Wear Seatbelt When Using Backhoe?
/ Wear Seatbelt When Using Backhoe? #1
CompactTractorFan
Super Member
Pennsylvania
Kubota BX25
My BX25 has a reversing seat for use with the backhoe. Should I have the seat belt on when using the backhoe? I have up until now, but now I'm wondering if I should...
/ Wear Seatbelt When Using Backhoe? #2
ROPS UP - SEAT BELT ON - STAY SAFE!!!
YES! See above
YES! See above
Yes, that's what I figured, but I was not sure since I don't think most backhoes with separate seats have seatbelts (or do they :confused:).
/ Wear Seatbelt When Using Backhoe? #4
Why? Do you think you are going to turn the tractor over using the backhoe? I guess, if so, then use the seatbelt.
Our dealer said that most rollovers occur when using backhoe. I guess I'll be using the seatbelt then...;)
/ Wear Seatbelt When Using Backhoe? #6
My one year old Woods BH90-X backhoe does not have a seatbelt.:eek:
Yes, I did not think that most came with seatbelts. I just wanted to make sure it would not hurt to wear it. (like wearing it if the ROPS is down)
/ Wear Seatbelt When Using Backhoe? #8
Why? Do you think you are going to turn the tractor over using the backhoe? .
Let me count the ways .
Don't use the BH with the rops folded either.
/ Wear Seatbelt When Using Backhoe? #10
Yes you prob should wear it. I myself will never wear one but thats just me.
/ Wear Seatbelt When Using Backhoe? #11
This seems unusual, with the outriggers extended I think it would be very difficult to rollover?
My backhoe has a separate seat, no seatbelt.....
/ Wear Seatbelt When Using Backhoe? #12
I'm guessing it's because they are not digging directly behind tractor, but are digging at an angle to the side. Very easy to pull the tractor up when doing this. Dont ask how I know. :D
Yep, I know too...;)
/ Wear Seatbelt When Using Backhoe? #14
The closest I have ever come to rolling over was using the backhoe.
Working along a road with a steep drop-off on one side.
Set up machine parallel to road, picked up a big rock with the thumb, and tried to lower it over the edge of the bank to a shelf about 8' below the road surface.
The machine got very tippy until I grounded the rock on the steep surface of the bank and slid it down to the shelf.
Beyond that narrow shelf, it was another 20' to level ground -- not a ride you want to take.
/ Wear Seatbelt When Using Backhoe? #15
I don't, but my old equipment doesn't have seat belts!
/ Wear Seatbelt When Using Backhoe? #16
CTF - for some of us old guys, we do things they way we have always done them. They did not have things like seat belts, ROPS and other safety devices when I was your age - at least not the ones we owned.
At your age, develop the good habits now, and they will stick with you.
/ Wear Seatbelt When Using Backhoe? #17
I wear mine. But, you can make your own call about it. :)
I will. :thumbsup:
2023 Kubota KX057-5 Compact Excavator (A63689)
2023 Kubota...
2000 FORD F-650 SUPER DUTY (A63569)
2000 FORD F-650...
2 new 10'' Pallet fork extensions (A61567)
2 new 10'' Pallet...
2014 INTERNATIONAL LF687 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2014 INTERNATIONAL...
2024 Kubota M7-174D (Deluxe) 4WD Tractor - 244 Hours (A63688)
2024 Kubota...
36in AIM Tooth Excavator Bucket (A64194)
36in AIM Tooth...
