Picking a Skid Steer/ CTL Mulcher
/ Picking a Skid Steer/ CTL Mulcher #1
BLCMulcher
Fecon FTX 148L
I run a Fecon FTX 148L out of Houston. I am considering adding a CTL to take advantage of their versatility and primarily to run a heavy duty hydraulic brush mower. However I would like to pick a machine that can run a mulching head as well. I assume a CTL that can run a mulching head should be plenty competant with the brush cutter/auger/blade etc.
I need to go used but want a late model machine. Anyone have any suggestions as to make, model and year?
Merry Christmas and have a great New Year!
/ Picking a Skid Steer/ CTL Mulcher #2
We have been satisfied with our Bobcat T320. We use it to run a black fecon head and high flow brush cutter, as well as all of the normal attachments. It would be a nice complement to your 148 and you could do small, residential jobs with the rubber tracks.
Any CTL used to run a mulcher full time will have issues. In the stock configuration, we had to clean the radiator 2 times/day in hot weather. I have made improvements, added a flip up oil cooler for easy cleaning, and a rear cover to make things easier. One of our local competitors runs CAT CTL's. We see him at the dealer all the time and I have seen 2 of his machines that caught on fire.
/ Picking a Skid Steer/ CTL Mulcher #3
I have a CAT268b with steel loegering tracks with a full forestry package and it does better than the asv's that i have run in the past and not to mention that the hydraulic horse power is the ame as the asv give or take 1 hp. Yes there are a lot of cats having problems, but most of them dont pay extra for the forestry package and fail to clean and maintain equipment no matter what brand. You should also look at the hydraulic fluid capacity as for more fluid cools faster than less fluid. With that said, stay away from john deere IMO. I like the steel ott tracks b/c when i had the asv's, the tracks wear pretty quick and are expensive. The steel tracks have been on there for 2 years and i have only had 3 problems with tires and that was cause of me driving on top of old pallets and got nails. Its cheaper to replace track bolts ($568) every 2 or 3 years than a set of rubber tracks and idlers. All of this is my opinion. A machine is only as good as the operator allows it to be!
/ Picking a Skid Steer/ CTL Mulcher #4
Terex/ASV just released a brand new new 100hp CTL set up with a full forestry get-up- standard reversing fan, standard ROPS/FOPS level II (it even meets some type of Canadian logging certification), fire extinguisher, hinged and reinforced belly pans for easy clean out, special hose protection, full forestry limb riser guarding package, metal face seal undercarriage, 15" of ground clearance, 4,000lb ROC, less than 72" wide, full undercarriage suspension, load sensing hydraulics, and 45gpm @ 3,800psi (I haven't run it yet, but based on 310ft lbs of engine torque and that much flow and pressure, nothing will come close hydraulically).
/ Picking a Skid Steer/ CTL Mulcher #5
How much for this new Terex??????????????????
/ Picking a Skid Steer/ CTL Mulcher #7
The new terex is around 75000 without the extra waranty i suggest you try to find an older 09 or 09 pt100 f they have been really good for us we have over 2000 hours on both of the ones we have and are just now putting the first set of tracks on them
/ Picking a Skid Steer/ CTL Mulcher #8
Hi All,
Just have to put my .02 in here, but you should really check out Lamtrac's LTR6125. Skid steer quick attach, reversing fans, confortable cab. This is basically a CTL on steroids, made for forestry but adaptable for buckets, augers, street sweepers...anything. Polyeurathane tracks are available for sensitive ground applications. Food for thought.
And for you that is in Houston area, Texas Timberjack would gladly do a demo for you in a very short delay.
P
/ Picking a Skid Steer/ CTL Mulcher #9
Hi All,
P
I think it would be a real big stretch to consider the Lamtrac 6125 a "CTL on steroids".
While I have no doubt about its brush cutting ability, I would ask you to explain to me how the machine would load brush into a truck with a grapple, load dirt into a truck with a bucket, unload a flatbed with pallet forks, dig below grade, etc. It has no real loader arms to speak of so I can't see how it comes close to offering increased versatility beyond brushcutting and possibly dozing.
Secondly, what is the MSRP of a 6125? I may be wrong, but I'm assuming that it is quite a bit more than $100k.
/ Picking a Skid Steer/ CTL Mulcher #10
actually tidewater is discounting the ones they have so you could get on with a mulcher for around 100 about 85 without
/ Picking a Skid Steer/ CTL Mulcher #11
I googled their website...holy crap!!!! They have four 2007 6125s and they're advertised for $145k+ with a Magnum head. They must have been real proud of them to hang on to those machines for this long (2007s)...three years old is a long time to have something in inventory. Will cummins even warrant those engines anymore?
I know Bobcat would have gone nuts if my dealership would have sold a three year old machine and asked for warranty.
Isn't Magnum now owned by Bradco? I heard that their mulcher was pretty decent.
Thanks for the replies. Please keep up the good info.
There is a 08 Bobcat T320 with 1700 hrs, bobcat head (don't know if its a 48 or 60) plus a bucket, grapple bucket, 20+5 dovetail trailer, toolboxes and air compressor for $53,000. Whatcha think?
Also, for you guys with skid steer mulchers how important is having positive pressure cab over plain old ac & heat?
