Draft Control
/ Draft Control #2
Draft control operates by sensing the amount of "pull" on a ground engaging implement. If while using such an implement the tractor happens to get stuck, the draft control will lift the implement over the obstruction.
This is mainly used for plowing operations, but is also sometimes useful when using a boxblade or scraper blade. When using draft control a constant ground speed should be maintained.
My owners manual advises to not enable this feature when using non-ground engaging implements, and unexpected movement of the lift arms could result.
Check your owners manual for details about how this feature is implemented on your tractor.
Excavator trenching bucket- one bucket per lot (A63689)
Excavator...
Pallet of Miscellaneous Duplex Polyester Webbing Slings (A56858)
Pallet of...
2005 JLG Skytrack 10054 10K Capacity Telehandler (A59213)
2005 JLG Skytrack...
2016 Ford F-150 4x4 Pickup Truck (A61573)
2016 Ford F-150...
2014 CASE IH Magnum 340 (A63111)
2014 CASE IH...
Wacker Neuson AR14H (A60462)
Wacker Neuson...
