Oil & Fuel cold weather hydraulic problem
/ cold weather hydraulic problem #1
Stanicet
St-Anicet, Quebec, Canada
Kubota L3400
just purchased a used L3400 Kubota (2005), I resided in St-Anicet, Quebec, Canada, and having difficulty using the hydraulic system in cold weather when it is below (-10C), any suggestion.
/ cold weather hydraulic problem #2
Welcome and hello.
What kind of trouble? Just slow or nothing moves? Does it become normal after warm up? If you have water in your hydraulic fluid bad things happen in the cold. If the fluid looks to have a milky haze to it then I would suspect water. Give us more info. There is lots of help available here.
/ cold weather hydraulic problem #3
The quick and the dead answer is a kerosene fired salamander heating the tractor from the side for an hour before you use it and your problems will no longer exist.
They work and work well and I have been using mine which is 110,000 BTU for this for 16 years for all my equipment.
Edit: The external hydraulics/cylinders valve will be very cold and will require a long period of operation to begin to bring them up to near operating temperature for your use.
In one of my examples I use the Kerosene fired salamander to heat up the hydraulic reservoir and engine of my firewood processor and it works wonders as it has a huge tank and large engine that are huge heat sinks and get very cold quickly- your tractor is no diferent.
The Kerosene fired salamander will solve your cold operating issues as they will be gone after an hour of heating the tractor up with the salamander.
/ cold weather hydraulic problem #4
Kubota is very touchy about their oils, you may need lighter oil from Kubota and may need to block off some portion of the radiator to keep the engine temp up. Not all the heat is rejected by the radiator, at low temps the engine block will lose heat too.
/ cold weather hydraulic problem #5
I run my tractor at those temps all the time and never experience any trouble. Never have to run a heater. I often run at -5F or 0F. Things are a little slow for about 15 minutes but after that normal. One time at -20F everything stopped working about 10 seconds after start up. I shut it off and plugged in block heater for an other hour. Then every thing was OK.
/ cold weather hydraulic problem #6
With my ford 3930 at start up I will have a slugish loader for the first 10 minutes then after that it goes good
/ cold weather hydraulic problem #7
In sub-zero temperatures my hydraulics are often really slow. I find by letting it sit there for a period of time (10 - 15 minutes) things will warm up and the hydraulics will work okay. I have also put an external heater and force hot air onto the engine for a bit to get things warmed up.
Be careful and do not over work the FEL while the fluid is still cold as you can blew a seal.
thanks, just finsihed change the hydraulic oil and filter, and used a space heater to keep the outside lines warm
thank for the assistance, my first tractor knowledge is imited. So th colour of the Hydraulic oil was dirty white to grey in colour. So i have change the the hydraulic oil and filter, now seem to be working better. Quick question, do I need to get a Heater for the hydraulic line or system?
/ cold weather hydraulic problem #10
I would think that you would want a block heater if you don't have one. But that is mostly for starting. It may warm the hydraulic oil slightly. If it is below 10 or 15 degrees F I plug the block heater in about an hour before hand. If it is below 0 F I give it about two hours if I can. Every tractor and the way it is used is different. So you will have to experiment with yours, If I were you I would just start using it and make changes as problems arise. You should see a vast improvement with your new hydraulic fluid. It sounds like you had some water in the old stuff.
/ cold weather hydraulic problem #11
I seriously appreciated this info. I should never have a temp problem here where daytime temps are never less than +20F. I had been wondering how to deL with the cold
/ cold weather hydraulic problem #12
I've worked on heavy equipment that has a "warm up valve" to warm up the hyd system oil......basically it consists of a pressure relief valve deadheaded to build up pressure and dump directly to reservoir tank.....then the cold temp light goes off and the oil is warm enough to run the machine.....
As we all know (or should) when your hydraulic system goes from high pressure to low pressure without doing any work (lifting cyl or running hyd motor) then VIOLA there's heat.!!.......Don't we all complain about this in the summer when running our equipment constantly in overload relief and the hyd oil overheats...??.....YES..!!
Well the answer you are looking for is, after startup at idle actuate the FEL control valve lever in a mode to blow pressure over the relief valve ...(.ie: bucket curls cyls sucked all the way in and hold the lever on the valve)......this will warm up the hyd oil in a few minutes while you are warming up the engine anyways and you'll be able to feel the warmth on the valve block with your hand......Do not hold your hand on the hoses that are pressurized for safety.....(Akkamaan's Got Pics to prove that)......
If your tractor is healthy hydraulically this will not harm your tractor but don't tie the valve lever down and forget it......it will potentially overheat.....
Whenever this subject comes up I've never seen this advised before here but it does work pretty good in extreme conditions.......
Hope this helps.....Let me know how it works.......:thumbsup:
/ cold weather hydraulic problem #13
This is a time of year when Super UDT or other suitable low-viscosity hydraulic oil is beneficial. As you are learning, clean oil and fresh filters help a great deal as well.
2014 MASTER END DUMP TRAILER (A65643)
2014 MASTER END...
100 Gal Fuel Tank (A65643)
100 Gal Fuel Tank...
INOP/NON-RUNNING 2004 International 4200 Dump Truck, VIN # 1HTMPAFM64H660244 (A65563)
INOP/NON-RUNNING...
1999 Volvo Day Cab Truck, VIN # 4VA7BBRF8XN767346 (A65563)
1999 Volvo Day Cab...
20ft Driveway Gates (A65579)
20ft Driveway...
2018 HINO 338 4X2 S/A 26FT FLATBED (A59912)
2018 HINO 338 4X2...
