Utility Tractor with 120R Front Loader (A56435)
2022 John Deere...
1995 Freightliner FLD120 T/A Wet Kit Day Cab Truck Tractor (A55973)
1995 Freightliner...