You are right Digdeep about the Lamtrack. My 148L is beefier and much closer to a SS/CTL with the loader arms than the Lam.
Thanks
/ Picking a Skid Steer/ CTL Mulcher #13
I think new is better no matter what model you select, reason is I think all makers have learned some lessons over the last 3-5 years.
Next you should buy by service more than anything else.
I wanted a ASV before they were TEREX and got some of the worst help BEFORE i even purchased the unit so that told me a lot.
I called CAT and the salesman came out to me the next day and offered to drop a unit off for me to play with. Also offered free pick up and delivery every time I needed service - and these people were 75 miles away. Next they had a HUGE service truck that goes to customers. This rig is filled with fluids, filters etc. They come out go through my machine right on site. Gotta love that.
I have the non pressurized can and it does ok when I'm in a cloud of dust, which I am most of the time, pressurized would be nice.
I know I've put my CAT through heck in the Desert where the temps get up over 125 during the summer and the CAT doesn't skip a beat. She pulls like a mule and lifts like an Elephant.
Yep service is almost more important than the brand some times.
/ Picking a Skid Steer/ CTL Mulcher #14
Excellent point about service and support.
However, I think it is very important not to label an OEM as having poor support since so much of this is dependant on the local dealer. For instance, my local CAT dealer sucks for support on compact equipment, but your local dealer is excellent. Ironically, I can go to my Terex dealer who sells Case and get great service support, but the sales guys are average.
I guess CAT would offer mediocre service and support based on our two experiences. Remember that all dealers regardless of brand are independant dealers, and you need to visit and ask questions to see if they fit your needs.
/ Picking a Skid Steer/ CTL Mulcher #15
-----you may want to think about a Fecon FTX90L (loader arme) with a RELIABLE Yanmar engine..i have one available, I also have a Fecon BH74SS mulcher for a skid steer--please call 513-284-8990 thanks Jim
/ Picking a Skid Steer/ CTL Mulcher #16
I bought a Takeuchi TL250 high flow last year...it was everything I was told to expect, and then some. The only thing I changed from the original configuration was the high flow quick couplers and went to the flare nut fittings, because running the mulching head ended up making the quick couplings leak. I also bought a TL230 series II at the same time. 3 year/3000 hour warranty was standard and nobody else would touch the price or warranty. I have to admit that I like the front glass and down angle visibility on the Bobcat over the Takeuchi, but the operator space in the Bobcat felt cramped and tiny when compared to Takeuchi. I will admit that the interior of the Bobcat was fancier since it looked more like what you'd find in a car rather than in a piece of equipment.
/ Picking a Skid Steer/ CTL Mulcher #17
Service is a key. We wanted to buy a CAT CTL. Went by the dealership and asked to talked to someone. They gave me his phone number. I called and gave him the specifics of what I wanted. CTL, mulcher, bucket, etc. He emailed over a quote and said let him know if he could be of any further help. Also went to Bobcat just to compare. Salesman was there, helpful and gave us all of the pricing on the spot. Introduced us to parts, services managers. We left to think about it. 2 days later, bobcat called back and said he had located a machine similiar to what we wanted and transferred it and a mulcher to his location. He said to come get it and try it out. After the demo they all met with us to go over any concerns/questions. We have gotten that kind of service ever since from parts, services, etc. The CAT salesman still hasn't followed up.
This is just my local situation. Visit your dealers and scrutinize their service before the sale. The service you get when they are trying to sell you something is the best you will see. If it sucks then, it will really suck when you are broke down.
/ Picking a Skid Steer/ CTL Mulcher #18
If i cant see the sales man when i need to do business, then an email is just throwing gas on my fire! I want to see him face to face and se who really appreciates the money more. I have delt with Blanchard for a while and the other day went to a store that i never went to before and they were right on the job. Its not right that others cant be like that. When u get better service from walmart than your local dealer, its time to leave!
WGTactical... good to hear you like the TL250. I am looking at a 2009 Tak TL250 with 370 hours, 1 yr left on warranty, aux hyd cooler, enclosed cab with ac & heat, 6 foot extreme duty hyd brush hog, grapple bucket and bucket.
Whats this package worth?
Thanks!
/ Picking a Skid Steer/ CTL Mulcher #20
Great question DIGDEEP, my bad for not being clearer.
The 6125 has optional "high lift kit". That is basically loader arm kit that will bring your front attachment to almost 7 feet in height. That way the machine can be used for other applications but mulching. I can certainly get you pictures or specs of that if you are curious.
Thanks!
2019 GENIE GS-1930 ELECTRIC SCISSOR LIFT (A62129)
2019 GENIE GS-1930...
2019 CATERPILLAR  XQ35 GENERATOR (A58214)
2019 CATERPILLAR...
2025 Hydraulic Brush Cutter Skid Steer Attachment (A61567)
2025 Hydraulic...
John Deere 12in Channel Tooth Bucket Excavator Attachment (A60352)
John Deere 12in...
2016 FORD F550 CREW CAB SERVICE TRUCK (A59905)
2016 FORD F550...
2005 KENWORTH T800 T/A 6X4 DAY CAB TRUCK TRACTOR (A59908)
2005 KENWORTH T800...
